Old 04-09-2009, 06:37 PM   #16
Big Tall Bastard
Voice of Reason
Oddometer: 335
I didn't have a problem with the bolts, fit right in. The anodizing makes sense.
Current rides: 07 Aprilia Tuono R, 87 XR600R (Hell Yeah!)
Some of bikes owned in the last few years: 2007 990 Adventure ,2001 Aprilia Mille RSV, 2000 XR 650 R, plated Sold (what a dumbass) 2001 CR500R, 2001 Cagiva Gran Canyon
Big Tall Bastard is offline   Reply With Quote
Old 04-13-2009, 03:14 AM   #17
dlh62c
Oddometer: 1,603
Originally Posted by GSPD Dreamer
Pretty sure it will fit your 640. The best way to get your hands on one is to e-mail Kevin at ralleyconnex@gmail.com
Thanx
Just ordered the 2" Rally Risers using PayPal.
daryl
Old 04-13-2009, 10:21 AM   #18
rob748
resident alien !!!!
rob748's Avatar
Oddometer: 825
2''
the one thing l noticed was on the first ones it had a rectangle linking the two sides together but the one l have has the round piece linking the sides together, it allows it to twist when you go down, l had to put it in a press to get it back
rob748 is offline   Reply With Quote
Old 12-06-2011, 05:39 PM   #19
Weldit
Weldit's Avatar
Oddometer: 336
Originally Posted by barkbuster67 View Post
+1 on the 2" riser. Excellent for the tall folks.
+1 on the WTF with the 7mm hex. I haven't found one yet. Not even a torx will fit. Ended up using lots of loctite with the biggest flat blade and a wrench I could find.
just installed my rally risers and no sign of a 7 mm allen wrench in my pile of tools
was about to grind down a 8 mm a tad as no imperial was close either
then tried a torx and a 45 is a pretty good fit and good enough for the 15-20 ft-lbs torque
should be a lot better now - for standing - I'm 6'8"
my brake line is a bit tight on the radius down from master
I switched the lines in the clip on frame behind gas tank (line to lever on top now)
my bike has ABS so line goes back to ABS unit under seat
had to move throttle under bars - no room for rubber dust boot as it is to tight to switch gear now
looks like you left boot on in your picture - any trick ?
'11 Dakar 990
Weldit is offline   Reply With Quote
Old 12-06-2011, 08:24 PM   #20
Holaday OP
Man of Leisure
Holaday's Avatar
Oddometer: 591
looks like you left boot on in your picture - any trick ?[/QUOTE]
It's been so long I don't remember. I don't remember having any trouble with it. Try loosening the switch and rotating it out of the way. Then get your throttle in place. Maybe a little light grease or lube on the rubber boot and then rotate the switch back into place. Good luck.
Soon as your born you start dying, so you might as well have a good time!!!
Checkout my Ride Reports:
Baja
http://www.advrider.com/forums/showthread.php?t=405461
Kootenays
http://www.advrider.com/forums/showthread.php?t=614464
Holaday is offline   Reply With Quote
Old 12-20-2011, 03:16 PM   #21
Sumi
Sumi's Avatar
Oddometer: 1,799
Is it still possible to buy these?
Old 12-20-2011, 03:22 PM   #22
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,347
I bought a set a few months ago. I had to buy them thru Ebay.
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 12-20-2011, 04:12 PM   #23
KTMandu
Adventurer Wannabe
KTMandu's Avatar
Oddometer: 332
Sumi
Risers can still be acquired by contacting rallyconnex@gmail.com
See also www.rallyconnex.com
You may have to make contact more than once. The guy is away quite often and very busy.
14 500 XCW, 06 950 Adv, 06 400 EXC, 00 300 EXC
KTMandu is offline   Reply With Quote
Old 12-20-2011, 04:13 PM   #24
Unkgd
Oddometer: 345
Rally Connex Riser
Sumi,
Here is the website for the Dirtnblood riser - aka Rally Connex http://www.rallyconnex.com/adventure.../equipment.htm.
It took me several months to get mine (it included the Scott mounting adapter as well) and lots of emails - but it was worth it!
Unkgd is offline   Reply With Quote
Old 12-20-2011, 04:29 PM   #25
Weldit
Weldit's Avatar
Oddometer: 336
the rallyconnex website is very poor - no pictures of any stabilizer mount that you talk about
was it a custom part for you ?
I was a little unsure about a 2" riser mounted to one 10mm bolt - seems kind of undersized for this leverage
after a ridding buddy flipped his bike and sheared off the stock handlebar mount bolt on one side
after I mounted the 2"bone riser by rallyconnex I gave the handlebars a good flex test and
the bars seemed to flex long before the riser moved or the rubber mount on triple clamp moved
BUT I could see that little 10mm bolt breaking in a crash very easily
just a note - it seems all KTM's use whimpy 10mm mounting bolts - why ?
'11 Dakar 990
Old 12-20-2011, 05:10 PM   #26
Unkgd
Oddometer: 345
SNIP
Weldit,
I think it may be a "custom" part - but he has made a few of them that I know of. I found it reading this thread - http://advrider.com/forums/showthrea...ht=rally+riser . I have had it on the bike for about 10 months and it is close to perfect for me on and off road. An inch more rise would be nice - but then I would need new brake and clutch lines - and maybe throttle cables as well.
Bill
Old 12-20-2011, 08:11 PM   #27
xcflyn
xcflyn's Avatar
Oddometer: 1,157
Ill throw this in. I seen the OP's (Holaday) set up and this was a pretty sweet. I thought he mentioned they were hard to come by these days if at all ? Blair chime in if you have some thoughts on this.
xcflyn is offline   Reply With Quote
Old 12-20-2011, 08:35 PM   #28
Holaday OP
Man of Leisure
Holaday's Avatar
Oddometer: 591
Wow lots of posts on this old thread. I'm sure he is still around, just takes some patience. I'd like to learn more about this Scott's mount option. I have been slow to get a steering dampner cause I thought I'd have to give up my Dirtnblood riser. I'd like to keep it if I went to a Scott's.
Baja
Kootenays
Old 12-20-2011, 10:29 PM   #29
Masa
Masa's Avatar
Oddometer: 301
I got 2" riser couple of weeks ago. Took less than a month from the initial email contact.
Masa is offline   Reply With Quote
Old 12-20-2011, 11:03 PM   #30
Sumi
Sumi's Avatar
Oddometer: 1,799
Thank you for all of the replies! I'll try to contact him.
As for the bolt size "issue": when I got off the bike this summer when crashing into a tree, I've also bent those bolts during the process of the handlebar getting hit by my knee. In my opinion this is not a design flaw, but an advantage, as the bolt will "sacrifice" itself, absorbing some of the energy of the impact, instead of breaking your bones / bending / breaking the handlebar and/or the triples.
Times are GMT -7.   It's 06:48 AM.
