Old 04-18-2009, 08:09 PM   #1
blankenship OP
Oddometer: 13
disastrous '71 yamaha CT1 restore? oh no?
a good friend's elderly father gave me his old '71 yamaha ct1 175 enduro a few months ago, as it had been collecting dust since 1976!
i cleaned the carb and put a put in a keyster kit, sealed the tank, replaced all the corroded gaskets, added new bel-ray oil in the injector, and she fired up today! when the smoke cleared, she seemed to be running darned good...though only with the idle/air screw screwed all the way in.
i warmed her up, drove around the block a few times, and was having a quite a blast...then suddenly...SMOKE...tons of it...billowing gray out of the tail of the pipe and the pipe/engine connection.
she died, and though i was able to restart her, she smoked like crazy and runs like crap. the plug was pretty fouled...but a new plug didn't make a difference.
ps: i hadn't changed the transmission gear oil yet..i was waiting til i got her warmed up.
ps2: i didn't test the oil injector first.
ps3: my girlfriend claims to have heard a "squeal" come from the bike before it started smokin'.
what happened?
now what?
blankenship is offline   Reply With Quote
Old 04-18-2009, 08:39 PM   #2
ruh roh
hey Yall
ruh roh's Avatar
Oddometer: 296
Does the kickstart still move the piston?
edit, I see still it started back up. I'M guessing rings broke or valves stuck.
If the world didnt suck , we d all fall off.
ruh roh screwed with this post 04-18-2009 at 08:45 PM
ruh roh is offline   Reply With Quote
Old 04-18-2009, 09:00 PM   #3
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,195
Valves stuck on a CT-1??? Come on man its a 2 stroke.
My bet is you lost the main seal on the clutch side of the crank. It's sucking tranny oil into the crankcase.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 04-18-2009, 09:01 PM   #4
Andy-Gadget
Any bike can go anywere
Andy-Gadget's Avatar
Oddometer: 1,347
Sounds like crank shaft seals to me, letting gearbox oil into the engine, and letting crank case compression out.
Whatever the cause, it sounds to me like a full pull down is indicated.
"If a man empties his purse into his head, no man can take it away from him.
An investment in knowledge always pays the best interest"
Benjamin Franklin.
'95 Sport 1100 Guzzi,'84 Cali 2 Guzzi, '95 Guzzi mille, '84 R65LS, '84 R100, '82 R100RS, '05 DL650, '72 Bultaco Sherpa T 350, '78 Montessa 348, "00 XR650R
Andy-Gadget is offline   Reply With Quote
Old 04-18-2009, 09:58 PM   #5
blankenship OP
Oddometer: 13
how to
crankshaft seals, eh?
are those the "oil seals" (parts number 14 and 17 on this shematic) : http://www.bikebandit.com/assets/sch.../YA4256_02.gif ?
can they be repaired without removing the motor from the bike?
anybody know if there's a test i should do first, and/or if there's a "how to" thread anywhere on the forum? (i've searched, but didn't have much luck).
Old 04-18-2009, 10:52 PM   #6
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
+1
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 04-19-2009, 05:24 PM   #7
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,261
hah! nope! pull motor, tear it apart. replace crank bearings and seals.
stainlesscycle is offline   Reply With Quote
Old 04-20-2009, 09:22 AM   #8
wolvertone
Save a mile-Kill a metre!
wolvertone's Avatar
Oddometer: 171
If you didn't check the oil injector, the oils is most likely "gelled" up and you could have ran it without oil and scored the cylinders.
Have you done a compression check?
Steve
RR Colorado '09: http://advrider.com/forums/showthread.php?t=476546
1966 Chang Jiang 750 M1M
1977 Harley Ironhead
1979 BMW R100RT
1990 BMW K100LT (parting out)
1996 Beta Techno
1999 Kawasaki KLR 650
wolvertone is offline   Reply With Quote
Old 04-20-2009, 05:49 PM   #9
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,195
Wow!!! That's number two for this thread. Do you guys just type random stuff and hope that something you've said might apply?
Old 04-20-2009, 07:57 PM   #10
Cat Daddy
Cob Artist
Cat Daddy's Avatar
Oddometer: 837
This is the forum to learn and talk motorcycles. Why don't you explain the fault in his logic instead of being a jerk ?
If you want to be an asshole, Jo Mama is a more appropriate venue.
Cat Daddy is offline   Reply With Quote
Old 04-20-2009, 09:22 PM   #11
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,195
Of course it is a great place to learn about bikes and to talk about them too but are these people reading what the OP said??? And gee..... I did tone it down. I didn't call anyone a F'n idiot. Or unlike you, I didn't call anyone an asshole. I wasn't going to go into exactly how off his post was but since you asked, let's look at some of what is being passed off as knowledge here.
OK, the first guy was talking about valves. On a CT1..... Duh. The second guy is talking about...wait a minuet... how many barrels does a CT1 have? Oh yeah that's right only one. Maybe it's the second one that has those mysterious valves in it??? Also if your are burning so much oil it's "billowing" out the pipe and fouling plugs, it is highly unlikely that a lack of oil has caused scoring to the cylinder(s) sic. AND even if you did have a scored barrel all the blow-by in the world isn't going to cause it to smoke because there is no oil in the crankcase, geeze it's still a 2 stroke! Or maybe 2 strokes are too complex for you sensitive types???
It would be much better to have had no responses than out of the ball park wrong ones.
Old 04-21-2009, 04:24 AM   #12
Cat Daddy
Cob Artist
Cat Daddy's Avatar
Oddometer: 837
Well, I will stand by my words that you were being an asshole in that post.
But, your reply does illuminate the logic or lack thereof in his resonse. I'm watching this thread closely because I too have a CT 1 175. It's a one owner, bought new by my mother in law, and it has 800 miles on it. I've been collecting parts here and there for a complete resto in the future.
I appreciate your second post explaining the faulty logic.
Old 04-21-2009, 04:53 AM   #13
JRP
Old guy
JRP's Avatar
Oddometer: 1,491
It is possible for the oil injector to be at fault,especially on a bike that old. I always disconnected them and ran premix when I was riding enduros (too many years ago to count) LOL
My guess is also the crank shaft seals, these have been sitting for a long time and rubber does get hard with age. Replace them and also check the cylinder walls for scoring, a set of rings and quick hone should fix that up quite easily if that is the case.
Good luck with the project!
"What could possibly go wrong? " The Jerk
2014 Royal Enfield Continental GT
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is offline   Reply With Quote
Old 04-21-2009, 02:46 PM   #14
Inane Cathode
Cheated Anion
Inane Cathode's Avatar
Oddometer: 4,601
I've noticed oil two stroke oil gets super runny. Might want to rotate the injector by hand and make sure whats coming out of the schnozzle is what you've put in the tank.
_______
Pokey The Wunderbus
The VEEP Project
Inane Cathode is offline   Reply With Quote
Old 04-21-2009, 07:38 PM   #15
pplassm
Brace for collision!
pplassm's Avatar
Oddometer: 2,557
If it's like my MX360, you can remove the right sidecover, clutch and primary drive gear, and get access to the drive side seal. You should be able to pry it out and replace it with a new one. Might as well do the generator side, too, while you're at it.
Pete
pplassm is offline   Reply With Quote
Times are GMT -7.   It's 12:10 PM.
