Old 03-13-2010, 07:35 PM   #1
Trike Flyer OP
Oddometer: 26
F650GS Speedo not working
I'm looking at a 03 f650gs that has a speedo that is not working. Any thoughts on what may be the issue?
Thx
Jeff
Trike Flyer is offline   Reply With Quote
Old 03-14-2010, 05:12 AM   #2
Zoef zoef
Oddometer: 366
If I'm not mistaken, the F650GS uses a sensor on the back wheel to determine the speed. First check if the distance is working or not.
If distance is working:
  • Speedo is probably defective
If distance is also not working:
  • Distance between sensor and ring could be faulty
  • Sensor could be broken
  • Wiring between sensor and speedo broken somewhere
Zoef zoef is offline   Reply With Quote
Old 03-14-2010, 05:51 AM   #3
veesquared
Oddometer: 126
speedo
have a look at the wire itself from the rear sensor. I have seen the tire rub through the wire. Also up under the speedo itself is a connector . There is a bail that holds it in position cheap piece of black plastic Make sure the plug is setting on the pickup pins . I have had problems with moisture as well making the speedo quit until it dried out.
KTM 1190 KTM 690 E KTM 200 Exc
veesquared is offline   Reply With Quote
Old 03-14-2010, 07:17 AM   #4
Capt. REDBEARD
TWECO
Capt. REDBEARD's Avatar
Oddometer: 1,126
ditch it!
if you continue to have problems you might want to consider replacing it with a vapor or another aftermarket equivalent - a few folks around here have been doing that lately. Also if you are interested in keeping the OEM set-up I have a used speedo off of a 2003 w/14000k miles that I would be willing to part with..............
sorry I can't be more help - but it is a matter of back tracking wires from the unit out to make sure they are not compromised - and then checking with a volt meter at the speedo to make sure everything is providing the right juice.
1976 R60/6, 2009 530 EXC, 2008 250 XC, 2004 950 ADV
if the ocean were whiskey and I were a duck - I'd swim to the bottom and never come up
Capt. REDBEARD is offline   Reply With Quote
Times are GMT -7.   It's 12:26 AM.
