Old 05-03-2009, 07:03 AM   #61
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Mine is utterly.
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 05-03-2009, 07:15 AM   #62
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,734
Originally Posted by WoodWorks
Im from Jerzey so waz dat mean Dave ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 05-03-2009, 07:31 AM   #63
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Oh man, I just HATE having to explain my lousy jokes.
Quite = utterly (also totally, absolutely, entirely, etc.)
Quiet = noiseless.
David
David
--Curly
Old 05-03-2009, 07:32 AM   #64
DockingPilot
Oddometer: 9,734
ah ha. OK then, I small a rat.
Quiet = noiseless.
David
Frank Reinbold
Old 05-03-2009, 10:42 AM   #65
dukedar
60 easy payments!
dukedar's Avatar
Oddometer: 340
I hope that it works out for you Griz.
Now I am wondering about the clutch noises on mine. In your break-in thread the consensus was that some clutch noise was normal...
At what point do we get concerned...
Darren
'09 BMW F800GS
dukedar is offline   Reply With Quote
Old 05-03-2009, 10:55 AM   #66
DockingPilot
Oddometer: 9,734
Poll it. Clutch chatter, when hot, yes or no.
CHECKED AT OPERATING TEMPS !
Cold, it's quiet. Hot it's not.
Frank Reinbold
DockingPilot screwed with this post 05-03-2009 at 03:44 PM
Old 05-03-2009, 02:03 PM   #67
JRWooden
Oddometer: 4,267
Clutch adjustment nuts loose .......
So all this clutch talk made me go out and check mine...
I had noticed a bit more slack in cable so figured it was time to adjust ...
I noticed two things:
1) the adjusting nuts were only finger tight - that sucks.
So y'all might want to check yours... I would think if they vibrated loose they would put MORE slack in the cable but who knows....
I don't know if installing the clutch cable is a dealer operation or not, but they should have been tighter than I found them ...
2) 12mm wrench would not go on the nuts, while a 13mm was very loose.
1/2" english wrench (which works out to 12.7mm) fit pretty well still just a bit loose. WTF is up with that?
Jim
Old 05-03-2009, 02:58 PM   #68
Stuntman
Stuntman's Avatar
Oddometer: 677
Poll it. Clutch chatter, yes or no. So far I got 2 no's. Dave and My friend George.
Mine operates like a clutch should. Slight "clunk" when cold, no clunk when warm and quiet. I have around 1100 miles on mine. Sounds like I got lucky (knock on wood)!
Bring a compass, it's awkward when you have to eat your friends.
Stuntman is offline   Reply With Quote
Old 05-03-2009, 03:28 PM   #69
pInniT
Oddometer: 51
I dont think the rattle you hear when u r in nutral is something to overlly concerned about, nearly all ktm 4st exc, husky 4st, bergs, some wrf yami's, have clutch rattle in nutral, its "usually" caused by the tolerance between the outer locating fingers of the fibre plates or the inner locating on the steel plates ratteling on the clutch basket/inner hub, my brother in-law had this problem/concern (the rattle was crazy!) at the spanish isde in 2000, we spoke to the ktm farrioli guys and they said it was ok that is normal and just ride it! we checked all the bolts and they were tight so he raced the bike in the hills of spain in real clutch punnishing terrain with no probs!!! If its a rattle that is goes away when you pull the clutch in and the clutch is under tension or when it gets hot is not as bad and the clutch works like it's ment to, you "sould" be ok...... if the bolts back out the noise will be alot different, even still the bolt shouldnt be able to come right out and work its way through the motor, most likely what happened to Griz is about all that can happen if your on the ball and catch it in time!!!
pInniT is offline   Reply With Quote
Old 05-03-2009, 04:07 PM   #70
tmex
tmex's Avatar
Oddometer: 2,039
Jim
Just for shits and grins I put a wrench on mine and found exactly the same thing - 12mm would not fit and 13mm was quite loose. Also the nuts were not very tight.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 05-03-2009, 04:10 PM   #71
DockingPilot
Oddometer: 9,734
Dam Chinese
Frank Reinbold
Old 05-03-2009, 04:11 PM   #72
DockingPilot
Oddometer: 9,734
TMEX !
Attention please, when hot, does your clutch slightly rattle like a dry clutch and go silent when you pull that lever in thats being held on by that Chinese nut ?
(think Nancy Grace) Yes or no ?
Frank Reinbold
Old 05-03-2009, 04:19 PM   #73
Benjava
Benjava's Avatar
Oddometer: 1,920
Originally Posted by M N B
I just got my F800GS back from the shop. It was there over 5 weeks for a clutch failure.
In California there is no way I would wait five weeks for a clutch. They'd be giving me a new bike on day 31. Man that Koolaid must be good.
Benjava is offline   Reply With Quote
Old 05-03-2009, 04:28 PM   #74
M N B
would rather be riding
M N B's Avatar
Oddometer: 1,207
Yeah, sure....
2014 Ducati Multistrada 1200 Pikes Peak MNB Touring Edition
2009 BMW F800GS
2011 Husqvarna TE310 - 2003 Husqvarna TE610e
2007 HD Road King FLHR
1997 BMW K1100LT Special Edition
M N B is offline   Reply With Quote
Old 05-03-2009, 04:46 PM   #75
DockingPilot
Oddometer: 9,734
He'd demand it !
Frank Reinbold
Times are GMT -7.   It's 12:28 PM.
