Old 06-28-2004, 08:42 AM   #1
RAW OP
stamen in the sniffer
RAW's Avatar
Oddometer: 3,838
Tire plugging advice
Hey, guys and gals.
I just got my first tire puncture. I've never had to deal with plugging a tire, so . . . I'm gonna need some help.
The puncture was caused by a piece of bailing wire or something. When I pulled it out, it left a very clean, small hole.
Should I just use some of that sealing goo? Or what?
I've got an appointment at the dealership tomorrow to have the tire replaced, but it'd be nice to ride down there for the appt.
Get $5 off of your smugmug signup!
Enter code: sA9I4bmgcofRU
RAW is offline   Reply With Quote
Old 06-28-2004, 08:57 AM   #2
kildala2000
The GS Store.
kildala2000's Avatar
Oddometer: 2,056
Flat Tire.
Hey RAW,
Don't use the tire sealing goop. It makes a mess. Just use a tire plug. Simple easy and safe.
Since you are getting the tire replaced there is no need to do anything else.
Ride Safe.
Rick
Originally Posted by RAW
Hey, guys and gals.
kildala2000 is offline   Reply With Quote
Old 06-28-2004, 09:02 AM   #3
turkeyneck
Oddometer: 3
Tyre plugging advice
I am not a tyre engineer, however I have ridden thousands of miles over the least 20 yeaers on plugged tyres & never had a problem. Tyre companies say it is a no no but I believe that is the lawyers talking. I like the Stop&Go kit because it seems to have a plug that is larger inside the tyre(like a mushroom) T.Neck
T.Neck
turkeyneck is offline   Reply With Quote
Old 06-28-2004, 09:03 AM   #4
Rad
Just me
Rad's Avatar
Oddometer: 12,172
Use the plug kit, plug/glue, that came with yur GS. If it is a small hole you will need to ream it out a lot, then ream it out again, then again and again....... If ya don't, you will just rip the plugs try'n to get them in.
Rad is offline   Reply With Quote
Old 06-28-2004, 11:44 AM   #5
Frogman
Plunk Yur Magic Twanger
Frogman's Avatar
Oddometer: 36
I have limped many miles on a plug but never had the balls to keep the tire. Perhaps your dealer can install a more permanent plug that is guaranteed. Perhaps you should try writing to Metzler or Michelin and ask them whether a correctly installed plug is a death warrant.
If carrots are so good for your eyes, how come there are so many dead rabbits on the highway?
Frogman is offline   Reply With Quote
Old 06-28-2004, 12:18 PM   #6
Reprobate
Sarcasm Loading....
Reprobate's Avatar
Oddometer: 6,327
Link:
Tire plugging FAQ
I write the Amsterdam Assassin Series (suspense fiction), if you want to know more or support me by buying my work, please check out my website Tao of Violence and blog Amsterdam Assassin Series for news and links to the ebooks.
Reprobate is offline   Reply With Quote
Old 06-28-2004, 12:21 PM   #7
kildala2000
The GS Store.
Oddometer: 2,056
Tire Plug
Hello,
I have been a tire repair guy for years.
The best way to have a tire repaired is by having it pluged then taken appart and a patch installed on the inside. Then it will be guaranteed for life.
Just my 2 cents worth.
Ride Safe.
Rick
Old 06-28-2004, 01:25 PM   #8
Rad
Just me
Rad's Avatar
Oddometer: 12,172
Originally Posted by kildala2000
Hello,
Ride Safe.
Rick
There is about a zero chance any shop will do that in the States for a motorcycle
Old 06-28-2004, 01:42 PM   #9
Guzz
Gutless wonder
Guzz's Avatar
Oddometer: 4,912
Not true. Oddly, I had a BMW shop plug a tire from the inside. The tire had less than a 1,000 miles when I picked up a nail. Plugged it from the inside, and the tire eventually made it to 12,000 miles
Change must come from a barrel of a gun. -- Mao Tse Tung
When governments fear the people, there is liberty. When the people fear the government, there is tyranny -- Thomas Jefferson
Guzz is offline   Reply With Quote
Old 06-28-2004, 02:07 PM   #10
Reprobate
Sarcasm Loading....
Reprobate's Avatar
Oddometer: 6,327
And another one!
Thread on the UKGSER forum - clear detailed instruction of roadside puncture repair using the BMW repair kit!
Another UKGSER thread on using the Rema puncture repair kit with drawings.
Old 06-28-2004, 02:20 PM   #11
Rad
Just me
Rad's Avatar
Oddometer: 12,172
Wow! I've never heard of a bike shop patch'n tires, in the last few years.
Cool
Old 06-28-2004, 05:12 PM   #12
Davo
BMW Uber alles
Davo's Avatar
Oddometer: 142
I agree with rad that you should follow the instructions to the letter. The bit about replacing the tyre is up to you.
"Hey RAW,
Since you are getting the tire replaced there is no need to do anything else."
Hey Kildala,
Nothing personal mate, but by NOT using the glue this guy stands a very good chance of killing himself. Simple and easy but NOT safe. The road heat bonds the three compounds together, glue and the two in the plug.
On my RT my last rear tyre had 5 plugs (if you dont belive me speak to Garners motorcycles in Melbourne) as riding down the side of the freeway was by far and away faster but the road debree had you getting punctures every couple of weeks. Replacing the tyre was simply not an option. The plugs hold very well and out of 20+ BMW style plugs i have never had a problem. BTW Make sure you put the plug in long ways as it often tends to tear if you dont.
Some may think that 5 plugs is excessive but i have already experienced a sudden deflation at 85mph and on the RT it was no problem (big chunk of scrap metal). Your choice if you want to change the tyre and if your in doubt that you could handle a sudden deflation then get a new one.
stone cold sober
Davo is offline   Reply With Quote
Old 06-28-2004, 05:52 PM   #13
kildala2000
The GS Store.
Oddometer: 2,056
Tire repair
Hey Davo,
No offence taken Mate. Sorry for the misunderstanding.
You HAVE to use tire glue. This will bond the rubber to each other and will make a water tight seal. But too make it safe I would sure put a patch on the inside as well.
Hope that makes things clear.
Thanks Davo for catching that mistake.
Ride Safe.
Rick
"Hey RAW,
Hey Kildala,
Old 06-28-2004, 05:55 PM   #14
Davo
BMW Uber alles
Davo's Avatar
Oddometer: 142
Talking kildala
Your a gentleman and a scholar
stone cold sober
Old 06-28-2004, 06:03 PM   #15
ilmostro
Under Da Sea
ilmostro's Avatar
Oddometer: 29,256
Jam a manatee in there. They're good for plugging up all kinds of holes :):
I've got stay the fuck out of it written on a stone tablet in my bedroom. - Con Stapleton
ilmostro is offline   Reply With Quote
Times are GMT -7.   It's 08:24 PM.
