05-27-2010, 11:25 AM
#136 |
Oddometer: 731
Found a new toy in the solidworks program that I am using. It in theory can calculate mass. So by adding the components the total becomes 1kg. (using 7075 alloy - 2730 kg/m^3)
But the hitch is when I add all the calculated volumes up and then multiply it by specific mass I get 1.4kg. If anyone can shed light on this one let me know but for now I'll take the heavier one as a guide. Which means that the light bracket as already lighter that the stock one (2.3kg). Now i know since the bike standard without fluids is 189 its not much but its up high and out the front. Its about as far from centre as you can get. Also I hope using a WR headlight unit with upgraded wiring I'll get a decent light output and lose some weight there as well, plus fairings (although at the moment thats definitely theoretical), hopefully I can lose about 3 kg from the front instrument area. I figure I may even notice the difference (its a DL).......................
If ignorance is bliss, why arenīt more people happy?????
05-27-2010, 02:04 PM
#137 |
Oddometer: 4,258
Have you played with the stress tester thingy in solidworks.
I thought it was great fun designing something and then putting stupid amounts of load on it just to see it bend. |
06-03-2010, 10:38 AM
#138 |
Oddometer: 731
Check this out!!!!
For anyone interested in a 21 inch front wheel conversion on a strom, check this out...
http://www.bikesales.com.au/all-bikes/private/details.aspx?R=3195387&__sid=124501CC2132&__Qpb=true&Cr=0&__Ns=p_RankSort_Int32|1||p_Make_String|0||p_Model_ String|0||p_YearMade_Int32|1||p_PriceSort_Decimal| 1&keywords=&__N=1432%20604%201429%201428%204294967268%20429496 0808&seot=1&__No=15&__Nne=15&trecs=19&silo=1400
06-03-2010, 12:26 PM
#139 | |
skrik vir niks
Location: South West Florida, USA [formerly, South Africa]
Oddometer: 832
"Franken-Strom" Husaberg 48mm USD front forks, Husaberg 21" Front wheel, Brembo brake and 320mm motard front disc, Motard guard, Magura taper bars, Ego barkbusters. B&B Bashplate, Centrestand. Pannier racks/supports. 17" Husaberg rear wheel with cush drive, Alloy exhaust silencer. Mitas EO9 Dakar tyres (Good condition), New chain and sprockets.
06-04-2010, 11:36 AM
#140 | |
Oddometer: 731
06-04-2010, 12:07 PM
#141 | |||
Single Track Noob
Oddometer: 1,455
Q: Awesome v-strom build. I'm looking into adapting some spoke weeks for mine, but leaving the suspension stock. Can you give me any more info about the Husaburg rear wheel? Do you know what bike it came off of? A: Quote:
Thanks for the info. The adaptors for the disc what needed to be adapted, was it just for the bolt pattern or did you need to change the width as well? Why the spacer on the sprocket, could you not source a KTM sprocket in a 525 and needed to keep everything in alignment? A: Quote:
Brian Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa ![]() www.PhotoSupportNW.com |
06-06-2010, 05:16 AM
#142 |
Oddometer: 731
This is similar as what I had to do to mine. I had to machine up some spacers to run the standard dl rear disc and then use a dr650 rear procket with a spacer to gain the extra width, its not to much work really except the machining. Its a pretty cool looking build, if someone in the north of oz is after a strom that might be a good buy if still avaliable.
I'll be interested if someone ends up finding a cush drive hub that is the same width as a stock dl rear wheel, anyone know what the width of the transalp hub is?
06-13-2010, 04:02 PM
#143 |
Oddometer: 731
crash pics.
I know its been a while since my bingle but I just found some pics of the bike mostly finished, accepting that the bike is bent maybe its a bit of an idea of the finished product anyhow.
![]() Sorry for my ugly mug ![]() Looks a bit less like ned kelly but maybe just as bent up at the end ![]() The issue that may involve stripping the bike down to have this fixed, any suggestions let me know.
06-15-2010, 05:32 PM
#144 |
Oddometer: 731
time on my hands
Heres a couple of pics of some fun I have been having
![]() ![]() Getting closer to be able to design a fairing around the front end. Hopefully that will enable me to design the nav/instrument brackets etc to correct sizes without having to guess like I did last time. Making the fairing easier is the aim with measurements that are a lot more specific. The wheel should be fairly easy to complete (with tyre) and I already have a ktm adv front fender that I'll make brackets to fit. All this should be able to be done on Soildworks. Although I have gained a headache , and the computer sometimes as a 10 inch screened ultra portable EEE Pc is not really up to serious cad design.
06-16-2010, 04:39 PM
#145 |
Oddometer: 731
more fun
Eyes are sore, and not for the usual advrider reading.......mezos thread......
![]() I had a go at the tyre (i figured a tkc 80), but somehwere along the lines I got a dimension wrong, and well it came out more like a slick. But I may have another go......
06-16-2010, 11:56 PM
#146 |
Oddometer: 4,258
Holy crap that's some nice cad work. Are you self taught or did you do a course?
06-17-2010, 09:27 AM
#147 | |
Oddometer: 731
Fixed the tire problem I had, heres the current stage of completion. ![]() Having used this now for about a month its great to be able to mod created parts so easily. For example, add disc mounts to the hub, which then updates the wheel sub assembly and then updates the front end assembly. When I used Autocad (which may be able to do this) I never considered doing this as I didn't know how. This program makes it easier and I think the results work OK. Being I think a program that forces designing and building in 3D vs 2D how I did with CAD creates inital issues with my brain but once past that damn it works.Please don't get the idea that I'd rather be doing this work on a computer than my bike, but since its 13000 miles away this is as good as it gets.
06-27-2010, 06:14 PM
#148 |
Oddometer: 731
fairing
I've been trying vainly to get the front fairing designed but I have run into a few problems making the parts join together in Solidworks. I'll attached a current pic in the next few days but it is doing my head in a bit.
![]() ![]() Thinking of adding a nav tower attachment block similar to this; ![]() And the idea kinda behind the fairing is (not to much laughing "hows he gunna get it to look like that etc....") ![]()
tileman screwed with this post 06-27-2010 at 06:31 PM |
07-06-2010, 08:04 PM
#149 |
Oddometer: 207
Respect to you for your work mate. Obviously a very clever fellow not afraid of having a go and learning something new, all power to you.
Trev |
07-07-2010, 01:53 AM
#150 |
Oddometer: 4,258
you done any more yet?
