Old 05-14-2012, 08:16 PM   #46
KLXmcrider
Oddometer: 194
Thank you, I too am thinking of installing the kit on my new to me '00 E.
I believe the current Suzuki part #26300-29813 but says '06-up .So it will fit.
Again thanks for the info...David
KLXmcrider is offline   Reply With Quote
Old 05-15-2012, 06:58 PM   #47
Flatop
Flatop's Avatar
Oddometer: 4
Thanks Dasvis, nice avatar.
Flatop is offline   Reply With Quote
Old 09-27-2012, 08:51 AM   #48
geoduch
geoduch's Avatar
Oddometer: 45
Great write up and pix. I just picked up a 2001 DRZ440E and want to do this mod. Is there only the one Suzuki OEM kit available? The only one I have come across is Drz 400 Kickstart Kit 26300-29813, but some sites say it only works on 2006 and up models.... is this true?
George DuChaine
2003 Vstrom 1000 1983 VF750F Interceptor (gone) 1981 FrankenSeca 550 1986 VFR750F 2004 DRZ440E 1996 EXC300
geoduch is offline   Reply With Quote
Old 10-29-2012, 01:06 PM   #49
kcomst
Oddometer: 14
The issue is that newer models have a compression release. If your bike is older than this, you can still install the kickstart; just leave out the comp release. That's what I did on my 2000. The DRZ is harder to kick than my YZ450F, but when you need it, it's nice to have. This didn't happen to me until over a year after I installed it. In fact I forgot I had it. I was downtown and my battery went dead, tried push starting (it's hard to bump start too; you need pavement and a long hill or start in 4th/5th gear and get a lot of speed up on gravel) and was getting ready to call my daughter to come get me in my pickup truck. Then I remembered I had it. All of a sudden I was glad for spending the $200 and about 3 hrs of my time putting it in. I might also add that, since this thing is hard to kick, don't shorten the lever more than absolutely necessary if you have the Clarke tank.
Other issues people have mentioned:
Weight: some will disagree with me, but I do not consider the DRZ a dirt bike. My YZ450F is a dirtbike. The DRZ is a heavy dual sport. Adding 3 lbs is not going to make a significant difference. You can't do long jumps on this bike, it doesn't have the suspension. At one time I started installing aftermarket bling and trying to get my bike lighter, but gave up by the time I realized I had put $1500 into a $3000 bike, and still had not installed the other things I wanted - aftermarket pipe & muffler, oversize tank, FCR carb, inverted shocks, more comfortable seat. By the time you do all that, you may as well buy a KTM! The one thing the DRZ has over buying a KTM is low initial cost, and I believe it is more reliable and easier to maintain than the high performance bikes.
One person asked what else you should fix while you have the clutch cover off? Excellent question! While you have the oil drained and the side cover off is the best time to perform the water pump fix mentioned at the bottom of the DRZ mods page:
http://www.4strokes.com/tech/suzuki/drz400su.asp
Here are instructions and pictures:
http://www.thumpertalk.com/topic/194...ater-pump-fix/
Suzuki may have fixed this in later years, I don't know. But my DRZ like many others seems to mysteriously lose slight quantities of coolant and periodically needs to be topped up. I ran into this fix right after I had finished doing the kicker and wish I had known, I would have done it then.
kcomst is offline   Reply With Quote
Old 07-14-2013, 03:47 PM   #50
motoraptor
12 Seconds Ahead
motoraptor's Avatar
Oddometer: 16
Thanks for the write up.
I followed it to the letter and got a kick start installed on my KLX400 yesterday. It was my first time rooting around in any engine compartment and the photo documentation you provided inspired confidence. Cheers.
http://www.flickr.com/photos/kitundu_birds/9285983807/
motoraptor is offline   Reply With Quote
Old 07-14-2013, 06:23 PM   #51
N-m
Captain 2 Sexy
Oddometer: 457
Is this mod possible on all the variations of the 400 by Suzuki and Kaw? I would think since you have the same drive train.
Thanks for the great pics.
N-m is offline   Reply With Quote
Old 12-15-2013, 03:44 PM   #52
Simple_One
Oddometer: 52
IS the DRZ-400SM, the same deal as the S?
Can you install a kick start on a 2008 model, or did they add decompression or something else that complicates the works?
Simple_One is offline   Reply With Quote
Old 12-15-2013, 06:10 PM   #53
dasvis
dasvis's Avatar
Oddometer: 536
No problem, it will work fine.
What? Over? Did you say "over"? Nothing is over until we decide it is! Was it over when the Germans bombed Pearl Harbor? Hell no!
2009 Suzuki DRZ400S
dasvis is offline   Reply With Quote
Old 12-16-2013, 01:27 PM   #54
Simple_One
Oddometer: 52
Good news, thanks for that.
Old 02-22-2014, 03:10 PM   #55
bajadog
Running around knees bent
bajadog's Avatar
Oddometer: 85
Question
Followed Mr. Cobb's excellent photo instructions to a tee (I thought) on my
riding buddy's 2006 DRZ400s.
The kick start lever does not spring back
up after kicking it.
I did not have the spring retaining collar at around 4'oclock position because it required
winding (adding tension) the spring.
Does anyone remember if adding tension is required? I put the kick start shaft/gears/spring assembly clock
in so I would not have to wind the spring.
Thanks for your time.
bajadog screwed with this post 02-22-2014 at 04:00 PM
bajadog is offline   Reply With Quote
Old 02-22-2014, 04:29 PM   #56
Mr. Cob OP
Howling "Mad", Adventurer
Mr. Cob's Avatar
Oddometer: 9,461
Howdy bajadog,
YES, you must wind, pretension the spring for it to work properly.
Dave, aka "Mr. Cob"
My photos, http://mr-cob.smugmug.com/ Join Smugmug, use this coupon ( https://secure.smugmug.com/signup?Coupon=geyYbNZwLLrl6 )
Mr. Cob is offline   Reply With Quote
Old 02-22-2014, 04:56 PM   #57
bajadog
bajadog's Avatar
Oddometer: 85
Dave, thanks for the quick reply and PM.
Oh well time to pull it all apart again (should be quicker ) .
Marco
Old 02-22-2014, 07:13 PM   #58
bajadog
bajadog's Avatar
Oddometer: 85
What a difference a quarter rotation on that spring
made!
Now I just have to find why his idle is crap.
Thanks again Dave.
Old 02-08-2015, 09:21 PM   #59
KI6HNB
KI6HNB's Avatar
Oddometer: 230
I'm working on installing this kit right now. What is the recommended shade tree way to re-torque the clutch nut without having the wiz bang factory clutch holder tool?
'09 DRZ400S <--47K miles and counting
'08 KLX110 (now 177cc) pitbike
KI6HNB is offline   Reply With Quote
Old 02-09-2015, 01:25 PM   #60
intotheabis
High on life!
intotheabis's Avatar
Oddometer: 618
I put a little "blue" loctite and hit it quick with the impact while holding it with my gloved hand.
It was so loose when I removed it I figured that would be fine.......time will tell
Intotheabis
intotheabis is offline   Reply With Quote
Times are GMT -7.   It's 02:33 AM.
