Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 07-12-2012, 07:12 PM   #49621
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Originally Posted by wayno View Post
Here is Dummy's answer: Timing chain on wrong location and I know you pulled dist to make sure it is in right location. Don't ask how I know about chain....but there was gas on bottom of hood when I got done..... Blowing instead of sucking after a 20 below night....lol
Enough, Pics or it didn't happen right!
The marks are RIGHT the dist is WRONG, but it runs like that.
So its still running like CHIT but it runs.....
Everything SAys it should not RUN, with the dist pointing at #1 it will not run.
Maybe someone used a cam out of some obscure AMC engine, no idea.
It starts GREAT idles pretty good, just runs like chit after that, I've rebuilt the carb. I'm actually thinking its either a flat cam, or vacuum leak there someplace. but will work on it tomorrow.
Its got a little lifter noise but its not terrible sounding.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 07-12-2012, 07:50 PM   #49622
Dragon43
If you insist.
Dragon43's Avatar
Oddometer: 6,048
Some engines will run, sorta, when 180 degrees out of time......
Double check for compression stroke when setting to The correct cylinder to fire... ... Yepper, sometimes it is that simple......
Shouda, woulda, coulda but dint.
Dragon43 is offline   Reply With Quote
Old 07-12-2012, 08:03 PM   #49623
tcourdin
Resident Spooner
tcourdin's Avatar
Oddometer: 10,690
Originally Posted by ozarkrider View Post
I've been wanting to check out the Salida area. You up for a run that way next year?
Yes sir, ready when you are!
My SPOT
tcourdin is online now   Reply With Quote
Old 07-12-2012, 08:10 PM   #49624
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,502
well there is that, but Ive never been able to tell the difference between 6 degrees and 20 degrees by a screwdriver in the plug hole either..
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is online now   Reply With Quote
Old 07-12-2012, 08:18 PM   #49625
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
IT can be done, even did it on the Nissan because in their wisdom Nissan did
not put actual timing marks on the engine just used two gold links on the chain.
once you rotate the engine they're lost.
So its work it out by feel if someone else started the job and you had to finish it.
Had another issue years and years ago with a 318 for some unknown reason
did not put marks on the timing chain.
I didn't start working stuff yesterday. I've been doing it for 25 years.
Old 07-12-2012, 08:22 PM   #49626
mouthfulloflake
Not afraid
Oddometer: 17,502
is that point type distributor?
232 or 258?
1 5 3 6 2 4
did you verify the firing order?
gyah, yeah im sure you did these thigns, im not trying to insult you , just trying to think thru the things that might be wrong.
Old 07-12-2012, 08:28 PM   #49627
mouthfulloflake
Not afraid
Oddometer: 17,502
I learn things everyday, every engine, every scenario..
IM just trying to help, but yeah, good luck with it I guess.
Old 07-12-2012, 08:34 PM   #49628
tcourdin
Resident Spooner
tcourdin's Avatar
Oddometer: 10,690
O'jay when you leaving for Niagra Falls?
My SPOT
Old 07-12-2012, 10:21 PM   #49629
tokyoklahoma
75%has been25%wanabe
Oddometer: 1,723
Bluhduh 180 out
232 or 258?
1 5 3 6 2 4
I've seen guys put in a dizzy 180 out, and instead of pulling it and re-installing it, they just called wherever the rotor pointed #1 and placed plug wires around the distributor according to the firing order.
tokyoklahoma is online now   Reply With Quote
Old 07-13-2012, 01:59 AM   #49630
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,706
mornin fellers
DrLewall is online now   Reply With Quote
Old 07-13-2012, 03:02 AM   #49631
ozarkrider
Discombobulated Sociopath
ozarkrider's Avatar
Oddometer: 5,628
Thursday at 3pm. Arriving in Vermont sometime Sunday. Staying till the following Thursday then headed back home via the Falls.
US 62 starts just south of Niagara and will take me all the way home. My boss just came home via that route last week. He said the scenery along the Allegheny River and through the Allegheny Mtns was awesome, even in 100+ degree heat.
Gotta spoon a new tire on Yellaphant and finish the service on it. I'm soooo ready to go.
O'Jay
I'm not weird, I'm Limited Edition!
Life is a sexually transmitted disease and the mortality rate is 100%
ozarkrider is offline   Reply With Quote
Old 07-13-2012, 05:04 AM   #49632
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,723
Great deal on the Geigerrig 1200 hydration pack.
http://sellout.woot.com/offers/rig-1...-pack-100-oz-1
Old 07-13-2012, 05:59 AM   #49633
mouthfulloflake
Not afraid
Oddometer: 17,502
I bought a 77 CJ5 factory V8 renegade trim package.
engine started right up, sounded great, would rev great, no more smoke than normal ( from a carbed engine with fenderwell headers)
but the truck would just barely move it self, in low range it would get around alright.
compression check, 0,0,1,0,0 supposedly the engine was recently rebuilt
pulled the engine out, and tore it down, someone had broken a piston ring on EVERY cylinder when installing them.
the crank was 0/0, and the tinware was useful on my 360, everything else went to the scrapyard.
Old 07-13-2012, 05:59 AM   #49634
terrascout
Oddometer: 1,682
Route?
From AR I like to head up and grab 400/54 North of Joplin to head West and miss the toll roads. You could keep head west once you hit Wichita area but lots of little towns to slow down for. I usually head north from Wichita and the wander west. If all else fairs I hit 70 and go west until Oakley, KS. You can run straight west all the way to CO Springs. Fairly wide open and scenic. Not many town so fill up when you can. There is about a 100 mile stretch just before Kit Carson to just before the Springs with no gas stops. But you can move right along.
terrascout is offline   Reply With Quote
Old 07-13-2012, 06:20 AM   #49635
tcourdin
Resident Spooner
tcourdin's Avatar
Oddometer: 10,690
Thats awesome, you're gonna enjoy it! I'm hoping I can sneak in a ride before our usual labor day ride, I'm needing some mosikkle therapy!
You got me all excited bringing up Salida, it's a kewl little town! I could spend a few days there.
Heres a pic from an awesome little restaurant we ate at last year, it's right on the river!
My SPOT
Times are GMT -7.   It's 03:58 PM.
