Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 08-08-2012, 09:41 PM   #51076
mdawg12
Old and Slow
mdawg12's Avatar
Oddometer: 1,674
You know, more I think about it - you have air pressurized forks with air over oil, not sure why it shouldn't be OK in rear shock? May not be perfect factory performance, but for light weight trail riding probably never know the difference.
mdawg12 is offline   Reply With Quote
Old 08-08-2012, 09:48 PM   #51077
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,347
Originally Posted by mouthfulloflake View Post
understood Mdawg
from what I have read ( total google, might be inaccurate)
the nitrogen of high pressure charge is contained within a 'bladder' rubber, or something else, but separate from the oil?
confirm, deny, argue, educate me either way please.
got info, please share..
This is true. The bladder takes up more then half the space in the shock. So other then heat maybe having a small amount of effect in changing the pressure a lb or 2 I seriously doubt oxidation ever really becomes much of an issue.
Here's what the bladder looks like.
Old 08-08-2012, 10:48 PM   #51078
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
http://www.wnd.com/2012/08/yikes-oba...your-paycheck/
What will the goverment say your job is worth?
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 08-09-2012, 04:28 AM   #51079
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 32,856
Mornin fellers
got to catch up on my reading here, but not right now..gots to run!
DrLewall is offline   Reply With Quote
Old 08-09-2012, 05:12 AM   #51080
MountainMoto
Ain't Life Grand
MountainMoto's Avatar
Oddometer: 197
Mornin Doc. Chilly 70 degrees here in Lubbock this morning. Glad NWA got a little rain.
Originally Posted by DrLewall View Post
Mornin fellers
MountainMoto is offline   Reply With Quote
Old 08-09-2012, 06:00 AM   #51081
tcourdin
Resident Spooner
tcourdin's Avatar
Oddometer: 10,578
the manual calls for 200 + psi of Nitrogen... holy cow!
Yepers, I thought it was pretty high!
While setting up my bicycle I noticed the fork pump goes to 200 psi, and theyre designed to not let all the air seep out like a regular tire pump or chuck when you remove it. Come borrow mine, the gauge is stuck on 50psi for some reason, I'm headed to buy a new one this morn just to be sure im accurate. Albie def had a good idea on the pump.
I think the main reason to use nitrogen is it doesnt fade. So if you're out there racing lap after lap your suspension stays consistent. Playing around in the yard you guys will be fine doing whatever. As long as the shock is working properly and the rear isnt bouncing and the rebound is working (not coming up too fast) you guys will be ok. You never wana ride one with a blown shock and a "springy/bouncy" rear, as it will send you over the bars in quick order.
My SPOT
tcourdin is online now   Reply With Quote
Old 08-09-2012, 06:37 AM   #51082
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,347
Hmmm I imagine if anything regular air as opposed to N2 would make the shock STIFFER when it gets hot, not make it fade. The air is only there to create pressure in the oil reservoir. When air heats up the pressure RISES. Anyway, considering the very small volume of air used, even at the hottest temps you wouldn't see any significant rise. And remember that air is almost 80% nitrogen so only 20% of that volume is going to be effected by the heat.
Old 08-09-2012, 07:00 AM   #51083
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 16,703
the funny thing Albie, from reading on thumper talk and other places on the internets, people are saying it will explode, impale, and maim you.
its quite amusing!
How hot woul I have to heat that small volume of air at 30-50 psi to get it to pressurize that bladder higher than the 289 psi of nitrogen its designed to hold?
Im thinking 1200 degrees? haha
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake is online now   Reply With Quote
Old 08-09-2012, 09:57 AM   #51084
mouthfulloflake
Not afraid
Oddometer: 16,703
My busy work day was interrupted by a txted photo from my daughter...
Old 08-09-2012, 10:01 AM   #51085
tokyoklahoma
75%has been25%wanabe
Oddometer: 1,557
Thumb WOOOHOOoooooo
tokyoklahoma is offline   Reply With Quote
Old 08-09-2012, 10:04 AM   #51086
sc-razor
sc-razor's Avatar
Oddometer: 3,759
Hey Albie! This is on Craigslist. It matches your helmet!
2009 XR650L
2009 KTM 300XC-W
Steve
sc-razor is offline   Reply With Quote
Old 08-09-2012, 10:17 AM   #51087
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,347
Uuhhhh OK.
Old 08-09-2012, 10:23 AM   #51088
tokyoklahoma
Oddometer: 1,557
Bluhduh clutch
I think I need a new clutch pack. My bike is lurching/dieing when I first put it in gear after a cold start.
I guess I can order that when I get my upgraded fuel filters.
Old 08-09-2012, 11:21 AM   #51089
mouthfulloflake
Not afraid
Oddometer: 16,703
I think I've read about folks taking it apart
and filing the lugs on the clutch basket to fix that
like they wear an irregular notch in the supposed to be flat lug area and they can't completely release
Old 08-09-2012, 11:23 AM   #51090
crazyapple92
Oddometer: 126
Notice the guilty "Sorry pop, I opened one of your boxes" face.
Dang you for putting your kid daughter in the pic and ruining all the fun... Suddenly all the jug jokes I was going to make are a whole new level of inappropriate.
crazyapple92 is offline   Reply With Quote
Times are GMT -7.   It's 09:25 PM.
