Old 04-06-2009, 08:45 PM   #1
KLRThumper OP
Oddometer: 31
KLR 650 Fan Problems
I just got back from a 2000 mile trip to San Fransisco and as soon as I started riding in the city back here in Seattle I started having problems with my bike overheating. It takes all of 10 minutes in downtown stop and go before it hits the red bar and I have to pull over.
Problems
-The fan does not seem to run
-When I turn the bike off the fan does not run
- I smell a faint rubber smell
I have checked the fan to make sure it does spin freely when i push it with my finger.
Has anyone had a problem like this before or know of anything that I could try to isolate the problem. Thanks
KLRThumper is offline   Reply With Quote
Old 04-06-2009, 09:16 PM   #2
faceman
currently ADV-less..
faceman's Avatar
Oddometer: 161
guessing,...could be blown fuse,...broken wire,..bad temp sensor...
bad ground...unplugged...when was the last time you heard it run?
worst case bad fan motor. Try jumping diectly to the battery to
see if it runs, but make sure you get the right wire to positive.
If it does work,...use a volt/ohm meter to trace and check the wiring
harness.
'86 VFR 750 R/W/B
95 KLR650 - '02 KTM 640 Adventure R,... Gone, but not forgotten
faceman is offline   Reply With Quote
Old 04-06-2009, 09:32 PM   #3
Durden
Freak!
Durden's Avatar
Oddometer: 477
Replace the fuse, if thats not the issue let me know where I can mail my $20 to....
Either that, or just make sure you are always driving really freaking fast.
Durden is offline   Reply With Quote
Old 04-06-2009, 09:52 PM   #4
faceman
faceman's Avatar
Oddometer: 161
Just looked over the CD/manual,.. could also be the fan relay(under the tank,
to the right of the main frame) between the frame and overflow tank.
White wire, 20 amp fuse, supplies (+) power to relay. From the relay, Red/White goes to the
Temp sensor on the radiator,..Blue supplies power to the fan motor and Black/Yellow "from" the
fan motor is (-) ground.
'86 VFR 750 R/W/B
faceman screwed with this post 04-06-2009 at 10:05 PM
Old 04-06-2009, 09:52 PM   #5
caborado
Posing as a n00b
caborado's Avatar
Oddometer: 187
Survey sez.....
my money is on the fuse....
been there, replaced that...
carry spare fuses...
....wait there should be one in the fuse holder....
Let us know
Once in a blue moon the thermo sensor will poop out....
http://klrworld.com/forums/
http://www.apriliaforum.com/forums/
Somewhere between the tire rolling across the ground and the smile on my face there is a throttle twisting in my hand~Cabo
caborado is offline   Reply With Quote
Old 04-06-2009, 09:55 PM   #6
guns_equal_freedom
Oddometer: 5,594
Check the fuse.
If the fuse is good then do this quick trouble shooting check.
Pull the wire off of the fan switch lead.
The fan switch is located on the bottom of the radiator.
Get a 6-8 inch piece of electrical wire (your choice of gauge), strip the ends, put one end in the fan switch lead and ground the other end.
It does not matter if the ignition switch is on or off, the fan should run.
If the fan does not run then your next step is to check the fan relay.
If the fan runs then you have a problem with the fan switch.
guns_equal_freedom is offline   Reply With Quote
Old 04-07-2009, 12:37 PM   #7
KLRThumper OP
Oddometer: 31
Originally Posted by guns_equal_freedom
Check the fuse.
Ok so I checked the fuse and it was not blown. So I tried grounding the fan switch lead and still got nothing... Anything else I can try?
Old 04-07-2009, 12:43 PM   #8
KLRThumper OP
Oddometer: 31
How do you check the fan relay?
Old 04-07-2009, 01:50 PM   #9
guns_equal_freedom
Oddometer: 5,594
You need to buy a factory service manual.
The easy way is to pull the relay from the sidestand safety switch and swap it with the fan switch relay.
The fan switch relay is round and on the metal support of the coolant tank.
The sidestand safety switch is under the plastic cover near the battery.
Then try grounding the fan switch lead to bare metal and see if it works.
One other thing is to power the fan from the battery, run leads from the battery to the fan, make the contact with the ground and see if the fan runs.
The fan circuit is pretty basic -
It's either the fuse, relay, fan switch or a wiring problem.
Old 04-07-2009, 02:18 PM   #10
KLRThumper OP
Oddometer: 31
Is the relay under the gas tank?
Old 04-07-2009, 03:28 PM   #11
guns_equal_freedom
Oddometer: 5,594
Yes.........
The other one is under the seat.
Buy a factory service manual already.....
Old 04-07-2009, 06:42 PM   #12
KLRThumper OP
Oddometer: 31
I know. Where would you suggest I pick one up at?
Is there an electronic one i can buy right now?
Old 04-07-2009, 07:14 PM   #13
guns_equal_freedom
Oddometer: 5,594
Kawasaki
http://tinyurl.com/dbb5s5
Old 04-07-2009, 07:22 PM   #14
guns_equal_freedom
Oddometer: 5,594
Old 04-07-2009, 07:37 PM   #15
yosmitetom
Oddometer: 3,354
Fan relay us near the fuse, right under tank. The sidestand/safety relay is identical under cover on left side near battery. Advance Auto has a replacement relay . . . maybe:
Manufacturer - GP Sorenson
Number on Box - 41-5002
Other Part Number - R3054Z
Cost - $12.98
Por nada.
yosmitetom is offline   Reply With Quote
Times are GMT -7.   It's 03:53 PM.
