Old 04-13-2009, 08:05 AM   #1
James Adams OP
A few crayons short.
James Adams's Avatar
Oddometer: 10,260
Duro HF-904
Does anyone have experience with this tire (Duro HF-904)? It comes in a 130/90-16 size, which will fit the back of my Nighthawk (and also the pre-'08 Ninja 250s) and claims to have a 50/50 tread.
505 XC-F DUKE 690
James Adams is online now   Reply With Quote
Old 04-13-2009, 09:05 AM   #2
30Bones
30Bones's Avatar
Oddometer: 4,652
I ran them on my KLR once. I think just a rear IIRC. Watch the tread blocks at the base. I am not the only one that had this happen and the KLR is no powerhouse. Unsure what it had for miles on it in this pic, but I changed it out soon after I noticed it cracking, as it got worse
30Bones is online now   Reply With Quote
Old 04-13-2009, 12:37 PM   #3
threadkiller
Semi-feral Pappy
threadkiller's Avatar
Oddometer: 1,795
I run two sets on my KLR. No problems at all with cracking. Traction on pavement is great, wet or dry. Gravel and dirt traction is good. Forget trying to ride in mud.
threadkiller is offline   Reply With Quote
Old 04-13-2009, 12:39 PM   #4
niceviewbehindbars
out enjoying the vu
niceviewbehindbars's Avatar
Oddometer: 1,392
What kind of mileage did you get out of them??
Graham
06 BMW R1200GS
"The human spirit needs places where nature has not been rearranged by the hand of man." -Unknown
niceviewbehindbars is offline   Reply With Quote
Old 04-13-2009, 12:48 PM   #5
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,766
I ran them for ~6000 miles on my KLR, 5300 of that was the Continental Divide Ride. Lots of this ride was heavily loaded at speed on pavement, no chunking issues. Agree about the mud though
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 04-13-2009, 01:42 PM   #6
threadkiller
Semi-feral Pappy
Oddometer: 1,795
I changed them at 4500 miles. They still had good tread but they were getting squared off. I could've milked another 1500-2000 easily.
Old 04-15-2009, 07:25 AM   #7
markk53
jack of all trades...
markk53's Avatar
Oddometer: 9,030
25,000+ miles on Duros without any problems. I ride hard supermoto type play days on back roads and also dual sporting on dirt/gravel with occasional muddy trails, I will always try to avoid mud - I hate getting wet and there are no "good" dual sport tires for mud short of DOT knobbies. I change them out at about 4000 miles just due to the way they start to handle - traction on loose surfaces is starting to go away and the transition from the flat center tread to the round outside tread gets a bit more noticable than I care for. If I got in a bind for money I could probably sqeeze 6000 or more out of them before the center is actually smooth. I also replace the front at the same time, it checked and it won't go two rear tires and still perform decently (I tried, it was nearly bald at about 8000).
The tread design is what sold me. They use a cross tread web between blocks to stiffen the tire reaction in turns, but the open tread around the circumference is deeper and sort of gives more of a paddle effect. It's not easy, but you can see it in the pictures. The tread is shallower between blocks side to side, but deeper between blocks around the circumference.
I could afford more expensive tires, but it wouldn't be worth the expense. At about $100 I can buy a pair of Duros for the cost of one tire from the "name" brands.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 04-15-2009, 07:45 AM   #8
30Bones
30Bones's Avatar
Oddometer: 4,652
I would have given the Duro another shot, but the rears are too narrow for their 18" wheel. Going to try Kenda 270's again. used to run them on the KLR also and liked them too
Old 04-15-2009, 03:54 PM   #9
markk53
markk53's Avatar
Oddometer: 9,030
That is about the point where I've taken them off and put on a new set due to traction and cornering issues caused by the flattened center.
The cracking looks very much like the proverbial "dry rot", the standard cracking that will occur caused by ozone, sun light, being around electric motors or other things that put out ozone. I see that sort of cracking starting on the front as well, and not just on Duros.
Mark - klx678
Old 04-15-2009, 06:44 PM   #10
30Bones
30Bones's Avatar
Oddometer: 4,652
I ride enough, tires are changed every 6-8 months, so unless it was OOOODL before I got it, I doubt that was the case. Garaged and in covered parking during that time frame in life. lol
Old 04-17-2009, 03:33 PM   #11
markk53
markk53's Avatar
Oddometer: 9,030
Mine will start to look like that within about a year, definitely by the time I get 4000 or so miles regardless of time. As long as the tire cords don't show it isn't a big issue. You would keep an eye on them though, just to be safe.
Duro may not be using a lot of preservative in the compound. I know Bridgestone used to have a bunch of preservative, it was that kind of greenish coloring you'd see on the sidewalls of some of the old OEM tires on Japanese bikes.
Mark - klx678
Old 04-17-2009, 09:44 PM   #12
klrbaer
Tim
klrbaer's Avatar
Oddometer: 282
904's
I'm on the 4th set of 904's. About 6000 miles per set. all surfaces and speeds. they kind of suck in the mud. great otherwise.
They do crack, but I just ride it harder.
Tim
Firefighter/EMT
If you can read this, thank a TEACHER. If you're reading this in ENGLISH, thank a SOLDIER.
God Bless us all.
88 NX 125, 99 Valkyrie, 02 KLR
Pulling my homebuilt monowheel
klrbaer is offline   Reply With Quote
Old 05-11-2009, 11:12 AM   #13
KLR PILGRIM
SICK ASS ADVENTURE RIDER.
KLR PILGRIM's Avatar
Oddometer: 863
So if I go with the Duro hf 904 how wide can I go on the KLR?
I'm new at this so is the 904 the size?
Scottland McFowl. U.S.M.C. Ret.
2009 KLR650 BIG BAD AND BLUE!!!!!!!
ADVENTURE RIDER
2009KLR650,Blue
2007KLR650 Red Sold
1975XL350 sold
2007 pontoon boat
2007 Gun Dog,
KLR PILGRIM is offline   Reply With Quote
Old 05-11-2009, 11:26 AM   #14
30Bones
30Bones's Avatar
Oddometer: 4,652
Duro's in inches? (I forget). Just break it down to metric and you'll have your answer for what will fit the KLR.
Old 05-11-2009, 12:59 PM   #15
threadkiller
Semi-feral Pappy
Oddometer: 1,795
The rear on a KLR is 130/80-17 for the Duro 904. The 903 is 90/90-21. I have a set on order from American Moto Tire.
Times are GMT -7.   It's 07:24 PM.
