Old 06-21-2009, 03:45 AM   #76
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,728
Originally Posted by Mezo
Theres a guy selling one in SA thats had the DHZ 140cc lifan engine swap
Have you heard them things rev once you done done a few mods ? risten
Correction two guys selling posties with 140cc lifan engines
Would one of these 160cc "race engines" fit in the postie ? $665.
Mezo.
Apparently they do, but then you have an unreliable Chinese piece of crap instead of a rock sold piece of crap that will keep going no matter what you throw at it, and thats what I thought was so attractive about them.
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is online now   Reply With Quote
Old 06-21-2009, 08:31 PM   #77
110Punk
110Punk's Avatar
Oddometer: 3
Two more extreme adventure posties are about to launch into action after a couple of weekends of fiddle in Sydney...
One is a 2005 with 32,000kms sourced via Gumtree for $800 unregistered but in good nick from an owner who bought it at Pickles Auctions, got it serviced and then got distracted until the wife got sick of it.
The other is a 2004 that's been resprayed and restored by a third party.
Tanks were picked up at Liverpool Bike Wreckers for $30 a pop... one an old XR250, the other a random Yamaha number. Much more appropriate than the $195 quoted elsewhere for similar product!
Immediate plans are to fit some panniers, a prototype of which can be seen being used as a seat below, and switch to some higher output lighting. Keep everything else stock and go have some fun!
Oh and from our couple of months of prices research some of the best value CT110 buying is on eBay.com.au or other local classifieds... You really shouldn't be paying more than $900 for a clean unregistered example with 30,000km's on the clock.
Seeing the world at 65km/h...
110Punk is offline   Reply With Quote
Old 06-22-2009, 04:32 AM   #78
Andreenduro
LUMI
Andreenduro's Avatar
Oddometer: 107
What type oil??
Hi everyone,
first of all a question to 110punk. Can you tell me more about the pannier you knocked up?
And than, what type oil do you have to tip into the 110?
My mate just got his beast, signed up on ADV and am sure will be with you fellas shortly.
I just want to give him a hand with a few things and one is the oil change.
Don't want to dump anything in there.
Cheers all, Andreenduro
Andreenduro is offline   Reply With Quote
Old 06-22-2009, 04:23 PM   #79
110Punk
110Punk's Avatar
Oddometer: 3
The Manual recommends 10W-30, which should be fine in tassie.
The Pannier was knocked out by my co-conspirator.
He took a 20L water jerry, sliced the top off and then cut the remaining bucket in half. Splice in a little extra width with some 2mm sheet and some pop rivets. He's also included some internal mdf sheets to add strength. The lid will either be pressed from more 2mm sheet or made up in vinyl tonneau material.
Pannier brackets will be from Bunnings and we'll just wingnut and wire lock the suckers on for relatively easy removal from the rear tray.
I'm just hunting about for an '86-91 XR250 fuel tank cap to complete the current mods so I can fuel up the big can on the front.... at 30-50km per Litre the extra 9L should kick the range out a little.
Old 06-22-2009, 10:19 PM   #80
voodoo110
voodoo110's Avatar
Oddometer: 2
I am 110Punk's co-conspirator.
My tank (the white one seen in his first picture) is from an '82 YZ250J. Mounting was fairly straightforward with some 90-degree angle brackets from Bunnings bolting the tank onto where the engine guard meets the frame. The back is held in place with a custom bracket easily bent out of some 3mm aluminum extrusion and attaching to the front of the seat hinge.
All the fuel lines were able to be rerun using the existing lines - so no need to buy extra.
Due to the location of the tanks the keyswitches were moved to the 'standard' location of under the speedo - as most people before us have done.
The next test is to see who's tank (the XR or the YZ) has provided the most extra range! I feel a little healthy wager coming on...
voodoo110 is offline   Reply With Quote
Old 06-23-2009, 02:57 AM   #81
glitch_oz
glitch_oz's Avatar
Oddometer: 1,783
Originally Posted by Andreenduro
Hi everyone,
We ran the shitters on 20-50 Diesel-engine oil (some BP plonk we got in Bamaga).
No probs whatsoever.
Any reasonable non-synth oil is fine.
Go posh...Motul 1000
Cheers
pete
www.AusTouring.com
A Dozen Years Of Adventures
glitch_oz is online now   Reply With Quote
Old 06-24-2009, 06:59 PM   #82
Andreenduro
LUMI
Oddometer: 107
Oil and panniers
Thanks all for the replies. Will change the oil and like the pannier idea !!
Have fun, cheers, Andree
Old 07-10-2009, 07:09 AM   #83
BUZZ44
BUZZ44's Avatar
Oddometer: 119
Almost finished
Well she is almost finished, ended up with a XR600 tank. Still have to fit the hand guards and finish the steering damper post mount.
[IMG]
http://
From Drop Box
BUZZ44 is offline   Reply With Quote
Old 07-10-2009, 05:13 PM   #84
Joe Watson OP
Joe Watson's Avatar
Oddometer: 1,032
Here is a link to a postie ride I just did:
http://advrider.com/forums/showthrea...4#post10315684
Joe Watson is offline   Reply With Quote
Old 07-11-2009, 03:21 AM   #85
angryad
Don't drop the soap.
angryad's Avatar
Oddometer: 1,451
Has any one changed their fork oil? In the manual it says drain the old stuff, fill from the top with ATF(automatic transmission fluid). Do you just fill it to the top, or is there a specific amount?
our latest Goldfields trip
http://www.youtube.com/watch?feature...&v=pQk4k_xXC3k
angryad is offline   Reply With Quote
Old 07-11-2009, 04:24 AM   #86
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,728
I was waiting until Philth and the others got back to ask this but what the hell...
After changing my second gear (half arse rebuild) and getting the postie back together, it makes a loud grinding noise when changing from second to third.
I found a screw and lock nut on the clutch cover that I adjusted until it stopped grinding but then the kick starter wouldn't engage....
So where did I stuff up?
tEAM iDIOT.
Old 07-11-2009, 04:27 PM   #87
FJRthommo
Anti social ranga
Oddometer: 165
Thought i'd better stick my head in this thread and say i also have a postie.
97 model that now has 31K on it. didn't have that many when i brought it for 900 not too long back. i'll be doing a FarRide on it next week.
i'll post a picher later on when i take one!
FJRthommo is offline   Reply With Quote
Old 07-11-2009, 09:37 PM   #88
FJRthommo
Anti social ranga
Oddometer: 165
Old 07-16-2009, 08:40 PM   #89
110Punk
110Punk's Avatar
Oddometer: 3
Just took our posties for a brass monkey weekend overnighter to lithgow... cold but great fun...
http://ct110.wordpress.com/
Few mods to adjust, some aesthetics to attend to, and an engine / gearbox overhaul on the cards but the Posties killed it for the weekend, and the touring tanks were a boon for range!
Question is, where to next?
Old 07-16-2009, 09:04 PM   #90
wiggywildwildwest
cranky bugger
wiggywildwildwest's Avatar
Oddometer: 737
the go with the clutch adjustment is to loosen the locknut, turn the screw anticlockwise 'til it gets firm. then clockwise 1/4 turn. lock the lock nut. all should be well.
Where you come from is gone. Where you thought you were going, Was never there. Where you are, Ain't no good unless you can get away from it.
wiggywildwildwest is offline   Reply With Quote
Times are GMT -7.   It's 02:08 PM.
