Old 08-07-2006, 05:06 AM   #61
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,100
I can hear a chirping from Kawasakis!!!
I had a chirping coming from my KLE400 Kawa and turned out to be the advance was too much!!! It sounded as described here, when accelarating... from a stop and when idling!! What do you guys think??
Old 02-18-2008, 07:03 AM   #62
BDV300
Oddometer: 11
Did this ever get resolved?
Our 2006 950 was chirp free until the first service was performed, now the bird is there. Same chirp description as everyone else. The bike runs awesome though and that's why I don't want to spend the time/effort/money to 'fix' it. Maybe, it's not really broken.
Did anyone ever figure out what the chirp really was?
BDV300 is offline   Reply With Quote
Old 02-18-2008, 07:27 AM   #63
charlie264
charlie264's Avatar
Oddometer: 8,401
Chirp
On my XLV750R, one of the pulse coils for the ignition broke and needed rewinding. After that I noticed a chirpy whistle from one of the exhausts. Block one, no chirp! Block the other, canary! Did a compression test and one of the cylinders was down about 10% to the other. So I put it down to a slightly leaky exhaust valve. Never really got to bottom of the chirp, sold the bike with. Fully disclosed of course, which he used to his advantage.
Charlie.
950SE
Old 02-18-2008, 07:35 AM   #64
BDV300
Oddometer: 11
Leaky exhaust valve?! They did find that two exhaust valves were out of spec and had to be adjusted. I'm not sure how far out of spec, or what the adjustment involved. The bike now has 750 miles on it, so I HOPE it's not a leaky exhaust valve.
Old 02-18-2008, 07:53 AM   #65
charlie264
charlie264's Avatar
Oddometer: 8,401
Chirp
Originally Posted by BDV300
Leaky exhaust valve?! They did find that two exhaust valves were out of spec and had to be adjusted. ????.
They are either the right or wrong valves. Out of spec, not sure what you mean? Diameter of the valve shaft and collars can vary. If a valve is not correctly ground in using valve grinding paste, it will either wear in and seat itself correctly or wear unevenly allowing gas to pass. As for KTMís I donít know, some engines the valves and seats are replaced at the same time so valves donít need to be ground in.
Old 02-18-2008, 12:55 PM   #66
BDV300
Oddometer: 11
Out of spec as in the clearances were too tight on 2 of the exhaust valves. The only other task performed (other than the routine 600 mile service stuff) was to set the needles to the richest setting. My bike was VERY lean from the factory.
Old 02-18-2008, 02:06 PM   #67
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 10,231
I think the chirping is common among carburetted twins in cold temps. It's the carbs. My Ducati does it too.
Ohh...and my KTM's clutch chirps when first engaging in cold temps too. Actually, my KTM makes all kinds of wierd racket. I've been thinking earplugs might be the right solution.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 02-18-2008, 02:14 PM   #68
BDV300
Oddometer: 11
I'll go the ear plugs route as soon as I know the thing's not going to chuck a rod through the top of the engine ;-)
I agree that it's carb related, but don't think it's temp related. I picked up the bike this past Saturday and it was one of the warmest days since we've owned the 950. What a great day for chirping!
I'm going to pull the top off the air box this weekend and see if I find anything obvious. Still open to other ideas though.
Old 02-18-2008, 02:16 PM   #69
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,412
My SE was chirping for the final 20 miles of my last ride. Turned out to be a broken tab on my skidplate. Wish it where something more interesting, as I would have immediately been able to eleminate the clutch and carb theories...
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 02-18-2008, 06:23 PM   #70
spafxer
spafxer's Avatar
Oddometer: 2,649
Vacuum Leakage!
Chirping can come from the rubber caps used to cover the vacuum ports on the intake manifolds. If the caps deteriorated, they act like a reed on a wind instrument. If the chirp goes away on application of full throttle (less vacuum) that's a sure sign of intake track leakage.
Good Luck.
jim
spafxer is offline   Reply With Quote
Old 04-27-2008, 10:38 AM   #71
EnduroJoe
EnduroJoe's Avatar
Oddometer: 87
The best I can figure is that it is the front exhaust flange or front mounting bolt. I had the air filter off watching the carb slides flutter and it still sounds like it's coming from down around the front cylinder. The chirp did stop for a littel bit after a crash, I replaced the front exhaust gasket every time I would retighten the gasket the chirp would stop for a littel bit. I tightened the front mounting bolt and the chirp got a higher pitch, so I set it back to its original position.
It still chirps, and still don't know what it is for shure. It's not the sas reeds, took them off. did valve adj everything looked ok. Water pump seal & impeller look ok. I have heard a few KLRs with a similar chirp. Anyone with FI bikes have it?
This is what mine sounds like.
I'll just have to get earplugs.
EnduroJoe is offline   Reply With Quote
Old 04-27-2008, 01:55 PM   #72
cpmodem
Orange Caveman
cpmodem's Avatar
Location: masa yee yah tee 59į 14' 9" N / 135į 26' 42" W
Oddometer: 7,103
That doesn't sound like the chirp I've heard from the 950's. Your's sounds more like a "squeek" from something loose. Maybe part of the fairing or the exhaust heat shield.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 04-28-2008, 07:07 AM   #73
BDV300
Oddometer: 11
That's the same noise mine makes. You were loading the engine to get it to do that, right? I've yet to figure mine out but it's time to start taking things apart. Mine has developed a bad habit of stalling right after a hot start (great when you pull out into trafffic and it stalls). The idle hangs a bit as well so it definately needs some attention. Maybe I'll get lucky and find the squeek while I'm looking for the other issues.
Old 04-28-2008, 08:21 AM   #74
bykpimp
Live and let ride
bykpimp's Avatar
Oddometer: 1,410
My bike chirps when cold and just fired up. If I cover the screw holes where the db killers go in the Akras with my fingers, the chirp goes away.
" I can't fix your motorcycle over the phone or internet" Spanky
bykpimp is offline   Reply With Quote
Old 03-13-2013, 02:10 PM   #75
SimplyExploring
Oddometer: 5
My 2008 has just developed a chirp. Has anyone ever got to the bottom of this?
Its never done it before. Its not a whine its not a whistle its a chirp! Its been laid up over winter and first ride out this year it starts chirping!
SimplyExploring is offline   Reply With Quote
Times are GMT -7.   It's 01:47 AM.
