03-03-2013, 04:55 PM
#61441 |
Not afraid
Oddometer: 11,419
remove the air filter , and spray it in the hole.
"A little inaccuracy sometimes saves a ton of explanation." - H. H. Munro (Saki) (1870-1916) |
03-03-2013, 05:12 PM
#61442 |
Oddometer: 736
03-03-2013, 05:15 PM
#61443 |
Not afraid
Oddometer: 11,419
If you are sure you got some in there... then it sounds as if you have no spark.
make sure you didnt pinch the wire going to the kill switch or anything with the seat and tank R&R also, make sure you the small wires going to the coil ( to find coil ---> follow the spark plug wire) didnt get knocked loose.
03-03-2013, 05:16 PM
#61444 |
Not afraid
Oddometer: 11,419
JT West,
the brewery is cool, I intend to return! Now, lets talk about this rabbit manure.... I want some.
03-03-2013, 05:24 PM
#61445 |
Oddometer: 736
03-03-2013, 05:29 PM
#61446 |
Oddometer: 736
getting a spark from the spark plug. Not a huge spark but a spark. not sure how big it is ment to be.
stuck |
03-03-2013, 05:32 PM
#61447 |
Discombobulated Sociopath
Oddometer: 4,108
Should be blue in color and maybe even have an audible "pop" to it. A yellow spark is weak and won't ignite the fuel/air mix.
O'Jay I'm not weird, I'm Limited Edition! Life is a sexually transmitted disease and the mortality rate is 100% |
03-03-2013, 05:39 PM
#61448 | |
Oddometer: 736
Its blue in color. But with kicking it i cant hear anything. Its not a big Spark but i can see it in the garage with the lights on. If its getting a spark it should have done something with the starter fluid right? |
03-03-2013, 05:41 PM
#61449 |
Oddometer: 4,108
Yep. You shoulda gotten at least a pop out of the motor. Does your carb have a butterfly or slide?
03-03-2013, 05:43 PM
#61450 |
Oddometer: 1,051
03-03-2013, 05:45 PM
#61451 | |
Oddometer: 736
Not sure. lol. There is one part that goes up and down then another then goes flat. I think that is where the air comes into the carb. should i give it some throatal while i spray it in there mayve? then give it a kick? stuck |
#61452 |
Oddometer: 24,189
03-03-2013, 06:03 PM
#61453 |
Oddometer: 736
sprayed more in there. tried kicking nothing did some more and nothing. Dam this bike is getting to be today. putting it away for another day.
stuck |
03-03-2013, 06:08 PM
#61454 |
Oddometer: 24,189
welcome to the world of XR4's
I went thru the same thing..am guessing you got sumthing put back together wrong in the carb..I see a tech day for you and I at the shop soon |
03-03-2013, 06:12 PM
#61455 | |
Oddometer: 736
I am sure i did. Just woundering the deal with the engine starter and a spark but not getting anything in the engine. |
