Old 06-27-2004, 08:52 PM   #1
Ryde2live OP
Live2ride BMW motorcycles
Oddometer: 55
Low pipe, full left bag mod questions....
Hello all, looking to tap everyones knowledge on my latest mod.
I want to move the pipe to the low mounting style and add a full size left bag.
What parts are needed to get this job done? (for a 2004 GS).
I'm wondering about the passenger peg mount/forward bag mount.
Does this need to be changed?
Lastly, will a set of bags off a 1996 R1100RS fit my 2004 GS with the low pipe mod?
Any help/advice is always much appreciated!
Adam Sefton
Denver, CO
Ryde2live Live2ride......BMW Motorcycles
Ryde2live is offline   Reply With Quote
Old 06-27-2004, 11:46 PM   #2
Bill on bike
Bill on bike's Avatar
Oddometer: 45
Check out the July issue of Motorcycle Consumer News, there is a story of just what you want to do. I just got the mag so I can't tell you what they did other than order the official BMW Police model pipe lowering piece and other stuff.
Bill Reitz
2006 BMW K1200LT
"Surf City USA"
that's Huntington Beach, CA
Bill on bike is offline   Reply With Quote
Old 06-28-2004, 01:16 AM   #3
Mick Fagan
Oddometer: 262
A friend has a 2003 Adventure and he just added a bent piece of pipe to his muffler and lowered the original. Manufacturing up a lower bracket to hold the muffler isn't too much of a hassle.
This may be a possibility for your machine.
Mick.
Mick Fagan is offline   Reply With Quote
Old 06-28-2004, 11:22 AM   #4
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,809
Yes, the full size bags from your RS will fit the GS once the pipe is lowered. I kept the bags from my '94 RS and have them on my '01 GS now. One problem with the MCN article referenced is if you do indeed want to install the full-size BMW System cases, they do not address the fact that the bag's lower forward support/mount point is different. On the GS half case, that bag mates to the stock passenger peg mount/forward bag mount. The full-size case's mounting point is about four inches inboard of that. The MCN article, that talks about installing the BMW GS Police bike pipe lowering kit, is great if you want to use aftermarket bags as there is no provision for an inboard bag mount (at least the article doesn't mention one).
I used a Wudo pipe lowering kit on my bike, which comes with an inboard bag mount. Alignment with the kit is a little off, as the rear end of the pipe would be angled way outboard if installed exactly per their instructions. I worked things around to get the pipe fairly parallel with the rest of the bike. The Wudo kit came with only one clamp, as they expect you to use the stock clamp/heatshield assembly as the other required clamp. That just looked too weird for me, and BMW wanted about $20 for their clamp, so a pair of hose clamps from the auto parts store for $1.39 completed my installation. Other than that, the Wudo kit is complete for your conversion. The front of the muffler with no heat shield is not very pretty, but I didn't buy this bike for its looks anyway. Good luck.
jdub is offline   Reply With Quote
Old 06-28-2004, 01:33 PM   #5
Mr. Clean
Mr. Clean's Avatar
Oddometer: 38
Wicked
Don't waste your $$ on the lowering kit. Just remove the muffler and replace it with an inch and three quarter ID tail pipe turn down...available at most automotive stores. It is held in place with a muffler clamp. Then, buy your accessory to use the larger inner pannier and you're in business w/o spending lots of money. And, your bike sounds a bit better
Chris "Mr. Clean" Lester
'02 GSA
Tucson, Arizona
Mr. Clean is offline   Reply With Quote
Old 06-28-2004, 09:53 PM   #6
Ryde2live OP
Oddometer: 55
MCN article
Thanks for the great responses. I'm going to go for it.
Does anyone have the July issue of Motorcycle Consumer News and would be willing to fax or scan and e mail the article about the low pipe/full bag.
I've tried to find it on a news stand and no one carries that rag.
Also, anyone have a BMW P/N for the left lower forward bag/peg mount to use for the full bag?
Adam Sefton
Denver, CO
Old 06-29-2004, 01:46 PM   #7
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,809
Just curious from those in the know - would doing this mod void the warranty on Ryde2live's shiny new '04 if the engine ever burped, spit, or puked?
Old 06-29-2004, 02:22 PM   #8
Rad
Just me
Rad's Avatar
Oddometer: 12,172
If yur worried, buy the BMW lowering kit for about $150
Rad is offline   Reply With Quote
Old 06-29-2004, 09:27 PM   #9
zouch
part-time wanderer
zouch's Avatar
Oddometer: 1,666
i've seen a bracket that covered this job for less than the BMW kit; by a company called 'ZMW', i believe.
then again, if you go with a Staintune low pipe, it'll include the necessary brackets for lowering and relocating the bag mount also.
cheers!
e
just a guy...
'02 GS Adv
zouch is offline   Reply With Quote
Old 06-29-2004, 10:08 PM   #10
Bill on bike
Oddometer: 45
I yanked the muffler off today. I bought a 1 3/4 ID 45 degree tail pipe for $3.99 and a muffler clamp for $.99.
I tried to post a pic unsuccessfully, maybe someone could give me a hint how.
Let's see, if the stock muffler weighs 22lbs. that means I can gain that much more. Alright! How much more can I remove!!!
Bill Reitz
2006 BMW K1200LT
"Surf City USA"
Old 06-29-2004, 10:10 PM   #11
Bill on bike
Oddometer: 45
Never mind about the help. Here's another pic:
Bill Reitz
2006 BMW K1200LT
"Surf City USA"
Old 06-29-2004, 10:52 PM   #12
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,520
here's the thing, the full-size RT bag needs a different anchor point, the stock GS point (off the passenger pegs) is too far out. You can fabricate something easy enough.
I went with Staintune full kit low pipe at 4000 miles back in Y2K. Sounds great, holds up, and had the correct bracket. And with the larger bag, you can carry hella more stuff, like extra hair pomade for longer trips away from home.
The high pipe, skinny bag is the stupidest thing BMW ever put on a bike.
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 06-29-2004, 10:58 PM   #13
Roamin
Roamin Hands
Roamin's Avatar
Oddometer: 158
HAHAHA...too funny.
You took off the heavy 22 lb. tailpipe and "improved" the noise but you left the 30 lb catalytic that would improve your mid range power if you removed it and reducing the heat at the drive train a lot. Seems a good choice to me....
Roamin is offline   Reply With Quote
Old 06-30-2004, 12:31 AM   #14
Vampire
Vampire's Avatar
Oddometer: 138
Staintune make a lower muffler, and supply the modified bracket to take the full size BMW case on the left. It is a relatively cheap option.
Wayne
I refuse to grow old until I grow up.
Vampire is offline   Reply With Quote
Old 06-30-2004, 11:11 AM   #15
bpeterson
I just tweeted it
bpeterson's Avatar
Oddometer: 1,030
anybody know of a place that sells just the staintune pannier attachment bracket, without the purchase of a new exhaust? I don't mind taking off the current exhaust and using a small piece of automotive exhaust. I didn't want to go through the hassle of fabricating a new mount for the standard case though if one was available for a reasonable price.
Brian
'14 KTM 350 EXC-F
'04 GS Adv
'02 DR-Z 400S - for sale soon
'06 TE 610 - sold
bpeterson is offline   Reply With Quote
Times are GMT -7.   It's 01:20 AM.
