Old 06-23-2011, 04:09 AM   #136
DeeGee
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,884
An absolute joy to read Sakurama. Thanks for taking us along with the project, looking forward to this. And congrats on the bump
DeeGee is offline   Reply With Quote
Old 06-23-2011, 03:45 PM   #137
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,126
Fantastic thread and a fine time spent reading it. The FCR's will bring a whole new kind of happiness when you first hear them belch. I had bug eyes when you showed us the porting on the 990S motor. I am tapping my foot impatiently waiting for the package to run on the dyno! Sumo the Husaberg, you know it will be worth the traffic time saved...
snowhawk jockey screwed with this post 06-24-2011 at 11:24 PM
snowhawk jockey is offline   Reply With Quote
Old 06-23-2011, 06:51 PM   #138
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,148
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 06-23-2011, 11:05 PM   #139
Keith
Slabbing it
Keith's Avatar
Oddometer: 925
Very cool on the 990 conversion!
What's going to happen to the old 950 lump?
Random Crap
Keith is offline   Reply With Quote
Old 06-24-2011, 12:14 AM   #140
Master
Oddometer: 338
Forgive my ignorance, but...
What's the advantage of the flatslides?
2013 KTM 1190 Adventure R
1988 BMW k100RS sidecar hack
1989 wrecked BMW K100RS (currently being café racerised)
Master is offline   Reply With Quote
Old 06-24-2011, 05:30 AM   #141
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
Way more flow, instantaneous throttle response, much better carburator in general, and very highly adjustable performance.
Plus....Major grin factor!
None of which will actually help improve Sakurama's riding skills.....
Flanny is offline   Reply With Quote
Old 06-24-2011, 05:59 AM   #142
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,349
The cool way they rattle at idle...
Tbone is offline   Reply With Quote
Old 06-24-2011, 06:27 AM   #143
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,493
The physical difference in the carbs is that the stock carb is a CV (constant velocity) and what that means is that the throttle actually doesn't control the slide of the carb but rather a butterfly below. When you twist the throttle the butterfly opens which creates vacuum as the engine turns faster. This vacuum then acts on a diaphram which lifts the slide. The idea is that the slide only opens in correct proportion to the amount of vacuum so the engine doesn't waste gas or get bogged down. It works well and was a good solution before EFI but there are downsides and slow throttle response is one.
The flat slide has a few advantages: The narrow slide creates a shorter track than a round slide but more importantly is that the slide is connected to the throttle cable so you have instantaneous response. This can create a bog if you go WFO instantly but that is usually countered by an accelerator pump which compensates for the carbs inability to provide enough gas when the slide goes up so fast (the reason the CV doesn't bog) by squirting gas directly into the intake. It's primitive and it wastes gas but it also works giving you instant and full power. There's a great "connection" between the throttle and the engine and it often creates a signifcant power increase through the range.
Another related advantage is if you've ever been crazy enough to try whoops on the 950. The vacuum slides can be pulled down with enough G forces and stall the bike while the flat slides are on a cable and that won't happen.
A final fringe benefit is that my bike will have the same carbs as Flanny but with a much bigger motor meaning I won't need to actually ride better than him to be that much faster! Of course anyone who's seen Flanny ride knows my grandma could go faster on an XR100 with missing spokes and flat tire - but that's beside the point.
G
sakurama is offline   Reply With Quote
Old 06-24-2011, 12:52 PM   #144
joneswgareth
Welsh Rarebit
joneswgareth's Avatar
Oddometer: 195
What a fantastic read - only just found this thread! Look froward to seeing that 990 engine in there! Thanks for sharing
950 SE
joneswgareth is offline   Reply With Quote
Old 06-24-2011, 11:54 PM   #145
Autostream
Autostream's Avatar
Oddometer: 5,833
...None of which will actually help improve Sakurama's riding skills.....
Originally Posted by sakurama View Post
....A final fringe benefit is that my bike will have the same carbs as Flanny but with a much bigger motor meaning I won't need to actually ride better than him to be that much faster! Of course anyone who's seen Flanny ride knows my grandma could go faster on an XR100 with missing spokes and flat tire - but that's beside the point.
G
Can't wait to see this thing in action.
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream is offline   Reply With Quote
Old 06-27-2011, 11:19 AM   #146
Pyndon
Pyndon's Avatar
Oddometer: 2,590
Pyn says that this engine, coming from a 990SM is the same as the 990R spec which is supposed to be 20hp up from the standard bike.
Gregor, good job....get it in there laddy!
The stock 990 adventure is just a few bhp more than the 950, the 990 SMR/SMT motor (the one I sent you) is 12bhp more than the 950 and this is what you've got. With the flat-slides and a nice exhaust system I reckon you'll be between 15 and 20bhp more than you had in your old dog.
The SD motor on the other hand is 29bhp up on the 950
The 1190 is a whole different ball game but totally unpractical for an adventure bike!
I think you'll like the SM motor.
Pyn
Flanny......I've just a couple more 990 SMR motors if your interested
Lyndon Poskitt Racing
Currently racing my way around the world at: www.facebook.com/LyndonPoskittRacing
Blogging at: www.racestoplaces.com
My Dakar Rally Experience
and blog www.LyndonPoskittRacing.com
My KTM 950 Story
Pyndon is offline   Reply With Quote
Old 06-27-2011, 12:16 PM   #147
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,493
Let me know what it will cost to keep Flanny from getting one of those 990's!
If I saw 20hp that would be a 20% increase and that is huge. I'd be happy.
G
Old 08-25-2011, 12:26 PM   #148
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,493
Okay, sorry for the delay. As you might imagine I moved my studio and then we moved to Portland and then I just got back from a week in the desert shooting the 2012 Rev'It! catalog (which was sooo cool - I wish I could show you some shots but you'll have to wait. Good stuff coming!) so I've been busy beyond belief.
Anyway, once back in NYC I got a day to head to the shop and do a bit of work on the 950. Sorry for the crappy photos - all I had with me was my iphone (well, I also had $100,000 worth of Hasselblad too but I didn't feel like carrying it on the subway - sorry, when I'm not working I prefer a point and shoot or the phone).
The engine is in the frame now:
And for those of you curious what was the demise of my engine it doesn't seem to be related to the water in the oil. I found this when I opened up the clutch side:
And more in the pan:
So it appears that my timing chain exploded. There's a lot of metal and debris in there so basically I now look at that engine as a 90lb spare parts holder - it's very organized with fasteners, clutch, stator, rotor etc conviently stored in an identical place as my 990 engine. Really I consider it now a source of those nice 6mm dished head srcews that are so hard to find. Expensive source...
I was supposed to have dinner with Judiaann but took a rain check to work a little longer since I decided to fly out a day sooner as my daughter was sick at home. Here's "sunset over seeley" at our shop:
And I thought I'd put in a shout out to two really great tools I use to clean a motorcycle. One is very low tech - Pledge. If you haven't used it you should try it. I always carry a small bottle with me on trips to clean face shields (disolves bugs and doesn't streak) but it's also good for plastic and rubber like the harness.
The other is really high tech and no, it's not a deep fryer - it's an ultra sonic cleaner. I got this for $50 and it's one of the best investments ever. You can fill it with any solvent or even just water and Simple Green and turn it on and it will just vibrate dirt and grease away. It's probably the single best carb cleaner I've used.
I have got the left side just about buttoned up. I'm finding a lot of electrical connectors that have changed from my 04 harness to the 09 990 engine (or whatever year it is) so I'm pulling the sensors from the 04 and moving them to the new engine as I'd rather not splice wires.
And ironically enough when I moved to Portland I met Ken (mortimersickle) who did the same transplant and he reminded me to change the timing wheel which I did. It took a monster Snap-On impact wrench to get the old clutch hub off but I got it.
I also found a lot of the little parts I needed in my spares. I always have to remind myself to check my own spares:
And so I only got one day but I did get a fair amount done. I'm back to NYC on the 6th and I'm hopeful to get more days to work while I'm there but I'm coming to terms with the fact that it's going to take more time than I'd hoped and that leaves me bikeless in Portland with all this perfect weather and amazing roads...
Gregor
sakurama screwed with this post 09-19-2012 at 12:14 PM
Old 08-25-2011, 02:50 PM   #149
schaffer40
I look lived in.....
schaffer40's Avatar
Oddometer: 413
Just saw this thread and lost 1.5 hrs (maybe 2) reading it from the beginning. What the boss doesn't know won't hurt him.
Good luck with the build.
The massive Raider Nation is beyond doubt the sleaziest and rudest and most sinister mob of thugs and wackos ever assembled. Hunter S. Thompson
Punk Rock Changed My Life- The Minutemen
schaffer40 is offline   Reply With Quote
Old 09-03-2011, 10:30 AM   #150
Steverino
Arrogant Horse's Ass #1
Oddometer: 36,668
Man I am having flashbacks to my rebuild. Mortimersickle was a lifesaver and the jugs I got from him are working like a champ on my 950. Rode it to Dallas a couple of weeks ago. 2900 miles in 4 days. Ran awesome and no leaks.
Now I need tires...
Good luck with the rebuild.
Steverino is offline   Reply With Quote
Times are GMT -7.   It's 06:36 PM.
