Old 04-28-2009, 08:48 AM   #1
Doc.Snyder OP
Doc.Snyder's Avatar
Oddometer: 2,012
SIXO - Speedo, Tacho, ...
Has anyone seen / used this?
http://www.motobau.de/cat-equip/rallye/sixo/main.html
Never stop exploring
Doc.Snyder is offline   Reply With Quote
Old 04-28-2009, 09:20 AM   #2
Worone
Rock Slinger
Worone's Avatar
Oddometer: 301
Looks great, how easy is it to hook up? What is the backlight like for night driving?
"Now you hit him Margie, my arm is tired" ~ Vinnie Barbarino
2007 KTM 950R SE
Chicks Dig Scars
Worone is offline   Reply With Quote
Old 04-28-2009, 09:34 AM   #3
Doc.Snyder OP
Doc.Snyder's Avatar
Oddometer: 2,012
Tried to translate the specs... sorry for my english ;-)
Specs:
-Automatic Display Illumination
-Automatic Contrast Adjustment
-Waterproof
-Shockproof
Functions:
-Speedo
-Rev Counter digital
-Date
-Time
-Overall KM / Miles
-Tank KM / Miles
-2 individual km / mile counters
-Voltage
-Control Lights:
-Idle
-Blinker
-High Beam
-Voltage
-Oil Pressure
external sensors (optional):
- Watertemp. w. max. memory
- Oiltemp. w. max. memory
- Water and Oil are being monitored and processed constantly
- Air Temperature w. min & max memory
Special Functionality for Rallye and Racing:
- 2 Split Trip Counters (correctable & resettable)
- Overall Distance
- Option to connect a shift flash (?)
- Lap counter
- Hour counter
- Service Hour counter resettable
Handlebar Remote switch available
Old 04-28-2009, 09:55 AM   #4
HappyGoLucky
Goeie Grys Giftige Gert!
HappyGoLucky's Avatar
Oddometer: 4,311
Your english is perfect - nice unit!
Be true....to yourself
HappyGoLucky is offline   Reply With Quote
Old 04-28-2009, 10:07 AM   #5
Doc.Snyder OP
Doc.Snyder's Avatar
Oddometer: 2,012
A bit expensive, though..
Is there a cheaper way to add a rev counter to the SE?
Does the KTM Accessory Rev Counter work on 950 / twins?
Old 04-28-2009, 10:09 AM   #6
HappyGoLucky
Oddometer: 4,311
I found that the Trailtech Vapor (which I got for rpm specifically) was all over the place. After tech support, and different methods of wrapping the rev wire, the best I could get was an estimate within 1500 rpm odd of where the engine actually was. Beautiful, but waste of time.
Old 04-28-2009, 10:10 AM   #7
Worone
Rock Slinger
Worone's Avatar
Oddometer: 301
How about the 690 instrument cluster?
2007 KTM 950R SE
Chicks Dig Scars
Old 04-28-2009, 10:18 AM   #8
Doc.Snyder OP
Doc.Snyder's Avatar
Oddometer: 2,012
so how does one set the idle (1400rpm) when there's no way to get correct revs?
Old 04-28-2009, 04:14 PM   #9
ktm950se
ktm950se's Avatar
Oddometer: 1,385
OK, who's going to be the first around here to try one of these?
I need reassurances
ktm950se
ktm950se is offline   Reply With Quote
Old 04-28-2009, 04:54 PM   #10
K2m
....58....
K2m's Avatar
Oddometer: 2,238
http://translate.google.com.au/trans...%3Den%26sa%3DG
This may help
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 04-28-2009, 05:14 PM   #11
HappyGoLucky
Oddometer: 4,311
A good ear and familiarity with the LC8
Old 04-28-2009, 09:47 PM   #12
Doc.Snyder OP
Doc.Snyder's Avatar
Oddometer: 2,012
It's a very very interesting device. But you need to have at least basic programming knowledge ... You can basically program any feature into the device - or just use the standard features... Very very complex little device...
Installation:
http://www.sixo.de/ASSEMBLY/assembly.htm
Video:
http://www.sixo.de/DOWNLOAD20/sixo_divx_m.avi
Doc.Snyder screwed with this post 04-28-2009 at 10:00 PM
Old 04-29-2009, 05:43 AM   #13
JanB
JanB's Avatar
Oddometer: 233
I use it on my WR400 and used it on my DR800... and liked it a lot!
Worked flawless, but requieres a little skill in mounting and wiring. I got an earlier model, for which Ii should do a Software-update. Dont know todays prices, but compared to the ICOs it was cheap 3 years ago!
http://www.jbing.de/gallery2/main.ph...serialNumber=2
http://demjansein.wordpress.com
JanB is offline   Reply With Quote
Old 04-29-2009, 07:05 AM   #14
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 21,326
I had Exactly the same experience with the Vapor
unaweep is offline   Reply With Quote
Old 04-29-2009, 02:26 PM   #15
charlie264
charlie264's Avatar
Oddometer: 8,493
I didn’t know these pieces of kit existed, I like! I was toying with the idea of replacing the instrument panel on my SE with the new Adv/Rc8's digital displays. Regarding the sporadic rpm readings, are they connected pre rectifier?
One thing that bugs me with the SE is that the mph and mpg seem to separately calibrated, any Linux programmers in here who could write some new firmware?
Times are GMT -7.   It's 05:19 PM.
