Old 11-11-2009, 06:14 AM   #31
dasvis
dasvis's Avatar
Oddometer: 536
Originally Posted by Chilipepper
Those aren't Philips screws they are JIS screws -look the same but different profile on the heads. If you have a hardware store nearby switch them out for proper Philips or I used my manual hammer driver. Can't remember the name right now, it holds the screwdriver tip and you hit it with a hammer to turn on or off. Won't damage the screw that way.
- Found a great source for JIS drivers. These guys are the sole importer of "Vessel" Japanese made tools. Below is a link to the bits they offer, search the site, they also show various screwdrivers & a lot of other top quality Japanese tools. I did some research on Philips head & JIS. The Phillips type were designed to "cam-out" once applied torque went above a certain limit to save the threads on the fastener. Nice- no wonder you see so many messed up heads on these. -- The JIS (Japanese industrial standard) type looks almost exactly the same, but the taper is slightly different - they are designed NOT to cam-out. If the JIS fastener is made to proper specs, it should have a small dimple or raised dot on the head to denote it as a JIS screw. From what I have read, you can use a JIS screwdriver on Phillps & it actually works better, but a phillips driver in a JIS screw will just mess it up. I have ordered a full set of JIS driver & bits!
http://www.jdvproducts.com/industria...-products.html
dasvis is offline   Reply With Quote
Old 11-11-2009, 02:35 PM   #32
Mark 42
Foiley
Mark 42's Avatar
Oddometer: 167
I was thinking you could cut a section out, drill & tap both parts,
put a stud in (and screw the two halves together) and then weld
and file the joint to make it strog and invisible.
A good welder could make it strong enough w/o the internal steel dowel
(or a titanium stud!), but I haven't done aluminium yet (I recently added
gas to my wirefeed welder).
Mark 42 is offline   Reply With Quote
Old 11-11-2009, 04:21 PM   #33
Chilipepper
Baja wannabe
Chilipepper's Avatar
Oddometer: 827
I ground a little bit of my kickstarter, then under the tank there is a big rubber pad that goes on the spine of the frame. I used foam for wrapping around water pipes. I think it took 2 layers under that rubber pad to hold the tank up off the kickstart. 1 think 1 layer was enough for about 4 months then it compressed too much.
Yes, this is my camera. No I won't shoot your freakin' wedding.
Chilipepper is offline   Reply With Quote
Old 11-11-2009, 05:41 PM   #34
dasvis
dasvis's Avatar
Oddometer: 536
Yeah, I thought about that too. Good idea.
Old 11-11-2009, 07:22 PM   #35
Mark 42
Foiley
Mark 42's Avatar
Oddometer: 167
That's a good idea.
Use some automotive heater hose slit open and it won't
compress so much.
I will have to do that next time I take my tank off (if I can remember)
Old 11-12-2009, 08:01 AM   #36
Chilipepper
Baja wannabe
Oddometer: 827
Yep big hose would work too. I just happened to have the pipe insulation laying around. I really just did it because I don't like how much some people have ground down the kickstarter.
Old 11-30-2009, 07:52 PM   #37
dasvis
dasvis's Avatar
Oddometer: 536
Originally Posted by XC Rider
Thanks for the info on the gas tank issue. I too have been thinking of adding a kicker to my DRZ, and also have the Clarke 3.9 tank. IMO, I think that your idea of applying a thin piece of sheet metal to the gas tank is probably the best solution.
Take some pictures and post them once you do it!
Finally had a chance to take it on an extended test ride... 100+ miles over mostly rough gravel roads & I can detect no sign of the lever rubbing on the tank at all. I think I will just leave it as is with no sheet metal protection.
The hour + that I spent on carefully grinding & test fitting paid off - it's a close fit but I made sure that there were no sharp edges & I buffed and polished it smooth.
Old 07-03-2010, 07:40 PM   #38
Matttys
Matt the Balloon Guy
Matttys's Avatar
Oddometer: 436
Can anyone give me advice on the picture below for my 470. . .
I'm having trouble installing kickstart gear with the knotch in the 4 O'Clock position. When I go to stick the long end of the spring into the engine case the gear always wants to rotate so the knotch is at 7 O'Clock or so. Is this correct? Should there be much tension on the spring or should there be little to no tension on the spring when it is installed?
Any help would be appreciated!
www.ProTwister.com
'04 Bonneville hack, '05 DRZ134SM minimoto, '02 955i Tiger, '08 WR250R
Matttys is offline   Reply With Quote
Old 07-20-2011, 09:31 PM   #39
Bird76Mojo
Bikeless :(
Bird76Mojo's Avatar
Oddometer: 1,461
Bumping this because I'm wondering the same thing..
GB
Threadkiller!!!
Always glad to help a fellow rider..
Bird76Mojo is offline   Reply With Quote
Old 11-29-2011, 05:42 PM   #40
GetYourOwn
Oddometer: 792
Can someone answer this last question? I am getting ready to install the kick starter and would appreciate any advice
GetYourOwn is offline   Reply With Quote
Old 11-29-2011, 07:49 PM   #41
dasvis
dasvis's Avatar
Oddometer: 536
Sorry, it's been two years & many lost brain cells since I did the install.... I don't remember!
Dasvis
What? Over? Did you say "over"? Nothing is over until we decide it is! Was it over when the Germans bombed Pearl Harbor? Hell no!
2009 Suzuki DRZ400S
Old 11-29-2011, 08:35 PM   #42
Mr. Cob OP
Howling "Mad", Adventurer
Mr. Cob's Avatar
Oddometer: 9,441
Howdy All,
Install the spring assembly just like I show it in the photos, there MUST be tension on the kicker return spring for it to function properly.
Dave, aka "Mr. Cob"
My photos, http://mr-cob.smugmug.com/ Join Smugmug, use this coupon ( https://secure.smugmug.com/signup?Coupon=geyYbNZwLLrl6 )
Mr. Cob is offline   Reply With Quote
Old 04-15-2012, 06:31 AM   #43
peteFoulkes
Oddometer: 157
Outstanding instructions. Thanks for documenting.
Read more about our round the world DRz 400 trip on our website here:
www.toughmiles.com
Find us on Facebook here:
www.facebook.com/toughmiles
peteFoulkes is offline   Reply With Quote
Old 05-14-2012, 07:16 PM   #44
Flatop
Flatop's Avatar
Oddometer: 4
DRZ400S kick start
Hi guys, we have 2 of DRZ400S that I would like to install the kickstarter on. Does the year of the machine matter or not? Mine are 2003 & 2004 units.
Flatop is offline   Reply With Quote
Old 05-14-2012, 07:18 PM   #45
dasvis
dasvis's Avatar
Oddometer: 536
Nope
2009 Suzuki DRZ400S
Times are GMT -7.   It's 06:51 PM.
