Old 04-30-2009, 11:07 AM   #1
giodog2000 OP
Oddometer: 245
Adjusting suspension f650gs: Want to learn.
Ok , it's about time I learn about suspension. Hi all. I don't get it. I play with the suspension adjustment on my new 650 gs (twin) and I can't see a difference. Maybe because I'm not use to this bike yet but I would like to understand what happens when I play around with both adjustments. Lets say I tighten the front suspension , what should I do with the other adjustment (rear) . What is the direct effect ? THanks for all your help.
First one out..last one in.
2011 KTM 690 Enduro R
2009 KTM 530 XC-W
giodog2000 is offline   Reply With Quote
Old 04-30-2009, 02:34 PM   #2
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,917
You're playing with the preload of the forks and rear spring. Basically they are ride height adjustments. You use them to set your suspension sag. They have a limited range of adjustability, after that you need to install heavier or lighter springs.
Heres a link to some basics. LINK
I think your GS also has rebound adjustment in the rear shock. That basically controlls how quickly the shock extends back from a compression.
Old 04-30-2009, 03:04 PM   #3
giodog2000 OP
Oddometer: 245
suspension
Thanks for the link .....and answer ;-)
2009 KTM 530 XC-W
Times are GMT -7.   It's 11:58 PM.
