09-28-2011, 12:12 AM
#166 |
on an endless build
Oddometer: 1,209
Look, I'm just going to say it Deadly. I'm going to paint my bike white and yours was a big inspiration. I'm just going to come out and say it now. The whole thing with the flatslides and 990 is mostly to piss off Flanny...
G
www.gregorhalenda.com Previously on ADV: My endless rebuild: 950 Refresh or Mission Creep My ride reports: 5 Up on Two Bikes - Long way to the Trans Lab and City Blocks to Slick Rocks |
09-28-2011, 04:34 AM
#167 | |
Flanny-it-up!
![]() The Brutale on the the other hand.....
Flanny Flanny-it-up!...Check out the FlannyMedia Web Site and Blog at www.FlannyMedia.Com
09-28-2011, 04:57 AM
#168 | |
Loose nut behind h/bars
Oddometer: 4,508
Thanks!I can only imagine what a snotty SOB your bikes going to be with that motor in it & flat-slides. I'm a green/orange with envy. You still have a dirt-bike on this side of the continent? If so, the invite is always open for you & whomever you'd like to bring along for a ride up here. Hope to see you again one of these days. Chris
http://www.theshining.info/ KTM 950 Adv. "S"...'06 KTM 525 EXC... '76 MV Agusta 750 America S...'84 Honda VF1000... '90 Kawasaki ZX11...'76 Kawasaki 900 Z1...'01 VOR 400E |
09-28-2011, 02:19 PM
#169 |
Motorhead!
![]() Love this sort of mechanical holiganism!!
Cole Ford<----my iPad app ...and iPhone version .....Android Tablet version06 KTM 950 Adventure(The Fainting Goat) ![]() 02 F650GS DAKAR ![]() 2 KLR650s Travel bikes http://coffeemotorcycleswine.blogspot.com/
09-30-2011, 03:07 AM
#170 | |
Fast and Far
Oddometer: 6,829
Why do I get the feeling you won't use a five dollar rattle can like I did
www.GravelTravel.ca Canadas Source For Overland Routes Tales From The Bivouac Rally Print Publications TCAT Trans Canadian Adventure Trail 15, 000 km GPS route across Canada |
09-30-2011, 11:45 AM
#171 | |
Flanny-it-up!
11-17-2011, 03:59 PM
#172 |
Oddometer: 1,702
Great thread
.Any updates .
03-24-2012, 06:13 AM
#173 |
on an endless build
Oddometer: 1,209
You know, I used to think it was pretty inconvenient to have to cross two rivers to get to my shop but now that I live in Portland and work in NYC and my shop is in NJ, well, it's just a whole lot worse. That and the fact that I have two little ones means that every time I book a flight for work I don't want to stay any longer than I have to and shop time suffers. J and I are hoping to find a place to buy in Portland this summer and then I'll move my mechanical wonderland across country and finally be living the dream - my own shop next door.
But that isn't the story. The story is that I'm finally updating this thread. So, we left off that I finally got my SMR engine into the frame and got it all hooked up. It was leaking here and there but I managed to get the big beast strapped to the dyno and... ...it made 10 LESS hp. Seriously... It made 88rwhp whereas my old 950 made 98rwhp. It was also lean off the charts so that is what you'd expect. I wasn't going to spend the time to jet the old carbs to the bike since I had no intention of using them which brings us here - installing the FCR carbs. I spoke to Flanny and he said that stock they were really rich - which is exactly what I'll need. We'll see. So I managed to get a weekend here in NYC and I wasn't going to waste it drinking or visiting, no, I was going to spend it in the shop. I went straight from the airport and got to work - cleaning and trying to find all the parts to this project. I had to do two simple things - make a bracket for the TPS and bore the inlets open as the 990 has a much larger port. That is the inside of an FCR - on the slide you have to remove the two set screws and a roll pin to get the shaft out. ![]() You have to also remove the worlds smallest Jesus clip on the end of the linkage - named because when it slips out of your pliers and falls on the floor that's what you'll say. I asked Flanny to send me a photo of his TPS bracket - not because I needed it but I just wanted to know how nice his looked so I could make mine a lot better. Since Flanny used steel I started with a block of billet: ![]() And I spent way too many hours on my mill: ![]() At the same time I was waiting on a parts order from McMaster so I was going between the mill and the lathe. I made this tool to indicate my inlet true - if you have a lathe you need to make this little bearing tool as it will make your life much better. ![]() Then I set a taper of 6.5° on my cross slide so I could open up the venturi from 39.7mm to 46.7 on the engine side. ![]() I finally got my new boring bar with a C-5 insert for aluminum and spun the lathe up to 1200rpm and managed to get a very nice finish. ![]() The goal being that the inlet tapers up to meet the widest opening of the carb boot. ![]() And there you have it - about 12 hours of work to do something that should have taken two. ![]() ![]() ![]() I finished that up at midnight last night, cleaned up my mess and headed back to the studio. The goal for tomorrow is to get them installed, run the bike on the dyno to see if I can find those 10 horses back and then start pulling the exhaust up to fabricate the new one. Gregor
www.gregorhalenda.com Previously on ADV: My endless rebuild: 950 Refresh or Mission Creep My ride reports: 5 Up on Two Bikes - Long way to the Trans Lab and City Blocks to Slick Rocks sakurama screwed with this post 03-24-2012 at 04:40 PM |
03-24-2012, 04:44 PM
#174 |
on an endless build
Oddometer: 1,209
Today isn't working out too well. I got it to idle but then broke an elbow on he throttle cable. It was the elbow that is threaded 6mm x 1 on one side and 6 x .75 on the other - who uses that thread? No one. The die is $40 and will take two days. I need another solution.
Oh, and only one accelerator pump is pumping. G
www.gregorhalenda.com Previously on ADV: My endless rebuild: 950 Refresh or Mission Creep My ride reports: 5 Up on Two Bikes - Long way to the Trans Lab and City Blocks to Slick Rocks sakurama screwed with this post 03-24-2012 at 05:53 PM |
03-24-2012, 05:52 PM
#175 |
on an endless build
Oddometer: 1,209
<iframe frameborder="0" scrolling="no" width="425" height="240" src="http://api.smugmug.com/services/embed/1763108610_NH4GF6t?width=425&height=240"></iframe>
Okay, this video tells me two things: 1. I'm going to get (even more) horrible gas mileage and 2. I will save lots of money on front tires. Gregor
03-24-2012, 06:22 PM
#176 |
Fast and Far
Oddometer: 6,829
03-24-2012, 06:29 PM
#177 |
Flanny-it-up!
03-24-2012, 06:47 PM
#178 |
Fearless of Falling
Oddometer: 873
![]() ![]() ![]() I love it!!!
03-24-2012, 08:25 PM
#179 |
Mark
Oddometer: 97
Safari Time, and that might get you from one gas station to the next... if you're lucky!
Ride Safe! 2006 BMW R1200RT 2006 KLR 688
03-25-2012, 05:12 AM
#180 |
Oddometer: 1,385
Any chance you made a dimensional drawing of the TPS mount?
ktm950se |
