Old 04-09-2009, 12:49 PM   #16
BMWHillbilly
Oddometer: 118
Hey KLRscoob, would you mind posting pics of front view and side view please? I'd appreciate it!
BMWHillbilly is offline   Reply With Quote
Old 04-09-2009, 02:14 PM   #17
MonsterJ
I have motopsychosis
Oddometer: 262
Originally Posted by The Griz
Shit, man, anyone could make those KLRscoob. A trip to Home Depot for shatterproof Plexiglass, some brackets, a couple of spacers, washers, bolts, DONE! The only things he's doing is cutting the Plexiglass and bending the brackets. I'm betting those brackets are intended for something else. I'm going to make my own this weekend. And I won't spend $65 thats for sure!
The Griz (click)
The sorry profile of: The Griz (Hmmmm.... where's that button? Oh. There it is...)
Ignore The Griz (click)
Ahhhh.... that's better.
-Nooner
Temple, TX -> Cape May, NJ -> Mobile, AL -> ECity, NC -> Kodiak, AK -> Mobile, AL -> Sacto, CA -> Cape Cod, MA -> New London, CT -> San Francisco, CA -> Juneau, AK (summer of '13) -> where to next?
MonsterJ is offline   Reply With Quote
Old 04-09-2009, 03:59 PM   #18
KLRscoob OP
KLRscoob's Avatar
Oddometer: 197
if you go to the picture link on my first posting there is a bunch of pictures in my Photobucket account. if that does not work let me know. I cannot seem to figure out how to post up pictures.
thanks
KLRscoob is offline   Reply With Quote
Old 04-10-2009, 08:18 AM   #19
BMWHillbilly
Oddometer: 118
That worked but still would like to see a pic of a straight on view from the front if possible. Your pics are from the top looking down for the most part. Sorry if I seem so picky....I'm just trying to get an idea the size, etc. thanks!
Old 04-25-2009, 03:07 PM   #20
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
So I finally fabricated my own headlight guard:
Took me about an hour, if that. Total cost of materials: $17. Home Depot.
The brackets are made from a 3 foot piece of flat aluminum. I cut, grinded, bent, and drilled em. The protector is a clear piece of 11"x14" Lexan cut to size and shape, then drilled holes in it to mount it.
I went with a thinner Lexan, so that if the guard gets struck, the Lexan will give or bend. Therefore not transferring as much of the force the the headlight enclosure via the brackets.
The Griz screwed with this post 04-25-2009 at 04:18 PM
Old 04-25-2009, 06:03 PM   #21
761
761's Avatar
Oddometer: 343
Good job Griz
761 is offline   Reply With Quote
Old 04-25-2009, 07:38 PM   #22
KLRscoob OP
KLRscoob's Avatar
Oddometer: 197
Looks Great Griz! Be careful using Lexan, it will shatter very easily. Try and locate a piece of polycarbonate. I have worked with plastics for a while and without the right stuff it will be easily shattered, last time I looked I could not find poly at my local homedepot. If you cannot find any locally try RIDOUT plastics in san diego, they should be able to send you some.
-Jason
Old 04-25-2009, 07:58 PM   #23
backroadsandbeyond
backroadsandbeyond's Avatar
Oddometer: 84
hey Griz, you may find that the sharp inner corner will form a crack. Its a typical stress spot. Round it out
live life today
backroadsandbeyond is offline   Reply With Quote
Old 04-25-2009, 08:29 PM   #24
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Thanks, guys! I'll check into Polycarbonate instead. I think I'm getting a crack already. Right where it's bolted on. Oh well. Trial and error, right?
Old 04-26-2009, 03:48 AM   #25
LILGS
LILGS's Avatar
Oddometer: 192
Hey Griz,
you will also need more support in the centre of the guard, it will be too flimsy. a few good gravel roads would shake that to bits..
it needs more support and use rubber where it mounts to the future polycarbonate so the vibrations can get dampened. the headlights are bad enough on their own..
LILGS is offline   Reply With Quote
Old 04-26-2009, 02:06 PM   #26
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
So I made some changes. Did some research. The Plexiglass (a.k.a. Acrylic - 20 times stronger than glass) I was using before wasn't strong enough. It started cracking where I had it fastened to the brackets from the pressure. So, I switched to Lexan (a.k.a. Polycarbonate - 120 times stronger than glass). It is way stronger than the acrylic I was using. I attached it with rubber washers as well.
I also did some tests on a spare piece of Lexan with rocks and chunks of metal and things. I was throwing 1" rocks and pieces of scrap mild steel at it as hard as I could. Couldn't break it!
Old 04-26-2009, 06:35 PM   #27
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 817
Stand back 10 feet, put a marble in a Wrist Rocket, pull back and let it rip. Let us know what happens. Wear a helmet and some thick clothes...the Lexan might just send the marble right back at you
I'd like to see this test on all the guards.
Bucko is offline   Reply With Quote
Old 04-26-2009, 08:21 PM   #28
Gany
Oddometer: 366
I just got a local Aussie manufacturer to make me up a velcro on set similar to the Cee bailee headlight guard. Difference being he makes his from Polycarbonate. His ebay ad has a link to some interesting youtube video demonstrations between polycarbonate and acrylic:
http://youtube.com/watch?v=Hsls5ZPCUnE
The guy trades under the ebay name of Peppershield_headlight_covers (http://myworld.ebay.com.au/peppershi...dlight_covers/), now has an F800GS template. I will put some photos up as soon as I fit them on the bike. If he gets enough requests he may consider making more.
Gany is offline   Reply With Quote
Old 04-26-2009, 08:49 PM   #29
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 817
Point taken. A few times.
Old 04-26-2009, 11:07 PM   #30
LILGS
LILGS's Avatar
Oddometer: 192
Griz,
ya need to round of the edges, it just doesnt look right on the HB side. what stops the guard from vibrating down and end up loosening the head light bolts? does it rest on the beak i can't see it clearly enough, this looks like a problem otherwise it will rub on the beak.
LILGS screwed with this post 04-26-2009 at 11:13 PM
Times are GMT -7.   It's 07:22 AM.
