Old 05-01-2009, 06:22 AM   #16
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,881
Cool product, Max.
Grossly inaccurate speedo readings have long bothered me. You might consider expanding this product line into other bikes. I realize that perhaps not too many use the abs ring to measure velocity, but some might.
Gracie's Gold
Lobby is offline   Reply With Quote
Old 05-01-2009, 10:05 AM   #17
Max Kool OP
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
Originally Posted by Gadget Boy
Max,
On the X Challenge, I changed the speedo setting from an 18" rear wheel to a 17" rear wheel and the speedo is bang-on GPS accurate.
I know, so did I (remember who came with that idea some two years ago ). However, on the Xmo and Xco you can't set the odo low enough...
Max Kool is offline   Reply With Quote
Old 05-02-2009, 06:30 PM   #18
Somber
Oddometer: 350
hrmmm... last time I ran with my GPS it seemed I was pretty dead on on my X-Co... I don't have stock tires (TKC 80s now), but it is the stock wheels...
I'll try to remember to doublecheck sometime soon - don't normally have my GPS mounted up for my weeks worth of commutes, but I don't think I have this problem to solve on my bike, I wonder if they made another undocumented running change at some point pre or during the 09 build...
Somber is offline   Reply With Quote
Old 05-03-2009, 11:55 PM   #19
Max Kool OP
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
Hmm, although the first batch was gone within a few weeks after we invented they worked really well on the XCo, I get the idea there isn't much interest in a new batch.
However, your input is greatly appreciated (I wouldn't want to get stuck with 10 or 20 useless speedo rotors)
Old 05-05-2009, 10:59 PM   #20
mbfj40
Oddometer: 174
I'm in for one on my '08 country, The "electronic" re-cal kits are $100 plus. I'm sure that if you ran a batch you could move them pretty easy. Just keep the the threads "bumped" up to keep em current for all to see or they get out of view pretty quick. keep it front and center.
thanks and ride safe, mike
mbfj40 is offline   Reply With Quote
Old 06-28-2009, 10:21 PM   #21
Bora20
Oddometer: 855
I like it, but I need to test out my bike with the GPS first. Just setting to 17" rear might do it for me.
Dan
2010 KTM 530 EXC Champion Edition - factory street legal
Pix - http://Bora20.smugmug.com/
Bora20 is offline   Reply With Quote
Old 06-29-2009, 01:14 AM   #22
Max Kool OP
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
At the moment it doesn't look like we're going to do a new run. I still have 1 ring left though. So if anyone is interested, pls email me.
max@xtankteam.com
Old 07-02-2009, 07:32 AM   #23
Max Kool OP
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
Sorry guys, I'm though all of them now.
I am willing to run a new batch, but I have to be quite sure if someone wants one or not. I wouldn't want to end up with 15 rings in the shed that nobody wants....
Old 10-22-2009, 12:37 AM   #24
Max Kool OP
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
Bump!
anyone still interested in this farkle? I could be convinced to have a new batch being run...
With like 10 to 15 people we can start the mill again.
Old 07-08-2010, 06:03 AM   #25
leafman60
Oddometer: 1,959
Im 99 percent sure I'm in. I will confirm tomorrow or later today.
leafman60 is offline   Reply With Quote
Old 07-09-2010, 08:46 PM   #26
leafman60
Oddometer: 1,959
Okay, I'm in. Tell me when and where to send the $$$$$
Old 07-11-2010, 05:19 AM   #27
leafman60
Oddometer: 1,959
Old 07-12-2010, 03:24 AM   #28
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,661
So, how do you change to tire size indicator on the Xchallenge?
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 07-12-2010, 03:48 AM   #29
Max Kool OP
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
My speedo is inaccurate, can I change it?
* So to all of us who want to adjust their wheel size in the speedo, watch this.
1. Remove the seat, and the right hand side panel.
2. Remove the ignition key if you haven't already done so (really important!!).
3. Unbolt the negative lead of the battery.
4. On the dash, hold down the "set" button and connect the battery.
5. Keep holding down the "set" key while the dash starts to count down from 15 to 1(the bike will not explode).
6. Next the dash is going to toggle between three rear wheel size choices. You can let go of the "set" button.
7. When the dash shows you the preferred rear wheel size press "mode".
8. Done. Now the new wheel circumference is set.
* (note, this is a mutliple choice question, three options. You don't get to set the wheel size on a per mm base)
The above procedure works perfectly for the Xch, but the other two are allready on a lower wheelsize.
* If by any accident you've chosen the wrong wheel size, insert the ignition key once into the ignition lock, and remove it again. Remove the battery terminal and start all over again.
* Once satisfied, Connect the battery solidly, reinstall the side panel and the seat
Old 07-12-2010, 04:02 AM   #30
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,661
David Hunn:
Times are GMT -7.   It's 03:04 PM.
