Old 04-18-2009, 01:31 PM   #1
the venturer OP
the venturer's Avatar
Oddometer: 1,387
Navcity 2009 map update failure
Hi! you all. I have just downloaded and installed new map version of Türkiye on my laptop and it is all fine until I have discovered that I am unable to send it to the device via mapsource now.
I says '' to transfer data to your device, select maps orcreate waypoints, rotes or tracks.''
Isn't it possible to change the map on the device this way?
Any help would be appreciated.
Thanks in advance.
the venturer is offline   Reply With Quote
Old 04-18-2009, 03:40 PM   #2
Jamie Z
Jamie Z's Avatar
Oddometer: 6,934
Send a message via Skype™ to Jamie Z
Have you used Mapsource before? Have you used Mapsource to send maps to the GPS before?
You must select the maps you want to send to your GPS. To do this, select the "Map Tool" in the toolbar. Now when you move the mouse around the screen you should see sections highlighted. Click on the sections you want to send to your GPS. They will change color. After you have chosen all the sections you want, select "Transfer" and "Send to Device."
If your GPS is properly connected to the computer, you should see it in the dialog box. Make sure the check box for "Maps" is selected, and then click "Send."
Jamie
I'm the Tent Space Guy Sign up to host fellow travelers here.
Budget Travel the Jamie Z Way
Jamie Z is online now   Reply With Quote
Old 04-18-2009, 11:56 PM   #3
the venturer OP
Oddometer: 1,387
Jamie
Thanks Jamie for your reply. I'll try explain it. I have been using Mapsource and GE happily until I came to a new map release. I downloaded and installed it onto my laptop. When turned it on to send the map to my 2610, there seemed no map to choose,let alone waypoints or tracks. I mean I can't choose anything now. Before this, I was able to do everything on mapsource. I can't select a map or anything to send to the unit.
Now I have started trying again.
Old 04-19-2009, 02:38 PM   #4
zakou
zakou's Avatar
Oddometer: 978
Tuurkey Map
I have installed the update of Navcity Turkey 2009.02 - MapID: 848
and everything is working fine on my 276C. I can transfer the entire map without any problems!
It sounds very strange what you are writing! By the way this update just comes out the right time for us!! the 15th of May we are going to be in Turkey!!:)
zakou is offline   Reply With Quote
Old 04-20-2009, 11:44 AM   #5
the venturer OP
Oddometer: 1,387
So; would it be too early to say ''Welcome to Türkiye'' Zakou?
If you make your through the customs at any weekend, let me know.
We could have a lunch of our typical cuisine.
As regards to my thread here, I have a question to you.
when you open Map Info page on your device, tell me what is written there? Navcity 2009-2 or; B1, B2, B3.....as per a division of the total map?
When 2008-4 installed on the device, all I could see on the Map Info page was two maps: one for Navcity 2008-4 and the other Türkiye Topo. It was so easy to switch to another one while riding on the bike. With this new form, 54 regional map divisions on map info page.
I can't understand this.
the venturer screwed with this post 04-22-2009 at 12:05 AM
Old 04-22-2009, 12:02 AM   #6
the venturer OP
Oddometer: 1,387
On map info page, there are 54 pieces of maps this time. Almost impossible to move from one map to another on bike.
Imposiisble to edit or fix this?
Old 04-22-2009, 11:02 AM   #7
zakou
zakou's Avatar
Oddometer: 978
Hi there
After installation of the Map on my 276C on the Map information page I see
B1, Turkey, NavCity 09.02 TKLTL by Basarsoft
there are total of 9 Maps on my Device From B1 to B9
By the way thank you for the invitation!! Our plan is to pass the border go to Kesan and then move to Gelibolu then to Canakkale then move to Sakirbey we want to see Kus Golu and then to Bursa. We will visit Instabul on our way back from the Black Sea region.
Old 04-22-2009, 11:46 AM   #8
the venturer OP
Oddometer: 1,387
PM sent Zakou.
Times are GMT -7.   It's 04:13 PM.
