Old 04-27-2009, 07:35 AM   #16
cool dude
cool dude's Avatar
Oddometer: 273
Cool2 Actually no
Originally Posted by uk_mouse
Is the part number for the cover the same (600.351.521.0023 in the above diagram) on older Advs? If so, I would expect the new impeller to fit.
It seems not. The old part number is 60035052000 although they look the same. See here from the 2006 990 Adventure part manual.
cool dude is offline   Reply With Quote
Old 04-27-2009, 09:26 AM   #17
mookymoo
Mookish Mook
Oddometer: 4,396
What is the benefit of the newer impeller?
mookymoo is offline   Reply With Quote
Old 04-27-2009, 09:34 AM   #18
cool dude
cool dude's Avatar
Oddometer: 273
Cool2 MMMmm
Higher flow rate is suggested in the first post.
I'd be interested in trying it out if it will fit in the older water pump housing.
Old 04-27-2009, 01:48 PM   #19
mookymoo
Mookish Mook
Oddometer: 4,396
D'oh, missed that sentence.
Thanks.
Old 04-27-2009, 04:10 PM   #20
Autostream
Autostream's Avatar
Oddometer: 5,833
2009 990 Parts manual shows asterix's on three new parts, impeller, cover and shaft.
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream is offline   Reply With Quote
Old 04-27-2009, 05:14 PM   #21
Gimme 2
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,124
I'd say the # means updated?
Gimme 2 is offline   Reply With Quote
Old 04-27-2009, 06:27 PM   #22
Autostream
Autostream's Avatar
Oddometer: 5,833
I you read the page...
# = Included in Gasket set (this is in left side diagram by the box)
* = New Part (bottom of right box and next to item numbering in parts list)
X = As required (bottom of right box and next to item numbering in parts list)
Old 04-27-2009, 10:13 PM   #23
cool dude
cool dude's Avatar
Oddometer: 273
Cool2 Prices
Well, if just those three parts need replacing then in Euro land the parts should cost about:
8 61235055000 2.56
4 6003515210023 37.25
14 61135054044 38.62
Some of the other parts have different part numbers too FYI...
Old 04-28-2009, 05:31 PM   #24
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,810
OP says that the new impeller was used on his '07, so it would seem that the new part would fit on all 990's and I would think all 950's as well.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 05-05-2009, 10:11 PM   #25
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,003
The wp cover is different.
the old one was #600.350.521.0023 but the old impeller height was 12,7mm while the new one measures 11,1mm so the hydrodynamics could be worse fitting new impeller to old pump housing. Cheers
gefr screwed with this post 05-06-2009 at 09:14 PM
Old 05-06-2009, 08:55 PM   #26
twodollardoug
the calimesa kid
twodollardoug's Avatar
Oddometer: 337
i just got my new impellers today, part # 612.35.055.000. they look quite different than the originals on my 08 sd and o8 adv. i wonder if the op's pump housing was replaced also?
twodollardoug is offline   Reply With Quote
Old 05-07-2009, 05:58 AM   #27
crofrog
Oddometer: 1,455
Also with out changing the size of the restrictor (thermostat in this case) you aren't going to dramatacially alter flow rates so I'd see if that's an updated part number as well.
crofrog is offline   Reply With Quote
Old 05-07-2009, 10:13 AM   #28
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,003
Looking at the new impeller I think the reason of the update is to make it slimmer.
Since the impeller is slimmer by 1,5mm and the housing is also slimmer, I guess the target could be to make it occupy less volume. Just a wild guess, untill I try to install the new items.
Cheers.
gefr screwed with this post 07-14-2011 at 12:08 AM
Old 05-07-2009, 11:06 AM   #29
BobbyC
BobbyC's Avatar
Oddometer: 1,353
I ordered a water pump rebuild kit last week and the shaft is new. It looks like there's some sort of coating to harden the surface. The seal is still gray and it comes as a set with the shaft.
No pics as I was in a rush to get my bike together and head down to NC.
-Bobby
'08 KTM 450 EXC-R
"I LOVE my bike!!!"
BobbyC is offline   Reply With Quote
Old 05-07-2009, 05:44 PM   #30
Autostream
Autostream's Avatar
Oddometer: 5,833
You may be suprised to know it can be possible to improve cooling by slowing the water flow.
I used to see this with V8's a lot when I was a mechanic in a previous life...
Often the temporary solution to an overheating problem was to remove the thermostat. But when the actual fault was fixed and the radiator cleaned out or whatever, the engines would often overheat. This seemed to bebecause theater was passing through the radiator so fast it got no chance to let the heat go. Put a thermostst in and slow the water down and it would all be normal again.
The V8's were affected the most in the ones I sw as they usually had biggest waterpumps, but I have seen it on smaller rice burners too.
This may have nothing to do with the 990 changes, but sort of related to the subject...
Times are GMT -7.   It's 03:34 PM.
