Old 06-24-2004, 07:21 PM   #31
JediBri
Glory to GOD
JediBri's Avatar
Oddometer: 501
Both of my 950s 'chirped'- the '03 silver and the '04 GO!
Brian
currently rideless...
JediBri is offline   Reply With Quote
Old 06-24-2004, 08:48 PM   #32
Greg Minor
The Trespasser
Greg Minor's Avatar
Oddometer: 2,322
Originally Posted by Anthony
I discovered yesterday that my wife's bike has been running with about half the coolant required. It was making the chirping noise that I think we are talking about I think more before I topped off the coolant. Could it be the impeller in the H2O pump?
Just a theory....
P.S. CHECK YOUR COOLANT!
Anthony
My bike is in the shop getting a warranty waterpump rebuild is your coolant darker than normal?
THE ORANGE ONES ARE FASTER!
Have maximum fun while preserving bike and body
2004 KTM 950
2003 Ducati Multistrada
2001 Honda XR 400
1988 C&J Honda 625
1970 Honda SL 100 (green)
Greg Minor is offline   Reply With Quote
Old 06-24-2004, 09:59 PM   #33
Anthony
Hurry up, Stephie!
Anthony's Avatar
Oddometer: 301
I don't think so, but as all of it had been pulled from the reservoir, it's hard to tell. I think what happened is her cooling sys. had never been bled properly, and after riding at 10-20 mph in HOT canyons in Utah, and dropping the bike a few times, the bubble finally reached the top. At least this is what I hope because alternative B is a blown head gasket
(no other symptoms to suggest this however...) This is a NEW 2004 model (orange, not s, black rims, no epc, etc...)
Hayduke drove a Jeep.
Anthony is offline   Reply With Quote
Old 06-24-2004, 10:30 PM   #34
JediBri
Glory to GOD
JediBri's Avatar
Oddometer: 501
My silver 03's coolant turned filthy over time, though this was after the 600mi service and a gasket could have been torn or something.
I had hoped that it was due to a low grade coolant but now think it was an oil-coolant leak. I hope my Go! is good.
When the silver overheated early this year I was shocked at the sludge that I drained. Still have a jar of the crud, though the silver is gone.
Old 06-26-2005, 12:28 PM   #35
smthmp
Internal Combustophile
Oddometer: 46
No one figured out the chirp?
Lots of bikes doing this, seems like lots of us are interested... Nobody ever figured it out? Just for the record, mine does it, 2004 model and has had the water pump update.
smthmp is offline   Reply With Quote
Old 06-27-2005, 04:26 AM   #36
crashomatic
crashomatic's Avatar
Oddometer: 17
chirp away!
Hi,
I have owned a 03,04, and a 05...only the 05 chirped. Its driving me nuts..thought it was loose valves or something. I wonder if its something in the plumbing.. Ah the benefits of having 3 year warranty in Asia. Ride it till it blows up
crashomatic is offline   Reply With Quote
Old 06-27-2005, 05:25 AM   #37
Reformed DucFlogger
Inventor Of The Wheel Mk2
Reformed DucFlogger's Avatar
Oddometer: 1,445
Clutch...
...throw-rod bearing? Older (90s era) Ducatis would have that bearing begin to go and it would chirp and then eventually squeal like a banshee. I think the odds are low, but...
it's not the ord itself but the cap the end of the rod sits in on the back of the outside pressure plate/cover.
There's also the old stethescope (sic) routine.
"...who gives a rat fornication?"
Reformed DucFlogger is offline   Reply With Quote
Old 06-27-2005, 10:04 AM   #38
rider914
Agnostic Adventurer
rider914's Avatar
Oddometer: 2,451
Intake?
Sounds like an intake squeak to me.
05.5 non-s, stock exh, cannister removed, SAS still there but disabled, ~2400miles.
Clutch in, click 1st gear, ease clutch out, "chirp, chirp, chirp."
There since day 1. No change after 1st service. More noticeable when cold (choke partially on?), but still barely there when hot. Also more noticeable on an easy take-off, less so on a hard launch.
- Matt
'05 950ADV
'04 525EXC D/S
'07 Tiger1050
Will herd cats for beer (... but I rescue puppies for free )
SmugMug (coupon: bLfv2vBXZicd6)
rider914 is offline   Reply With Quote
Old 06-27-2005, 12:56 PM   #39
RAGrote
RAGrote's Avatar
Oddometer: 1,021
Originally Posted by Desmofan
Maybe it's just carb squeek/intake honk ( ever hear flatslides chirp?)
Exactly correct!!!
OMG!!!
People... STOP OBSESSING!!!
Air squeaking past the slides at small throttle openings!!! DRIVE IT!!!
Now back to wes and our regularly scheduled bitch/moan sessions.
RAGrote is offline   Reply With Quote
Old 06-27-2005, 07:36 PM   #40
wesfnw
portland,or
wesfnw's Avatar
Oddometer: 356
Originally Posted by Katoum
My bike has developed a chirping sound from the motor. It sounds like its coming from the right side. This was noticable when first started but has become worse lately and is apparent all the time. It happens when mild throttle is applied at low speed with the clutch engaged. You can make it chirp everytime you let the clutch out but it happens after the clutch is fully engaged. A mechanic told me he thought it might be the water pump, as he has heard this noise in other bikes. If there is excessive play in the impeller shaft it makes sense that this could be causing the noise. My riding partner has has the exact same noise on his 950 which is a 03, mine is a 04. Are we the only ones who have a canary under the hood?
a mechanic?...a "KTM" mechanic?
that chirping sound is your head gasket & valve train self destructing inside that "state of the art" LC8 engine.
wesfnw is offline   Reply With Quote
Old 06-27-2005, 11:35 PM   #41
LKN4DRT
Mended
LKN4DRT's Avatar
Oddometer: 714
Could the chirp be squeaking rubber in the cush drive?
Nine five O A
Six nine O E
Five three O
Four five O
Five O O
LKN4DRT is offline   Reply With Quote
Old 06-28-2005, 09:23 AM   #42
RAGrote
RAGrote's Avatar
Oddometer: 1,021
Keep Going!!!
It's getting entertaining now!!!
Maybe it could be the electrons rushing out of the generator...!! ??
You guys are KILLING me!!
Old 06-28-2005, 09:26 AM   #43
HappyGoLucky
Goeie Grys Giftige Gert!
HappyGoLucky's Avatar
Oddometer: 4,311
Perhaps the irritating chirping noise is actually WESFNW's voice after he tried a round of bad ju-ju on all LC8's........
Be true....to yourself
HappyGoLucky is offline   Reply With Quote
Old 06-28-2005, 08:24 PM   #44
Katoum OP
Katoum's Avatar
Oddometer: 711
While entertaining as it may be to some, it has been a unsolvable mystery for me since I started this thread.
I just had all my clutch plates replaced along with rod and booster unit, and the f___in carnary is still alive and well.
I now have 24000KM and just got back from a 10 day backroad adventure and I must say that when I'm 200km from the nearest pavement that Canary starts to talk pretty loud to me.
Our bike's performed flawlessly for my friend and I who has the same bike, yet that chirp is hard to put to rest.
Now if I could just solve the low oil pressure to the cam tensioner on a hot motor driven off road? But that's a discussion for another thread if I can find it.
Katoum is offline   Reply With Quote
Old 06-28-2005, 09:12 PM   #45
KTM950
apexhunter
Oddometer: 153
Question chirp cause
A couple weekends back we rode 600 miles and heard a similar sound. At first it appeared to be throttle cable related-like the slack being taken up and then, the carb. slides first mvmt. Later, it seemed that it was related to the upward mvmt of the front forks-under acceleration. Then it seemed that it was just a cable rubbing as the forks came up.
At present the bike is in for service (7500 mile check list), tires and a fork seal. Otherwise it would be tempting to go out and check on the source again.
Ride safe and have a fun 4th
2010 KTM 530 XC-W Super Motard
2007 Ducati MS4RS
2006 KTM EXC450
2005 Montesa Cota 4RT
2004 KTM 950 Adverture
1970 Honda CB750
1975 Honda TL250
1971 Honda CT70H
1968 Honda Z50A
KTM950 is offline   Reply With Quote
Times are GMT -7.   It's 10:25 PM.
