Old 10-12-2009, 11:05 PM   #46
DidYouSeeThat
Uhhhh... Where?
DidYouSeeThat's Avatar
Oddometer: 178
I just ordered the 15T. I am looking forward to slowing down on the technical stuff (everything is technical for me )
Dang, I hand is tire from pulling in the clutch. I have stalled because the 1st gear is just too tall. OK cry cry cry... ;)
Of course, I'm used to a KLX250 that has a granny first gear - that I Love.
I'm not a top speed guy anyways, I love the 10-30mph stuff off road.
I'll report back when the 15T is on!
Whoa... DidYouSeeThat!.. Uhh.. Where?...
www.slapdrum.com
09 F800GS - Yel/Bck, IICE Air, Bars, MotoSport Bags
08 TE250 - with 300cc Kit
10 Rubicon
DidYouSeeThat is offline   Reply With Quote
Old 10-14-2009, 07:10 AM   #47
F800 Rob
MotoInsight
F800 Rob's Avatar
Oddometer: 924
Originally Posted by Bushwhacker
I have a spreadsheet that was originally downloaded for another bike that I have modified for the F800GS that will show changes in speed/rpm based on sprocket or tire changes.
If interested pm me with your email address and I will send it to you.
Here is a screen print -
If you want to send it over to me, I'll post it up on F800Riders.org for all to download.
rob at f800 riders dot org
Rob Werksman - Owner, Motorcycle Insight, LLC
Adventure Motorcycle Depot | S1000RR Depot | F800 Depot | Twalcom USA
North American Importer - Globescout, Twalcom, Wild@Heart, Hornig, AC Schnitzer (Motorcycle)
F800 Rob is offline   Reply With Quote
Old 10-14-2009, 06:08 PM   #48
F800 Rob
MotoInsight
F800 Rob's Avatar
Oddometer: 924
Bushwackers's gearing worksheet is now available here:
http://f800riders.org/forum/index.php?pageid=gsgearing
No download, no excel required.
(sorry Wildman - momentary brainfart!)
F800 Rob screwed with this post 10-16-2009 at 09:54 AM
Old 10-14-2009, 11:24 PM   #49
Wildman
Man of Kent
Wildman's Avatar
Oddometer: 16,058
Originally Posted by F800 Rob
Wildman's gearing worksheet ...
Nothing to do with me.
"Every county of England, every country of Europe and every (part of every other inhabited) continent of the Earth" ... 80% complete!
Counties: 39 of 39 - done!
Countries: 36 of 42; last up, Portugal, next up, Iceland
Continents: 5 of 19; last up, North America (USA), next up, Central America (Cuba)
Wildman is offline   Reply With Quote
Old 10-15-2009, 05:40 AM   #50
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 671
From the factory the clutch friction point is WAY out there. I've adjusted the clutch cable (at the engine case) and have found moving the clutch engagement point closer to the grip has made low speed handling easier and given my left hand a break.
Ride on.
:: Furious Basterds: Velox, Vehemens, Oblivio
:: "For those who don't understand, no explanation is possible. For those who do, none is necessary."
Bartron is offline   Reply With Quote
Old 10-15-2009, 10:05 PM   #51
DidYouSeeThat
Uhhhh... Where?
Oddometer: 178
Hmmm Good to know. I'll try that.
www.slapdrum.com
10 Rubicon
Old 10-16-2009, 09:21 AM   #52
YetiGS
Random Hooligan
YetiGS's Avatar
Oddometer: 6,168
Seems that would just put more slack in the cable. No?
-Scott-
Semper Fi
'04 BMW R1150GSA, '97 BMW R1100GS (For Sale), '08 KTM 450EXC-R, '04 KTM 625 SXC
"A pessimist thinks all women are bad. An optimist is one who hopes they are." Chauncey Depew
YetiGS is offline   Reply With Quote
Old 10-16-2009, 10:02 AM   #53
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 671
that is indeed what you are doing BUT by doing so you increase the amount the spring-loaded clutch cam needs to turn to engage. The cam is spring-loaded and takes up all the slack created. Hence, you move the friction point closer to the grip by increasing the amount the clutch lever needs to be pulled in to reach the friction point. For someone who uses two fingers on the clutch and brake, this made life much easier and made slow speed control easier.
As usual, YMMV.
Ride on.
Old 10-16-2009, 12:03 PM   #54
YetiGS
Random Hooligan
YetiGS's Avatar
Oddometer: 6,168
As usual, YMMV.
Ah. On previous bike's I've owned you could only let out so much slack. I'll have to check that out.
-Scott-
Semper Fi
Old 10-16-2009, 01:30 PM   #55
classyfun
Oddometer: 41
I just did mine and took it for a ride it does work. The clutch is a firmer pull on the lever.
classyfun screwed with this post 10-16-2009 at 01:48 PM
classyfun is offline   Reply With Quote
Old 10-16-2009, 04:53 PM   #56
JRWooden
Oddometer: 3,434
Does the clutch fully disengage?
It would seem that at some point adding more slack would reduce the actual throw enough that the clutch would not completely disengage when the lever was pulled all the way making the tranny hard to shift ... is anybody seeing that problem?
Old 10-16-2009, 04:58 PM   #57
Bartron
Bike Punisher
Bartron's Avatar
Oddometer: 671
Certainly a possible complication. A gradual adjustment should yield the desired results. There's a wide range of adjustment possible.
Ride on.
Old 10-30-2009, 09:20 PM   #58
DidYouSeeThat
Uhhhh... Where?
Oddometer: 178
I stalled the 15T
Ohhhh I rode the BMW with the 15T. Wow, it is smoother… I don’t understand why, but this is how it should have come stock, this is nice.
I thought it would make it jerkier. The power comes on strong but more evenly. Snappy throttle is solved!
Anybody know why this works. Is there such thing as too big a gear on the front and that causes the snappy-ness...
I’d love to hear a physics type explanation if any body has that training.
15T... I love it!
www.slapdrum.com
10 Rubicon
DidYouSeeThat screwed with this post 10-30-2009 at 10:49 PM
Old 10-31-2009, 02:12 PM   #59
wizze
Wizze = Wise
wizze's Avatar
Oddometer: 668
Where is everyone getting their 15t sprockets?
wizze is offline   Reply With Quote
Old 10-31-2009, 02:16 PM   #60
Wildman
Man of Kent
Wildman's Avatar
Oddometer: 16,058
I stalled the 15T
I thought it would make it jerkier. The power comes on strong but more evenly. Snappy throttle is solved!...
Good to know!
Times are GMT -7.   It's 10:20 PM.
