Go Back   ADVrider > Riding > Regional Forums > Australia
Old 05-31-2013, 04:44 PM   #931
Redmohawk
Random user
Oddometer: 5
Thought I'd go a little silly on an old CT90 , planning on taking it to the salt flats next march. Aiming for 100 mph on something that still looks like a postie (subject to some rules) Motor should top out at around 25 hp 200cc.
Bit of a work in progress atm
Ct90 piston beside Xr200 piston
CT90 crank and XR200 crank before mods
Now the XR200 crank will sort of fit
CT90 cases adjusted slightly to fit modded XR200 crank
CT90 barrel bored a little to far, for
A slightly modded XR200 barrel.
Redmohawk is offline   Reply With Quote
Old 06-04-2013, 01:01 AM   #932
Redmohawk
Random user
Oddometer: 5
Xr200 intake valve set beside a ct90 set
stock valve angle
Adjusted valve angle
xr200 valve at new 20 deg angle in ct90 head , means I need to make up custom valve seats and all kinds of other bits n pieces.
https://www.facebook.com/media/set/?...9105456&type=3
Old 06-06-2013, 01:58 AM   #933
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,378
stock valve angle
Cool
Not much left in barrel
You can jam a 61mm sleeve in the 90 barrel and it has some meat left.
Good luck
being wrecked by bored and stroked posties....braaaaaaaaaap
WILL_S is offline   Reply With Quote
Old 06-07-2013, 02:56 AM   #934
Redmohawk
Random user
Oddometer: 5
Xr200 barrel is 65.5 mm inside dia , this jigger is being built to go real fast for a short period (land speed racer on the salt) , but I hope to manage to ride it as much as possable.
Old 06-07-2013, 03:24 AM   #935
panhead_pete
Gone riding
Oddometer: 1,190
Wow that looks really interesting. Make sure you are fully up to speed with the rules for the DLRA including the leathers etc you need to wear. I'd love to race one year.
Going to Japan? Im there and happy to help.
panhead_pete is online now   Reply With Quote
Old 06-09-2013, 05:03 AM   #936
Redmohawk
Random user
Oddometer: 5
I'm a member and know a few in the area, so up to speed so to speek lol
Old 06-13-2013, 04:08 AM   #937
p-4
p-4's Avatar
Oddometer: 22
Honda ct 110 posti Preparations to around Australia tripp.VOl 9 LED LIGHTS
Front,LED lights testing ,plan install to honda ct 110 posti 2x10w led lights!.
Ordered from Ebay abaut 23 au pis.
Here was testing one in finke desert race wikend.
http://web.zone.ee/kangro1/Honda%20c...02/LED%20HONDA
p-4 is offline   Reply With Quote
Old 06-13-2013, 04:29 AM   #938
p-4
p-4's Avatar
Oddometer: 22
Led lights ,is 60 degree angel end flood 4x3w(abaut 1A) leds,the lengthwise 50m and widthwise40m.it can be said that, the one Led lights is better than the original front light.but my plan is to install two.Thus it is necessary to modify the electrical system,since the original generator output is 84w (7A)total.However ,turn signal end back lights
consume a lot of electricity relative,I change they to the ,low power led lights end turn signal relay must to change do!
Old 06-15-2013, 06:40 AM   #939
Clacka
motomofo
Clacka's Avatar
Oddometer: 814
holy shit, that's awesome
I'll be watching with keen interest
2005 Suzuki DRZ400SM (Dazza? Dizzy? Darcy? Dougal?)
2010 Yamaha XTZ660 Tenere (Trev)
2007 Honda CT110 (Hercules)
2004 HD 1200 Custom Sporty (Harold) FOR SALE
sortof...
1978 Yamaha TT500 (The Beast) (sold)
Clacka is offline   Reply With Quote
Old 06-17-2013, 03:45 AM   #940
Redmohawk
Random user
Oddometer: 5
Was planning roller rockers to complament the high lift very long duration cam, looking at around 10mm lift 300 deg duration 120 deg overlap with 30mm inlet and exaust valves. (Same size valves because I'm planning on running a big hit of NOS on the salt) But no matter how I hack at heads/billet T7 Ali I can't get the roller rockers to fit/be strong enough to survive 11,000 rpm for long runs and be as light as the stock units. So now I'm looking at modding the stock rockers with only needle bearings on the piviot. And moving the valve actuator/adjuster bolt inwards to suit the new altered valve position.
If I can screw 25 hp out of the motor NA then I'll try and shove another 15hp of NOS/fuel into her for the salt runs. 40 hp should get the old girl with my fat ass up to somewhere in the region of 170 kph give or take a few. I want to crack the real ton (100mph) on her.
From data I've scratched up on drag for the bike shape etc 25 hp with a good rider position should be good for 100mph just (head up riding standard position 25hp only good for 150 kph) . So 40 hp would be nice as insurance to get over the ton.
Old 06-23-2013, 01:57 AM   #941
p-4
p-4's Avatar
Oddometer: 22
Honda ct 110 posti Preparations to around Australia tripp.VOl 10 LED LIGHTS testing
Picture of LED lights in action
http://web.zone.ee/kangro1/Honda%20c...D%202%20Lights
Old 06-24-2013, 12:41 PM   #942
RDT953
RDT953's Avatar
Oddometer: 288
Nice lights
They look great, been thinking along the same lines for my bike. Are you using any sort of a relay?
I'm lost, I've gone to look for myself, if I should return before I get back, have me wait.
RDT953 is offline   Reply With Quote
Old 06-26-2013, 02:59 AM   #943
p-4
p-4's Avatar
Oddometer: 22
Wicked Honda ct 110 posti Preparations to around Australia tripp.VOl 10 LED LIGHTS testing
There are two ways,fristly opportunity is to use relay (5-10A) .The idea is that you take relay contral power from front lighte ,
which in turn passes to the exstra light switch end
can only be used ,with the engine running do
avoid batery draining.
However the exstra Led lights 2x10W ,consume only 2A power you can use only switch without relay and, of course, fuse between lights end batary
Anyway do my frend posti bike, we plane to install 2x5w Led lihts end
apparently do not need modifay turn lights.
Old 06-26-2013, 04:36 AM   #944
mcguyver
mcguyver's Avatar
Oddometer: 1,295
Just did a postie ride in the vic high country. Thought you might be interested.
http://seqtrailrider.typepad.com/my_...enanigans.html
mcguyver is offline   Reply With Quote
Old 06-27-2013, 06:34 AM   #945
RDT953
RDT953's Avatar
Oddometer: 288
Thanks for the information. Looking forward to reading about your trip. When do you plane to start?
Times are GMT -7.   It's 11:07 PM.
