Old 04-05-2009, 10:23 PM   #1
Sonymalc OP
I'm Just Here
Sonymalc's Avatar
Oddometer: 441
X-ch OEM Engine Guard Installation. w/pics
Hey everyone. I have installed the BMW engine guards onto my x-ch.
Here is the installation instructions as described by Sonymalc (I hold no liablity) that they did not provide me with.
Do a parts inventory and find out you don't have any instructions.
Start by removing both footpegs as an assembly with there mounts. (The lower bolt on the left side holds part of the kickstand mount, If you remove this with the bike on the side stand it will stay up but you will have a very difficult, approx 5 min time figuring out why the bolt does not want to start when reassembling. This is because the bolt hole in the stand bracket is not centered up with the frame threads. You will need to hold the bike off the stand in order to start it.)
Remove the front engine to frame support bolt. It is a long bolt in the front behind the skidplate. Skid plate may have to removed to remove the bolt but I just bent it out of the way using a suitable tool to bend it. (Cresent Wrench) You will also have to cut the zip tie and work around whatever line this is in the picture. You DO NOT have to take it off.
Now that you have all the bolts removed that need to be removed you can see that the new ones are longer.
Assemble the new engine bolt in this order, bolt, washer, engine guard bracket, washer, spacer, and slide into engine.
Install on threaded side of bolt, (this should be on the right side of the motorcycle) a washer, engine guard bracket, washer and lock nut.
Now fit the engine guard bars to the footpeg brackets with the new longer bolts and loosly fit together. Dont tighten it yet.
Now install the front bar mounts the the brackets using the smaller bolts provided.
I reconmend tightening the footpeg bolts first and then the front bracket bolts.
Now you have succesfully installed engine bars in about 40 min while taking pictures to share with all your ADV riders.
It would seem that these bars will act as great lower frame hardparts like kutch made.
Here is the completed project. Sorry for some of the bad focus pictures.
"Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the present." Master Oogway
FOLLOW ME ON MY SPOT
2007 BMW G650X Challenge
2004 Husqvarna TE250 now a 310
1997 BMW R1100RT
1997 Fantic Section 250
1972 Honda SL70
1990 Honda Transalp (sold)
Dreaming of that new GS1200
Lowrance iFINDER Expedition™ C
Lowrance XOG
Sonymalc is offline   Reply With Quote
Old 04-06-2009, 03:09 AM   #2
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,229
What type of shifting lever is that?
Max Kool is offline   Reply With Quote
Old 04-06-2009, 04:57 AM   #3
MTBiker78
ENDURO Wanabee
MTBiker78's Avatar
Oddometer: 184
- my guess is - Touratech - fixed F650GS lever
Regards
Lucas
I have a new challange ..... X-Challenge ....
www.vimeo.com/mtbiker
http://picasaweb.google.com/lukasz.lechowicz/XChallenge
MTBiker78 is offline   Reply With Quote
Old 04-06-2009, 05:04 AM   #4
Max Kool
Xtankteam™
Max Kool's Avatar
Oddometer: 3,229
I thought the TT shift lever had the bolt the other way around. (but not sure either).
Old 04-06-2009, 07:41 AM   #5
Sonymalc OP
I'm Just Here
Sonymalc's Avatar
Oddometer: 441
It is the TT lever.
1997 BMW R1100RT
1972 Honda SL70
Lowrance XOG
Old 05-19-2009, 08:04 PM   #6
fazer6
fazer6's Avatar
Oddometer: 286
Compatible w/ H-B bars?
It looks like these would fit in tandem with the Hepco Becker crash bars?
fazer6 is offline   Reply With Quote
Old 05-19-2009, 10:26 PM   #7
plumber mike
Highdive Deepened
plumber mike's Avatar
Oddometer: 3,372
Would you have a link to where you got them? I looked on the BMW Motorrad USA site and was unable to locate them. I assume they will work on the country as well. Thanks for the pics.
plumber mike is offline   Reply With Quote
Old 05-20-2009, 02:21 AM   #8
Sonymalc OP
I'm Just Here
Sonymalc's Avatar
Oddometer: 441
http://www.maxbmwmotorcycles.com/fic...p?mospid=50282
The part number for the factory guards is 71607706067
1997 BMW R1100RT
1972 Honda SL70
Lowrance XOG
Times are GMT -7.   It's 03:39 AM.
