Old 04-10-2009, 08:02 PM   #1
CYPKCntrl OP
CYPKCntrl's Avatar
Oddometer: 13
F800GS Dirty Brake Fluid
Just had a quick look at the fluid in my rear brake reservoir on my F800GS, and it is absolutely filthy! The bike has less than 2000 km on it, 90% on the street, and I've never touched the reservoir. Anyone have any ideas why this would occur?
CYPKCntrl is offline   Reply With Quote
Old 04-10-2009, 08:20 PM   #2
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
I'm not sure what you mean by absolutely filthy. But if it's just turned dark brown, it's perfectly normal.
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 04-10-2009, 09:23 PM   #3
CYPKCntrl OP
CYPKCntrl's Avatar
Oddometer: 13
Dark brown is normal? I honestly thought that it meant contamination. After a little more research, I'm finding out that the colour doesn't really mean much. Thanks David.
Old 04-10-2009, 09:51 PM   #4
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
No sweat, CTPKCntrl. And don't worry, there will be plenty of other things to go wrong with your bike. Hopefully, none of them too serious.
David
David
--Curly
Old 04-11-2009, 06:04 AM   #5
JRWooden
Oddometer: 4,267
brake fluid color
David:
I'm not in a panic, but I am surprised that ONLY the rear fluid is changing color and doing it rather quickly....
My front reservoir is same color as it was when I picked up the bike last August, but rear was very dark. Just for grins I sucked out all the fluid in the rear and replaced it with fresh stuff.
After only a few 100 miles the rear reservoir was pretty dark again....
Kinda weird.............
I have ABS, while I think CYPK does not.............
JRWooden is online now   Reply With Quote
Old 04-11-2009, 06:31 AM   #6
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Originally Posted by JRWooden
David:
My hunch, and it is only that, is that there's considerably less fluid in the rear brake system (one rotor vs. two, shorter brake line, smaller reservoir). So it darkens faster than the front. It's heat, not contamination. The fluid in my front reservoir is a lighter color than the rear, but it's definitely darker than when I picked up the bike 6000 miles ago. If you guys are worried that the color in the rear reservoir is unusually dark, you may want to check with your dealer. But if contaminants were getting in there, I'd think you'd probably also notice some seepage or other evidence of a leak somewhere in your system.
David
David
--Curly
Old 04-11-2009, 07:47 AM   #7
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,686
Brake fluid
On my 1150 the rear fluid always got dirty much quicker. Never seemed to matter.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 04-11-2009, 09:47 AM   #8
CYPKCntrl OP
CYPKCntrl's Avatar
Oddometer: 13
David:
I do have ABS as well. Also, I just talked to my dealer, and their opinion was the same as on this board - it's caused by heat and should be no issue. However, on their recommendation, I'll still bring it in for a quick inspection.
Interestingly, I have the rear suspension set up a little stiffer, which tends to cause the rear ABS to engage a lot more when I brake aggressively.
Old 04-11-2009, 04:19 PM   #9
JRWooden
Oddometer: 4,267
Weird let me know what the dealer says...
As David points out, it is smaller, closer to the ABS unit, etc.
I have the F658GS, so single front disk, but the reservoir is considerably farther from the "action" than the rear is ....
Jim
Old 08-07-2009, 09:00 PM   #10
Bike4Fun
Smooth IS Fast
Bike4Fun's Avatar
Oddometer: 1,782
So, I road over a mountain pass this weekend and going down (12 miles) the rear brake was at 85%+... Washing the bike today I noticed the fluid to be almost syrup color! Ok, so its all from heat and its no big deal, I don't feel any fade etc etc...
My question is about whether there is an fluid out there that won't discolor so quick and maybe better? Wow, I just opened the can of worms.
So on top of that, I don't see a quick bleed valve. Anybody installed one. Would it really take that long to run new fluid through?
Bike4Fun is offline   Reply With Quote
Old 08-08-2009, 04:54 AM   #11
JRWooden
Oddometer: 4,267
Joel:
I had not seen that tool .... looks interesting.
Only on the ABS equipted bikes (as I understand it) there is a 3rd bleeder screw up on the handlebars at the front brake master cylinder. I guess they were worried about an air bubble?
I know some of the older BMW ABS systems had a couple of bleeder screws on the ABS controller unit its self, but that does not seem to be the case on these bikes???
Just trying to make this all make sense .... any comments appreciated!
Old 08-08-2009, 10:15 AM   #12
Navaho
Navaho's Avatar
Oddometer: 1,042
It's the plastic that makes it looks dark. Take the cap off an look inside. You'll notice that the fluid is not as dark as it appears looking from the outside.
'07 450EXC, '06 950 Supermoto, '09 YZ450F
Navaho is offline   Reply With Quote
Old 08-08-2009, 10:28 AM   #13
Bike4Fun
Smooth IS Fast
Bike4Fun's Avatar
Oddometer: 1,782
so the plastic in the front is different than the plastic in the rear?? Sorry try again! my front is not discolored!
Old 12-13-2009, 09:54 PM   #14
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,409
You got a brake line or seal falling apart and contaminating the fluid. The fluid should never be brown. Maybe slightly yellow but not brown.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 12-14-2009, 10:49 AM   #15
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,679
Bleeding a rear brake, or replacing the fluid, takes no special tools save a wrench the correct size to twist open the bleed nipple, and a length of tubing to attach to the nipple. You do not need any fancy bleeders to do the work for you. The lever is low and on the right side of the bike, easily operated with your right hand, while your left hand operates the wrench to open and close the bleed nipple. Don't overthink this, just change the fluid.
Times are GMT -7.   It's 03:04 AM.
