Old 12-02-2009, 12:43 PM   #76
*kartman* OP
GO Bacon GO !
*kartman*'s Avatar
Oddometer: 442
And another update ;)
Checked and cleaned the parts
I also mounted a new (used) front rack, because there was a weld broken at mine...
Then I build in the motor
There were a few little problems ...
The srew from the oil line in the front of the engine knocked against the frame and therefore I could get it in the right position.
But after some filing this wasnīt a problem any more ^^
All pipes are built on, coolant and engine oil is in...
Vacuum connection for the fuel pump and temperature switch for the warning light are also fitted.
Filling and venting the clutch
Built on some parts
This is how it acutally looks...
Installed a new jet needle
The next thing I want to do is buying an Akrapovic full exhaust system
I also noticed that the Magura clutch armature doenīt fit with the old light / indicator switch - Iīm going to buy a CEV switch, which is a lot smaller...
*kartman* is offline   Reply With Quote
Old 12-02-2009, 01:12 PM   #77
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,617
You are doing what I want but the 660 wasnt sold here in numbers so I am buildin a 660 from parts.. I had a question do you know why they used a different stator setup on the 660 sm and did the cdi plug match up?? and Im dying to know if that front oil line you grinded has a jet inside or just a threaded hole near the bearing?? and finally one of the oil pumps look unavaible in the US pn .. 585380070000 Oil pump mikuni 185 660 99. is it avail in europe??
looks great .. dont forget the new shock and fork oil !!!
wrk2surf is online now   Reply With Quote
Old 12-02-2009, 01:33 PM   #78
*kartman* OP
GO Bacon GO !
*kartman*'s Avatar
Oddometer: 442
I donīt know why they used another stator setup... Iīd like to use the Kokusan from the old adenture engine, but it wonīt fit
The crankshaft is a bit different ...
The front oil line ends in a jet inside which lubricates the piston pin.
I checked the part number (yours has one "0" to much at the end) - itīs available here in Germany for about 75 Euros
Old 12-02-2009, 01:34 PM   #79
earthroamer
Stuck in Pindadesh
earthroamer's Avatar
Oddometer: 2,045
Originally Posted by *kartman*
And also a new video... look at about 50 seconds, where I almost went down
No, you almost went off a CLIFF!!
Quit doing that or I'll tell your mother.
Jim
06 F650GS
I wanna ride
earthroamer is offline   Reply With Quote
Old 12-02-2009, 01:38 PM   #80
wrk2surf
wrk2surf's Avatar
Oddometer: 6,617
that explains the different crank bearing on the left case! and do the CDI connectors hook up... same connector??
Old 12-02-2009, 01:43 PM   #81
*kartman* OP
GO Bacon GO !
*kartman*'s Avatar
Oddometer: 442
Oh sorry.... The connectors arenīt the same, you need the 660 CDI
Old 12-02-2009, 02:06 PM   #82
makazica
makazica's Avatar
Oddometer: 746
Additional fuel filter....just what I heard:
Filters for diesel engines are a better choice because at more than half throttle gasoline filters don't have enough flow.....
Can anyone can confirm this??
@kartman: sweet engine, get some usd forks....
makazica is offline   Reply With Quote
Old 12-02-2009, 02:30 PM   #83
wrk2surf
wrk2surf's Avatar
Oddometer: 6,617
no.. I know that.. does the adventure plug mate to the 660sm cdi??? im either getting the 660 rallye or smc cdi.. the rally looks like a fit
wrk2surf screwed with this post 12-03-2009 at 12:12 AM
Old 12-02-2009, 02:31 PM   #84
wrk2surf
wrk2surf's Avatar
Oddometer: 6,617
those 50s are some of the best forks ever made... also less chance of leaky seals..
Old 12-02-2009, 03:32 PM   #85
LukasM
Oddometer: 5,384
I have a spare set. Want to trade them for your 48's?
Old 12-02-2009, 10:54 PM   #86
*kartman* OP
GO Bacon GO !
*kartman*'s Avatar
Oddometer: 442
no.. I know that.. does the adventure plug mate to the 660sm cdi??? im either getting the 660 rallye or smc stator..
No ! I actually meant "plugs" with "connectors" ;)
They arenīt the same and wonīt fit.
Old 12-04-2009, 08:15 AM   #87
*kartman* OP
GO Bacon GO !
*kartman*'s Avatar
Oddometer: 442
There it is
Started it the first time and itīs running good
No strange noises or something else.
Now I have to do the cabling and so on
.... and buy an Akrapovic exhaust system
Old 12-04-2009, 08:33 AM   #88
tdreyer
KTiM
tdreyer's Avatar
Oddometer: 503
Oh! What ya gonna do with that old power plant?
~Tim
"04625 SXC
'04 625 SMC 76,xxx mi.
'97 CR500 Sold
tdreyer is offline   Reply With Quote
Old 12-04-2009, 08:40 AM   #89
*kartman* OP
GO Bacon GO !
*kartman*'s Avatar
Oddometer: 442
Either put it in a box as spare part.... or sell it (if someone offers me a good price)
Old 12-04-2009, 09:01 AM   #90
tdreyer
KTiM
tdreyer's Avatar
Oddometer: 503
~Tim
"04625 SXC
'97 CR500 Sold
Times are GMT -7.   It's 11:25 AM.
