Old 09-11-2010, 03:13 AM   #31
mikegc
mikegc's Avatar
Oddometer: 1,666
2009 R1200GS ADV clutch failure
Originally Posted by vincentone
I went ahead and finished the 3,000 mile trip by having to stop about every two hours to bleed the air out of the system and top off the reservoir. The system has no signs of leakage. I am now back in Houston and have called my dealer again and once more they tell me they have never heard of such a problem, but to bring it in and have "patience with them" until they can duplicate the problem. They say that they will not go forward on the basis of what may be written by experienced riders in ADVrider, but must diagnose the problem themselves. It is surprising BMW has not got a bulletin out on this problem; with all off the reported failures as seen on this thread alone. The problem is not only a nuisance to riders, but in certain circumstances it can create an acute safety issue.
Vincetone,
Although this is a known issue, some shops haven't actually seen the problem. My '09 did the same thing. BMW put the wrong mineral oil in my bike so my dealer changed the master cylinder, slave cylinder and the hydraulic lines. With that done, they still bled the system five or six times before getting all the air out.
Make sure the dealership has done the brake line recall (just a repositioning of the line) and replaces the mineral oil. I think there is a bulletin out about the slave cylinder on the '09s. I'm going by my dealership today and will check.
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 09-11-2010, 07:10 AM   #32
vincentone
Vincentone
Oddometer: 3
Clutch Failure
Originally Posted by mikegc
Vincetone,
Mike
Thanks Mike, my dealer did reposition the hydraulic line during the time of the first recommended service. I will be very interested to learn if there is a bulletin out on the 09 slave cylinder. I was surprised to see so many riders of the 09's had experienced the problem and then two prominent dealers; one in Kansas City and the other in Houston reported they had not heard of any problems. Do you know anymore about the correct mineral oil? The mineral oil can be purchased from a BMW dealer with the BMW logo on the bottle, but from your report it seems it may not be the correct fluid.
Thanks, John
vincentone is offline   Reply With Quote
Old 09-11-2010, 01:56 PM   #33
mikegc
mikegc's Avatar
Oddometer: 1,666
Thanks, John
John,
I was at Carolina Euro today and they were swamped. The service manager said, "Sure there was a bulletin on the slaves and the mineral oil." but he didn't look it up. My original fluid was clear and was replaced with a red-colored oil. If you look at the new bikes on the dealers floors, you'll see red oil. I was in Death Valley when I noticed the clutch getting a little "wimpy." The next day, it was pretty cool when I left and it was okay until I got to Phoenix and it started feeling soft again. By the time I got to Tucson that afternoon, I could pull it about half way in before I felt pressure. The next, it was still wimpy feeling and finally lost all pressure about 100 miles west of Las Cruses. I made it to El Paso and shut 'er down. By the time I got back to North Carolina three days later (bike in a trailer) the pressure was up a little but it was very evident something was wrong. I had called my dealer about the problem when I was en route from Texas and he had all the parts when I got there. After the repair, I've had no problems.
Mike
IBA 25881
Old 10-01-2010, 05:06 AM   #34
Woundflatout
Woundflatout's Avatar
Oddometer: 499
Again!!!
I had my clutch slave go out on my 2006 HP2 at 4800 miles. Replaced it on my own as the nearest reputable dealer is over 3 hours one way. It lasted exactly another 4000 miles. WTF?!! I made sure the clutch was bled properly by using a mighty vac multiple times.
I used BMW hydraulic mineral oil. In the bottle I have, the fluid is dark blueish black looking. Have they changed it again?
This is getting a little old. Two clutch slave in 8800 miles? Personally, I'd kill to have a cable actuated clutch at this point.
Does anyone know if there is a quality aftermarket slave available for the R1200? I checked Evoluzione, but they only list one for the K12 / K13.
Cheers,
Jason
Jason Slutsky
PROUD TO BE RIFF RAFF
'09 Husaberg FE570
Rallymoto #159
Woundflatout is offline   Reply With Quote
Old 10-01-2010, 06:55 AM   #35
Bin Ridin
Oddometer: 62
hose routing
Hi,
I think the problem is the hose sweeps lower than the slave cyl and vibrates where tied to the frame. IIRC, I read that this creates small bubbles in the oil. Re-routing cures this.
Bin
Bin Ridin is offline   Reply With Quote
Old 03-31-2013, 12:00 PM   #36
BeachMoto
BeachMoto's Avatar
Oddometer: 682
Wanted to bring this discussion back up to the top.
Rode out to Savannah, GA last Thursday and back on Friday from Va. Beach. It is right around 1000 miles round trip.
When I left the temps were in low 30s with light snow for the first 200 or so miles, then it warmed up to around 40. The trip back was a little warmer (low 40s). Didn't have any issues with the clutch on the way down but on the way back (around 350 miles from home), I noticed the clutch acting "weak", once I pumped it a few times, the pressure would build up and everything was back to normal.
I had this problem two years ago while riding across Texas and Oklahoma in July (temps well above 100), and I attributed it to the heat and air in the clutch hydraulic system (did the lean the bike to the right and pump the clutch trick to get the air out). Once I got around to the cooler leg of my trip (Idaho, Montana, etc.) didn't have any issues. Had the bike checked out when I got home and I was told everything was normal. Can't blame the heat for the latest episode. Didn't see any leaks by the slave cylinder back then or this past week. The fluid level is still normal (it is the red kind).
I will be leaving in June on a 12K mile 30 days trip, I am thinking about having the clutch slave cylinder replaced so I don't have to worry about it. How hard is it to DIY and what am I looking at $$ wise?
The bike is an '09 GS with 39K miles on it, BTW.
Grazie!
1970 Honda SL100 (my 1st bike in 1972)
1972 Yamaha Enduro 360 (loved this bike)
1977 Yamaha RD 250
1978 Suzuki 250TS
1982 Kawasaki GPZ 550
2007 BMW F800ST
2009 BMW R1200GS (Current)
BeachMoto is offline   Reply With Quote
Old 04-02-2013, 09:01 PM   #37
BeachMoto
BeachMoto's Avatar
Oddometer: 682
Anyone??
1977 Yamaha RD 250
1978 Suzuki 250TS
2007 BMW F800ST
Old 04-03-2013, 02:47 AM   #38
mikegc
mikegc's Avatar
Oddometer: 1,666
Bin Ridin made a good comment. Not long after I got my '09 GSA, there was a service bulletin about re-routing the clutch slave line. I believe they basically replaced a zip tie installed at the factory. I had the mod done and rode the then-new machine to California (from NC). On the return trip, my clutch lever had a mushy feel and finally gave up near El Paso. Short story even shorter, someone in Germany had put the wrong fluid in the clutch resevoir. I had to have the entire system replaced.
Since then, everything has been fine but I do have it flushed out periodically. If I were preparing for a nice long trip like you are (you dog!), I'd sure get it checked. It may just need to be flushed.
Mike
IBA 25881
Times are GMT -7.   It's 01:26 PM.
