Old 07-13-2010, 01:42 AM   #31
Max Kool OP
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
Ok guys, word is out, a new run is being made!
We need a few more weeks to get them out (production planning, summer holidays).
Price per ring (you need only one btw) will be €39,50 ex p&p, which according to the exchange rate is somewhere around 50 bucks.
Please pm me and "Erik RS" if you want one. Details will follow through pm's
Max Kool is offline   Reply With Quote
Old 07-13-2010, 11:38 PM   #32
Somber
Oddometer: 350
PM sent, thanks for doing another run...
Somber is offline   Reply With Quote
Old 07-14-2010, 01:08 PM   #33
Max Kool OP
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
Any know btw if the part numbers for the front rotor is the as the rear one?
Old 07-29-2010, 02:12 PM   #34
Max Kool OP
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
Ok guys, with special thanks to Leafman60, a new run has been completed.
The new rings are in, and ready to be sent out. Price is set to be €39,50 plus €3,50 for p&p worldwide. Check the currency guys, Euros ;-) Please send your Paypal donation to pp.account @ hotrodwelding.nl with reference to:
XCh Ring 44z
Your name and address
Cheers!
Max
Old 07-29-2010, 02:55 PM   #35
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
Oh and btw: they're made of (ferromagnetic) stainless instead of galvanized steel this time
Three Wheel Fever forever
Xtankteam™
Proud sponsor of the Sibirsky Extreme Project
Erik RS is offline   Reply With Quote
Old 08-04-2010, 11:55 PM   #36
Max Kool OP
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
Anyone already received and fitted the ring? Keep us posted!
Old 08-24-2010, 09:31 AM   #37
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,720
Bump this thread for the guys who need the ring. I have a challenge so Im going out to the garage and do this right now!
Originally Posted by Max Kool
My speedo is inaccurate, can I change it?
* So to all of us who want to adjust their wheel size in the speedo, watch this.
1. Remove the seat, and the right hand side panel.
2. Remove the ignition key if you haven't already done so (really important!!).
3. Unbolt the negative lead of the battery.
4. On the dash, hold down the "set" button and connect the battery.
5. Keep holding down the "set" key while the dash starts to count down from 15 to 1(the bike will not explode).
6. Next the dash is going to toggle between three rear wheel size choices. You can let go of the "set" button.
7. When the dash shows you the preferred rear wheel size press "mode".
8. Done. Now the new wheel circumference is set.
* (note, this is a mutliple choice question, three options. You don't get to set the wheel size on a per mm base)
The above procedure works perfectly for the Xch, but the other two are allready on a lower wheelsize.
* If by any accident you've chosen the wrong wheel size, insert the ignition key once into the ignition lock, and remove it again. Remove the battery terminal and start all over again.
* Once satisfied, Connect the battery solidly, reinstall the side panel and the seat
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 09-15-2010, 12:51 AM   #38
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
Thumb Running out
Only 2 left in stock of this batch
Xtankteam™
Old 09-15-2010, 10:52 AM   #39
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,590
sold!
PM sent! phew! just in time, I just bought wheels yesterday!
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 09-17-2010, 12:19 AM   #40
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
One down, one to go
Xtankteam™
Old 09-28-2010, 10:00 AM   #41
snooker
snooker's Avatar
Oddometer: 1,590
Well they are NOT the same. Is yours made to fit only the rear wheel (is this where the speedo pickup is?), or do you know if it will fit either?
And actually I just received your ring and really I just bought it because I got a 2nd set of wheels and the front wheel came without a sensor ring, which I need for the ABS to work. I didn't really care about the speedo accuracy, I just wanted a ring and figured it would fit either wheel.
So now I'm not sure what to do. I was planning to put my OEM rear ring on the front wheel (will it fit???), and put your new one on the rear. ?
Old 09-29-2010, 12:48 AM   #42
Max Kool OP
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
I honestly can't tell you, but if you have both why not compare them youself?
Number of boltholes, number of slots, ring diameter, etc.
Old 09-29-2010, 09:12 AM   #43
snooker
snooker's Avatar
Oddometer: 1,590
yep I'll do that, just don't have the new wheels yet and won't pull my stock wheels off until they arrive. Was hoping you would just know from your vast experience.
Please confirm that your ring is for the rear, and that this is where the speedo pickup is?
Old 10-01-2010, 12:08 AM   #44
Max Kool OP
Xtankteam™
Max Kool's Avatar
Oddometer: 3,240
Confirmed.
the speedo ring we're talking about in this thread is a customised slotted ring to replace the stock one BMW fits to the rear wheel. This ring is being used for both the speedo and the ABS (same pickup afaik).
Practice has proven this recalibrated ring will not interfere with the ABS system. No faulty warning light, no strange behaviour.
Old 10-04-2010, 11:10 PM   #45
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
SOLD OUT !
Xtankteam™
Times are GMT -7.   It's 10:03 PM.
