Old 04-06-2013, 03:19 PM   #46
AirheadRick
AirheadRick's Avatar
Oddometer: 6
Originally Posted by Prutser View Post
No need to sand down before everything fitted. I mounted about 20 of those rizoma bars.
But I was using the fat bars although it shouldn't make a difference.
You could try to put the controles on the wrong way to check if its the clamps of your controles that is to tight or its the diam. of the handle bars.
Mine are not the fat ones, they are the same diameter throughout which is great since they fit the bar backs and clamps I have on the bike now. They measure 22 mm with the caliper so everything should fit. I am just a bit nervous about forcing the controls on. The model I have is MA001.
http://www.motovationusa.com/mvstore...?idproduct=563
AirheadRick is offline   Reply With Quote
Old 04-06-2013, 03:27 PM   #47
Plaka
Brevis illi vita est
Oddometer: 4,609
Originally Posted by AirheadRick View Post
They are cast won't they break if you try to expand them?
You don't want to expand them much. How much are you going to sand off a bar?
I just opened up one of my spare clutch side perched with a big screwdriver in the clamp slot. Not much but if the thing is pretty close but just tight, should be enough. There is also a lot of room to clean up the inside of the perch.
Old 04-06-2013, 03:33 PM   #48
AirheadRick
Oddometer: 6
I will give it a try. I am out of town at work until Tuesday. I will try it then and give some feedback. Thanks
Old 04-06-2013, 03:41 PM   #49
Plaka
Oddometer: 4,609
Use the force, Luke.
Remove the pinch bolt altogether and clean the threads, leave it out. Clean the inside of the perch. Use a very large screwdriver in the pinch slot and twist when putting the perch on. Put the pinch bolt in last.
Old 04-06-2013, 03:52 PM   #50
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,801
I use the same technique that I use to open the lower clamp on the triples when they have been there a while: take a wide-blade standard (flat) screwdrive and use it as a wedge. The trick with aluminum is to work it slowly and let it expand (or whatever it does!)... forcing it rapidly tends to break things, moving it gently and slowly it can be expanded enough to get it on the bars. ....just did it for my 80ST el-cheapo bars!
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 04-10-2013, 09:05 PM   #51
AirheadRick
Oddometer: 6
Thanks guys. In spite of following the recommendations things didn't work out for me I managed to crack the clamp on the perch. It's still together but I don't thing I would trust it that way. I am pretty frustrated it took me a long time and wasn't cheap to get the right handlebar controls to do a handlebar master cylinder conversion on my /7. Guess I should have stayed with the stock bars. Going to see if a welder friend of mine with a tig set up can weld the crack or start my search for a new double pull throttle cable with the master cylinder.
Old 04-11-2013, 10:12 AM   #52
Boon Booni OP
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,504
That sucks.. Sorry to hear it.
Old 04-11-2013, 12:09 PM   #53
Prutser
Prutser's Avatar
Oddometer: 995
Did you try to slide them over the bars the clamp part last ? just to try if they do fit.
On those things its best to Not use the force !!!! They are brittle. But thats something you know now
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 04-13-2013, 10:52 AM   #54
SRanger331
SRanger331's Avatar
Oddometer: 183
Just changed my US high bars for the Rizoma MA001's
Ben
'73 BMW R60/5
'12 Yamaha FZ1
SRanger331 is offline   Reply With Quote
Times are GMT -7.   It's 01:16 AM.
