Old 04-13-2009, 07:57 AM   #1
Nevadan OP
Not from Las Vegas
Oddometer: 23
xr600r valve clearances
I recently got a 91 xr600r that needed a new rocker cover gasket. Saturday I replaced that but when I went to adjust the exhaust valve clearances the Haynes manual I have for it gave the clearances as 0.21mm(.005") now this does not mesh as .20mm is .008" and .005" is .13mm so my question is what is the correct clearance?
For the sake of being thorough what is the clearance for the Intake as well. The manual says 0.10mm(.004"), these two numbers mesh but are they correct?
Nevadan is offline   Reply With Quote
Old 04-13-2009, 10:21 AM   #2
mcma111
mcma111's Avatar
Oddometer: 12,254
Valve Adjustment Specs
Per the factory manual:
Intake = .004"
Exhaust = .005"
Now when you go to adjust the valves you need to rotate the engine counter-clock wise until you hear a loud CLICK. This will be the decompressor assembly on the cam disengaging. If you don't do this the engine will have a loud click at the right exhaust valve and when you go to recheck it it will be very loose.
So after the click find TDC through the window on the stator cover and adjust the valves.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-13-2009, 10:37 AM   #3
Nevadan OP
Not from Las Vegas
Oddometer: 23
How does the decompresion work off of the cam? I didn't look very hard at the cover when I had it off but I can't seem to picture it.
I had the decompresion cable disconnected when I adjusted the valves so that part was not engaged.
Old 04-13-2009, 12:49 PM   #4
mcma111
mcma111's Avatar
Oddometer: 12,254
Decompressor
The Honda decompressor assy. is on the cam, behind the cam drive gear. Self contained. The handle bar lever just push's open the right exhaust valve to let the engine get over TDC.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-15-2009, 08:20 AM   #5
Nevadan OP
Not from Las Vegas
Oddometer: 23
Thanks I will have to look at that first chance I get.
Times are GMT -7.   It's 02:55 AM.
