Old 04-20-2009, 05:44 AM   #1
7575KK OP
KK
7575KK's Avatar
Oddometer: 105
INFO: Some info about 990 Adv water pump
KTM suggest that water pump wheel on 990Adv (probably and 950Adv) can be replaced with KTM RC8 water pump wheel.
It will provide more flow within cooling system.
I saw that wheel and it was replaced on ma 990Adv/07 a week agoe during periodic service.
Wheel is slightly wither but it still fits in water pump. Wheel feathers are different too. The are more curved than on 990Adv wheel.
KK
7575KK is offline   Reply With Quote
Old 04-23-2009, 05:48 AM   #2
Louge
silence of the limbs
Louge's Avatar
Oddometer: 1,554
Good info KK.
Can you comment on performance?
P/N?
Just how deep do you believe?
Will you bite the hand that feeds?
Nine Inch Nails
Louge is offline   Reply With Quote
Old 04-23-2009, 06:22 AM   #3
RumRunner
Sit there, turn that
RumRunner's Avatar
Oddometer: 4,720
Another thought, at least annually completely remove the radiator and wash out/blow out all of the crap that accumulates in the fins. If your an off-road rider you will be amazed at the amount of crap that is lodged in the rad.
DW
I became friends with someone just because they rode motorcycles from no-place to no-where.
RumRunner is offline   Reply With Quote
Old 04-23-2009, 06:47 AM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,000
Good info.
Good info.
Could we have part number# pls?
Old 04-23-2009, 11:14 AM   #5
Fuelman
professional lurker
Fuelman's Avatar
Oddometer: 53
Water Pump Rotor 08
WATER PUMP ROTOR 08
Part# 61235055000
$5.28 (ktm-parts.com)
"Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything." Charles Kuralt
Fuelman is offline   Reply With Quote
Old 04-23-2009, 12:59 PM   #6
crofrog
Oddometer: 1,455
KK
Any source for that information?
crofrog is offline   Reply With Quote
Old 04-24-2009, 02:59 AM   #7
7575KK OP
KK
7575KK's Avatar
Oddometer: 105
Originally Posted by Louge
Good info KK.
P/N?
I'll post part number when I get home from work.
I've put also new cooling liquid, Motul - Motocool Factory Line, and aluminum cooler guard.
This combination is noticable better.
KK
Old 04-24-2009, 05:24 AM   #8
CHRIS_D
CHRIS_D's Avatar
Oddometer: 962
KK
I'm bit confused. I know this is a surprise anyway, is this an updated water pump wheel that's currently being installed on the newer ones?
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 04-24-2009, 05:32 AM   #9
7575KK OP
KK
7575KK's Avatar
Oddometer: 105
I don't believe it's update. I believe it's recommendation...
If you want it you can replace it.
Anyway that wheel cost around 10$. (+some extra for seal and new coolant)
Will new models of 990 adv have same wheel as RC8 I have no idea.
KK
Old 04-24-2009, 09:10 AM   #10
Autostream
Autostream's Avatar
Oddometer: 5,833
2009 990 manual shows new shaft & Impeller
Impeller is same as the RC8 as posted above.
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream is offline   Reply With Quote
Old 04-24-2009, 12:38 PM   #11
7575KK OP
KK
7575KK's Avatar
Oddometer: 105
Indeed, on bill I see p/n 612.35.055.000.
So it must be that it's on model 2009 already updated.
KK
Old 04-24-2009, 12:55 PM   #12
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
2009 was the first year for LC8's to use this pump wheel.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 04-24-2009, 06:10 PM   #13
CHRIS_D
CHRIS_D's Avatar
Oddometer: 962
Ok now it makes sense. Usually companys don't update a product unless there a good reason to do it.
Old 04-27-2009, 02:17 AM   #14
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,000
Seems the wp cover has also been updated.
So there is the possibility the new wheel does not fit inside the older than 2009 Advs. Can someone measure this? Cheers.
Old 04-27-2009, 03:12 AM   #15
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,475
Is the part number for the cover the same (600.351.521.0023 in the above diagram) on older Advs? If so, I would expect the new impeller to fit.
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Times are GMT -7.   It's 02:58 PM.
