Old 04-29-2009, 08:10 PM   #1
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Question Mounting tires on F800GS question....
So I'm going to mount some TKC-80's on my F800GS. I notice that on the front and rear axles have hex head openings on one side. They're huge! what size are they? Do I need a hex wrench for them? Any specific tools I need for a tire change on this bike?
Thanks,
Old 04-29-2009, 08:22 PM   #2
]I)Money
D NOT I
]I)Money's Avatar
Oddometer: 3,737
The hex portion of my spark plug socket fit the front. I didn't even bother with it on the rear.
Originally Posted by wxwax
Yes, but everything you've ever posted in the basement indicates that you're certifiably crazy, so you don't count.
"Another road remains, but it provides no more. It can only take us away"
]I)Money is offline   Reply With Quote
Old 04-29-2009, 08:24 PM   #3
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,711
I didn't need anything.
On the front, the pinch bolts will hold while you losen up the hold in bolt. The manual says to do it in reverse, but I don't see any particular reason why it would need to be that way.
On the rear, the chain adjust slider was part of the axle, or at least came apart together.
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 04-29-2009, 08:42 PM   #4
]I)Money
D NOT I
]I)Money's Avatar
Oddometer: 3,737
slider
It's not part of it, but it will come off with it.
Good idea on reversing the order on loosening the pinch bolts.
Old 04-29-2009, 09:02 PM   #5
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Thanks guys. I'm not going to bother with balancing them. I'm just going to throw them on and ride. Did you guys balance them?
Old 04-30-2009, 04:25 AM   #6
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,711
I didn't balance them. Seem okay. YMMV.
David
Old 04-30-2009, 05:49 AM   #7
Desert Dave
Enjoying the moment
Desert Dave's Avatar
Oddometer: 2,738
Did yours come apart in seperate pieces?
My axle came out with the left side chain adjuster attached, wasn't sure if it was stuck or designed that way, so I looked up the part and it's sold as a single piece.
Regardless, no hex needed.
See what I've been up to! Ongoing Ride Report
Desert Dave is offline   Reply With Quote
Old 04-30-2009, 06:00 AM   #8
Desert Dave
Enjoying the moment
Oddometer: 2,738
I always balance street tires (meaning being ridden on the street),always have, an besides it only takes about 5 minutes to do.
You could probably get away without doing it, as others have reported doing...er not doing . You'll KNOW if you needed it when you get to highway speeds and one end is bouncing like you're riding on small washboards, but that's usually a fair amount out of balance. If you're just out a little you'll probably not even notice, my rear TKC took less than an ounce of wheel wieghts to balance. I've heard out of balance tires will wear quicker, and uneven, maybe cause cupping sooner, but I can't say since mine are always balanced. And besides that would be a hard one to quantify with different conditions and amounts out of balance.
It's so easy to do so why not? But if you don't you'll probably never notice unless it's way off.
Old 04-30-2009, 07:01 AM   #9
tmex
tmex's Avatar
Oddometer: 2,039
I'm with Dave on this one. A rotating mass should always be balanced. Don't be lazy.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 04-30-2009, 08:24 AM   #10
Roonie
Roonie's Avatar
Oddometer: 389
My TKC's took a lot of weight to balance them. Basically I kept the stock weight and ended up adding more as it was in same location. I know without it I would for sure feel it. I had a heck of a time with the rear battlewings getting them off. Then in my haste I realized I hadn't completely deflated the tube so it wasn't letting the bead break etc. I will blame it on first time changing a motorcycle tire.
Roonie is offline   Reply With Quote
Old 04-30-2009, 08:30 AM   #11
]I)Money
D NOT I
]I)Money's Avatar
Oddometer: 3,737
No, you're right, I was thinking about the other side, which fell out when I took the nut off.
Old 04-30-2009, 08:49 AM   #12
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
I ordered DynaBeads. Easy installation. Better than weights.
http://www.innovativebalancing.com/HowItWorks.htm
https://www.bestrestproducts.com/c-100-dyna-beads.aspx
Old 04-30-2009, 09:13 AM   #13
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 817
I put on a set of Conti Trail Attacks. They needed quite a bit of weight to balance. Will try balancing the wheel by itself next time, just to see what's up.
Bucko is offline   Reply With Quote
Old 04-30-2009, 10:00 AM   #14
The Griz OP
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Does anyone have experience with the DynaBeads?
Old 04-30-2009, 12:04 PM   #15
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
Agreed.
Balancing is so easy and fast, why not do it?
If I'm not swapping tires back and forth alot (thus balancin alot), I sometimes pull wheels off after 5-6k miles just to re-balance them.
bxr140 is offline   Reply With Quote
Times are GMT -7.   It's 04:44 AM.
