Old 04-23-2009, 03:19 PM   #1
396427454 OP
Oddometer: 27
F800GS - starter spins when engine killed
09 800gs - when killing the engine with either the kill switch or the ignition key the starter spins briefly. the first time this happened, I thought I had fat fingered the start button while turning the kill switch - but no joy - I've experimetned now several times and it is clearly not my fat fingers - besides, the exact same condition occurs when useing the key to kill the engine.
Problem only occurs when stopping a running engine - does NOT occur when moving the kill or ignition swictch to the on positions. Occurs reliably 100% of the time.
Anybody else see this? Dealer is stumped
396427454 is offline   Reply With Quote
Old 04-23-2009, 04:41 PM   #2
Barney Fife
Oddometer: 68
Welcome to advrider. You might get more responses in Beasts. This sticky in GSpot explains:
http://www.advrider.com/forums/showthread.php?t=281007
Good luck getting it figured out.
Barney Fife is offline   Reply With Quote
Old 04-26-2009, 11:02 AM   #3
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Moving this over to Beasts.
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 04-26-2009, 11:11 AM   #4
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,710
My Vstrom does a similar thing. Kill the ignition and it sounds like the starter spins for a split second after or just a moment before the motor stops spinning.
I think it's the sprag clutch getting engaged and the motor itself spinning the starter for a split second.
Does it sound something like this?
Not the last sound in the video, but the second to last. The last sound, like 3-4 rapid clicks, is the Idle Control Solenoid re-setting itself.
Boon Booni screwed with this post 04-26-2009 at 11:34 AM
Boon Booni is online now   Reply With Quote
Old 04-26-2009, 02:15 PM   #5
rustynutz
Useless sod
Oddometer: 19
I'm not sure what it is, but it is absolutely normal, so you can relax.
rustynutz is offline   Reply With Quote
Old 04-26-2009, 02:16 PM   #6
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Just listened to the sound in the video and listened to my bike. Mine does it, and has always done it. I've also heard it on two other F800GS's and one F650GS twin. I'm willing to go so far as to say it's normal.
Old 04-26-2009, 07:37 PM   #7
Crilly
Oddometer: 786
Yeh, I had to ask the dealer about mine doing it. Said it is normal.
Crilly is offline   Reply With Quote
Old 04-27-2009, 01:01 PM   #8
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 4,074
If it is the same sound as the one recorded on the V-Strom, then I would say my Dakar 650 does make this sound as well, from day 1, three years ago. Always thought it was normal, though never liked it.
Lion
Lion BR is offline   Reply With Quote
Old 04-27-2009, 06:22 PM   #9
GB
Mod Squad
GB's Avatar
Oddometer: 56,767
If it's the next to the last sound in the video, all thumpers do that too and it's not the starter.
Old 04-28-2009, 05:57 AM   #10
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,417
Question
Maybe when the engine stops, it spins backwards a little, spinning the starter? I assume the starter uses a starter clutch? Compression makes it turn backwards maybe 90 degrees?
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 04-28-2009, 06:00 AM   #11
Bike4Fun
Smooth IS Fast
Bike4Fun's Avatar
Oddometer: 1,782
mine does it too!
Bike4Fun is offline   Reply With Quote
Old 04-28-2009, 07:34 AM   #12
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,710
It's possible. Valve springs pushing back on can make the motor rotate, and spinning backwards would engage the starter clutch.
Now that I'm listening for it, my Strom doesn't do it every time it shuts down. Maybe 75% of the time.
Old 04-28-2009, 12:44 PM   #13
Bayner
Oddometer: 1,603
Auto decompressor clack as the RPMs drop off?
Bayner is offline   Reply With Quote
Old 04-28-2009, 04:50 PM   #14
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Oh, noooooooo! Not another clack!
Nate in N.E.
Old 04-28-2009, 08:32 PM   #15
Teflon2
Oddometer: 27
Mine does it too. My 04 1150adv did it as well.
Teflon2 is offline   Reply With Quote
Times are GMT -7.   It's 03:09 AM.
