Go Back   ADVrider > Riding > Layin' down tracks > GPS Tracks - Oz and Kiwi Land
Old 04-15-2009, 07:24 PM   #16
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 7,868
There's a bit of a learning curve, but it's worth the effort. You can download shonkymaps and tracks4australia as well for free, and make them part of your mapset. the limiting factor is the number of map tiles you can have in a mapset, currently it's 2025, but I tried that number last week and got a corrupted mapset, so I went down to approx. 1960 map tiles and it works great, it generated a 1.6Gb mapset with 3 different mapsets in it, very handy!
I was mainly wondering how much the garmin topo set looks like OZTopo.
GodSilla is offline   Reply With Quote
Old 04-15-2009, 11:11 PM   #17
Micl
Oddometer: 261
Maybe we need to get together and compare, is your mapset bigger than mine
MicL
Micl is offline   Reply With Quote
Old 04-16-2009, 01:41 AM   #18
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 7,868
MicL
Probably, but it's a virtual pissing contest. Where are you in Canb?
Old 04-18-2009, 02:45 PM   #19
Micl
Oddometer: 261
I'm in Kambah, how bout you... Bit busy this week.. In the process of replacing wall in my daughters bedroom with sliding cavity doors, hopefully get it done today then need to paint next weekend. In between need to do oil change/service, install high guard kit (new break lines and bleed) and put new tyres on theKTM
If I can get it sorted then Delegate, Cancer council ride and maybe Newnes
Micl
Old 04-19-2009, 06:43 PM   #20
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 7,868
I'm in Kambah too.
Sadly I'm working for Delegate and the Cancer Council rides, a pity as I'd like to do both. I'm not sure about Newnes.
I think the routable tracks you talked about in the Brindies will all be gazetted roads, whereas the other tracks are logging roads and firetrails that aren't gazetted, and that's the difference. Most comprehensize insurance policies will cover you for gazetted roads, but not the other trails.
If you need shonky or t4a I have them here, easy to deliver on USB stick.
Old 04-20-2009, 09:01 PM   #21
FuTAnT
KTM 990ADV
FuTAnT's Avatar
Oddometer: 341
I was talking to the guys down at JA and they seemed to think that the Garmin Topo didn't include as many tracks as shonky or other equivalents. Mind you, this was only on a test section of Fraser Island, so other areas of Oz need to be tested.
Just bought a 60CSx on the weekend. Still trying to work out which will be the best map soln. I like the idea of one mapset with all the tracks that is also routable. Then again, maybe I'll just buy City Navigator for the easy stuff then setup way point and just let loose in the bush. Too many freakin options! (and they all cost $)
FuTAnT is offline   Reply With Quote
Old 04-20-2009, 09:06 PM   #22
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 4,104
Yep, Topo Australia (Garmins topo map) is a little light on on Fraser Island tracks.
Both OZtopo and Tracks4Australia have noticebly more tracks on Fraser.
Don't believe that this is a real indicator of the Topo Australia coverage as in other areas it seems reasonable
BurnieM screwed with this post 04-21-2009 at 12:25 AM
BurnieM is offline   Reply With Quote
Old 04-21-2009, 10:17 PM   #23
Micl
Oddometer: 261
I went with the Garmin Topo as I didn't want to have to buy City Explorer and OZ topo. I figured I would start with the Garmin Topo and if it sucked buy City explorer and look at shonky etc (the Garmin came with T4A on a Memory card but I havn't tried it). SO far around Canberra the GArmin Topo on the 60CS is better than my in car Navman and it seems to have lots of tracks and trails. I think bang for buck its the best option and I wouldn't bother with City Explorer. I may add some more tracks stuff though if I find it lacking but at this time I think its probably the best value for money if you are going to buy one mapset.
MicL
Old 05-02-2009, 05:11 AM   #24
regie308
regie308's Avatar
Oddometer: 1,441
i have been playing with gps's over the past 6 years and i have found the best set up "for me" is a "HTC touch crusie" load oziexplorer on it and put in all my custom maps then the inbuilt gps tells me where i am on any particular map.
load in my set wpts and route then i just follow. its just great.
regie308 is offline   Reply With Quote
Old 06-03-2009, 12:28 AM   #25
AdventureXR650
Esquire
AdventureXR650's Avatar
Oddometer: 147
Wicked eTrex Vista HCx
Got the Garmin Vista and OzTopo maps on CD. Loaded it all on PC and with a bit of routing around got it working well. Planned our Tassie trip on the PC use the mapping software and Google earth and the whole thing worked a treat. It the GPS found some dodgee little trail entrances that the eye wouldn't see. Only issue was the map said the trail was there on one occassion as did Google earth but it had closed and re-routed. Figured it out and downloaded the GPS and ws interesting to see we where right on the track but forestry Tas had changed it.
This is the ADV gathering at Delegate. The pink line is where we wanted to go and the black dotted is actual. All part of the adventure navigating...lol. The doubled up line is Saturday into Delegate (right side) and Sunday along Browns camp road to Mt Tingaringy...eventually.
AdventureXR650 screwed with this post 06-18-2009 at 08:41 PM
AdventureXR650 is offline   Reply With Quote
Old 06-12-2009, 05:41 AM   #26
KatoomDownUnder
Safer off a horse than on
KatoomDownUnder's Avatar
Oddometer: 956
Bluhduh
I went down the same route as Michl and so far after some stuffing about I have finally gotten the software to work . The supplied version of Mapsource has a fault with the wizard and needed the latest version update. As for BaseCamp I'm a bit iffy on that due to some crashing problems, but if you want to do some different angle views it'd do the job.
Thus far Garmin's software has stayed true to form and is a PITA but if you want turn by turn with topo it's the only one for Garmin GPS's (so far).
Na cnuic tha lomnochd
's tha duilleach Foghair
mar bhrat air la\r,
am fearann caillte
dan tug na seo\id ud gra\dh,
a sheas an aghaidh
feachd uailleil Iomhair
's a ruaig e dhachaigh
air chaochladh smaoin
You're not drunk if you can lie on the floor without holding on.
KatoomDownUnder is offline   Reply With Quote
Old 06-15-2009, 09:39 PM   #27
MungoP
Oddometer: 285
Difference between OZtopo and T4A
Originally Posted by BurnieM
Both OZtopo and TOPO Australia have noticably more 4WD tracks than Tracks4Australia and Shonkymaps.
OZtopo uses roads and tracks data from Map Data Sciences/PSMA
TOPO Australia uses NavTeq data
T4A and Shonky use Geoscience Australia data
Still trying to get a handle on the OZtopo and TOPO Australia differences
I'm confused (again) Burnie.
Looking at my CD cover with OZtopo on it, it says that OZtopo is a mapping product ...... comprised of two mapsets Tracks4Australia PRO and 20m Contours.
What are you referring to when you say
and
'06 CT110, '04 DRZ-250, '08 DL650 ABS, '07 DR 650 sold, '04 V-Strom 650 w/o, '00 VTR250 sold
MungoP is offline   Reply With Quote
Old 06-22-2009, 02:48 AM   #28
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 4,104
and
You have OZtopo v1. Current version is OZtopo V2.1.
Much more extensive roads and tracks in OZtopo V2.1. You can upgrade for $99.
OZtopo V3 is expected September-ish
Old 06-22-2009, 05:49 PM   #29
MungoP
Oddometer: 285
The OZtopo v1.0 CD cover says that OZtopo is comprised of two mapsets T4A PRO and 20m contours.
Therefore how can OZtopo and T4A use different data sources?
MungoP screwed with this post 06-22-2009 at 06:18 PM
Old 06-23-2009, 01:54 AM   #30
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 4,104
OZtopo v1 used the Track4Australia PRO roads and tracks layer (data from Geoscience Australia)
OZtopo v2 uses roads and tracks data from Mapdata sciences/PSMA
Times are GMT -7.   It's 12:12 PM.
