04-21-2009, 05:52 PM
#61 |
Nomadic Man
Oddometer: 3,758
Oz road train.
![]() P.S. ImaPoser, ditto
Jay
04-21-2009, 06:07 PM
#62 | ||
adventure imposter
Oddometer: 14,834
Takes my issue of a fifth wheel to the extreme. You still don't have an enjoyable vehicle to drive around when camp is setup other than the bikes.
ImaPoser Save $5 when you open your own smugmug account. Use code: DeAGMxYPTdjUA Quote:
04-21-2009, 07:30 PM
#63 |
Oddometer: 2,102
I full-time in my bus with only a motorcycle as a runaround vehicle, and it works. 1 week's worth of laundry or groceries, no problem. Some days a car would be nice, but it's not necessary.
Some things I have learned (and may have already been stated in the thread): -Moving is a hassle, and more expensive than staying in one place for a longer perod. Not just fuel costs, but RV parks/campgrounds have better seasonal/monthly rates. -A smaller rig is better for dealing with gas stations, parking lots and those small downtown areas that we sometimes have to go through. Mine is at 29' bumper-to-bumper and not bad from a maneuverability standpoint. If you have more room, you'll just accumulate more stuff. A bigger rig will also limit your roads and campgrounds, use more fuel, and cost more to insure & register. The Escapees forum has lots of good threads by people considering or just starting the full-timing lifestyle. There's a lot to learn. Good luck Sean PS: Here's a link for dollies that allow you to tow moto(s) + car. For your growing list of RVing bookmarks.
Before enlightenment, change oil and adjust valves; after enlightenment, change oil and adjust valves. |
04-22-2009, 08:07 AM
#64 | |
Oddometer: 1,378
04-22-2009, 11:40 AM
#65 |
Oddometer: 2,073
I would suggest a fifth wheel in the 30' range with a 12' enclosed trailer to haul the bike and other stuff. I would pull it with a one ton single wheel diesel p/u.
My second choice would be a Motorhome pulling a 1/2 ton pickup with the bike in the back. You will need two vehicles to get around with. You could ride the bike to your WalMart Greeters job
ADV Relay Rider 08 (The Texas Connection) Ride Pooie Ride ![]() Don't stop riding until you get to the crash , you might save it! |
04-22-2009, 12:18 PM
#66 |
Radical centrist
Oddometer: 21,238
There is no one answer to this, but here's my solution:
40 ft. diesel pusher Bluebird Wanderlodge with a stout trailer: ![]() ![]() I am in the middle of modifying the trailer as we speak. Just added the tie downs to carry one bike across the front of the trailer, in front of the Rover: ![]() Next step? I lease a workshop in Jacksonville. We were on the road for 6 months last year but weren't prepared and, in fact, didn't take a bike along and unexpectedly wound up in some primo riding areas. So I'm sketching a modular shelter for the open trailer that will lift on and off. On the trailer is will double as an enclosed cargo trailer. Off the trailer the shelter should stand alone, have RV park compatible hookups, and serve as a portable workshop for my bikes. I may not be able to get everything into the portable workshop, but I do expect to be able to carry extra bikes, tools, and spares as we meander around the country a bit. Stay tuned. Added: Just FYI the motorhome is an honest 40 ft. from bumper to bumper and the trailer is 26.5 ft. So yes, I'm a bit over the 65' limit here in Florida Maneuverability? Not much. Newer motorhomes often have steering axles that cut in sharper then the one on this thing, so my turning radius is measured in miles it seems. You don't want to get into a position when you have to turn around, that's for sure. But I used to own a company hauling oversized loads so I guess that it just comes naturally. I haven't loaded the Rover and the motorcycle together and am going to be curious because that's going to push the Rover's weight back a bit, but with the Rover centered on the trailer everything rides VERY well bearing in mind that I keep the speeds down around 55-62mph anyway. I just did the 1,500 miles or so from Southern Texas to North Florida without any troubles and am looking forward to heading back. Added added: The early Bluebirds are real bargains, but you need to have some mechanical expertise and know you limitations. They are built of steel, not fiberglass. Most have a 10,000 lb. tow rating (mine is actually an early one with a 7,000 tow rating but we have upgraded it). There is a whale of a difference between something like a Fleetwood with a single rear axle and a 5,000 lb. rating and a bus with a higher tow rating.
PirateJohn -- http://www.PirateJohn.com IBA #7552 - SS1K in 2000 and 50CC in 2002 In the Laredo, TX area and always willing to help travelers escaping into Mexico.
PirateJohn screwed with this post 04-22-2009 at 12:30 PM |
04-22-2009, 12:27 PM
#67 | |
Radical centrist
Oddometer: 21,238
You would be surprised how important that is!
04-22-2009, 12:36 PM
#68 | |
Radical centrist
Oddometer: 21,238
According to the RV sites, California has been doing a big-time crackdown that essentially makes it impossible to operate a big bus and a long trailer without having a CDL, and that's a whole 'nuther can of worms.
04-22-2009, 01:15 PM
#69 | |
Oddometer: 936
04-22-2009, 03:09 PM
#70 |
All Hands on Deck!
Oddometer: 20,674
I have 27ft. class C with split beds in the back. For us it's a good length and works for an older unit with no slides. Has four separate beds. Hard to find in a Class C. The two captains chairs pivot and face into the RV when you are parked which opens up the living area.
We have a 14ft trailer and the two quads and 3 bikes all fit. This works good for a family of 5. Tight fit but it fits. ![]() I am setting up this rig to flat tow on all four and then I will have my 4x and the KTM out at the same time with the RV. Kids are getting older and all 5 units travel out on the trailer only a couple times a year. A bit sad as time is marching on... ![]() Another option is tow the Bug. But then you have no bike..It's always a trade off. ![]() What I like about my set-up is the various options....Because the RV is older and the Bug and Trooper are too....It's not expensive. Obviously we have to work within our budgets. Given more money I think I'd still do this cheaply..does not mean it has to be bad. But you need to be good at fixing things. I would not want to own this stuff If I could not work on it. There will be times you need help so keep that in mind. It can drain your pockets. Good Luck getting set-up for adventures and travels. These activities and spending time with friends are what brings most of us a bit'of Joy in our lives.
What is this Green Energy we are looking for? "Self Replicating Carbon Sequestering Bio-Nano Technology"................TREES are the Answer! |
04-22-2009, 07:32 PM
#71 |
Viel Spass, Vato!
Oddometer: 25,811
These are some really good comments. Many, not just I, are learning from this thread.
Gracie's Gold |
04-22-2009, 10:45 PM
#72 | |
my butt hurts
Oddometer: 332
04-23-2009, 06:56 AM
#73 | |
DON'T REWARD SUCKAGE
Oddometer: 2,520
National Socialists and American Nazis are living examples of the existance of a hominid class known scientifically as "pre-human" due to minimal development capacity for rational thought. |
04-23-2009, 07:11 AM
#74 | |
Oddometer: 1,378
One other benefit to owning your own RV which can't be expressed in monetary terms. You know how the RV is cleaned and who has slept in your bed. Not to mention that you can setup and keep your RV the way you like so that it becomes a true home away from home. |
04-23-2009, 07:12 AM
#75 | ||
adventure imposter
Oddometer: 14,834
True. When I was looking in to it, I had it figured at somewhere around 21 nights a year was the break even point of buying vs renting. Only issue is not being able to rent anything other than a basic stripper model RV. At the time, there was no place I coul dhave rented a toy hauler.
| Thread Tools | |
