Old 04-01-2013, 05:45 AM   #811
buffallodan
buffallodan's Avatar
Oddometer: 1,709
This just gets more and more fascinating! Awesome work guys.
Sent from my SCH-I605 using Tapatalk 2
buffallodan is offline   Reply With Quote
Old 04-01-2013, 06:32 AM   #812
wiseblood
Hall Monitor
wiseblood's Avatar
Oddometer: 13,073
Originally Posted by sakurama View Post
Here's some CAD drawings I found that probably explain the system better.
That completely answers my questions! Also, you answered another question by explaining the free-wheel hub and the 70% power ratio.
Though, I imagine chain lubing / cleaning is about to become a slightly more time consuming task.
"Hard Work Often Pays Off After Time, but Laziness Always Pays Off Now."
Big Apple Tag-o-Rama Maps: Click Here!
wiseblood is online now   Reply With Quote
Old 04-01-2013, 08:30 AM   #813
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,486
Cool.
It's actually something we're discussing right now is the chains. They'll be smaller and we'll use two but the short one will be off the countershaft and almost completely exposed. The second longer one that will run up to the gearbox we'll make enclosed so that its not spraying lube all over inside the engine bay and so that it can live longer (enclosed chains can approach shafts in ease of maintainence and life spans) so really it should only be the short one that needs regular attention.
I have another trip planned to NYC in a couple weeks so I might use that time to pull my wheel apart and lace up the new hub. I shipped my dirt wheels to Portland so I'll need to lace that later. I'm curious to see how the bike works with the smaller 17/19 wheels on pavement (should never work except for wheelies) and on dirt where the 19 is at a disadvantage to the big wheels. It would be great if it helps the small wheel set on dirt and gravel.
Gregor
sakurama is offline   Reply With Quote
Old 04-01-2013, 08:47 AM   #814
neduro
Addict
neduro's Avatar
Oddometer: 11,985
Brainstorming, but what's the relative circumference difference between the 18/21 (that it is presumably designed for) vs. 17/19? I'm guessing that there's no issue, but I suppose there's a chance they could interfere?
I always felt like the machines that would benefit most from 2wd are not the ones Christini started converting. Big ADV bikes are right at the center of my list- lots of wheelspin in 1wd, a few more pounds won't make much difference (relative to a 250 lbs dirtbike), and intended use across a very wide range of intended conditions.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 04-01-2013, 09:03 AM   #815
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,066
Originally Posted by HeatXfer View Post
Question:
Why would the front wheel pull to one side with a single drive? If that were the case, why are shaft drive bikes only driven from one side? What about that single sprocket on the rear? Single disc brakes? They don't pull to one side.
I could see a potential problem if you only had one fork, it would want to rotate axially if it were by itself, but it's prevented from rotating because the front axle is secured to the other fork. Not to mention the fork brace.
Thanks in advance
It's called "torque steer" and driven rear wheels don't turn so they aren't affected. If the driveshaft was on one side the combined forces of a shaft and gear spinning in one direction would assist or fight steering based on the which way the bike was turned. By driving both sides the driveshafts cancel each other. Essentially the gear is attempting to climb the sprocket and so it will pull to that side.
When the bike is spinning the front wheel you certainly sense a stiffness from the gyroscopic forces.
Maybe Chris can weigh in with a more technical answer.
Gregor
Torque steer is the issue - but the place it would come from would be at the headstock. If you have a single drive, it would certainly want to turn/steer in reaction to torque applied - just like the rear swingarm wants to extend downward when you apply torque.
Driving both sides of the hub is not completely necessary - other than to provide equal load in both sides of the drive at the head.
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 04-01-2013, 01:11 PM   #816
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 716
Thanks Wadester, that was the same conclusion I came to after reading both references. I realized neither addressed my question clearly. Originally my attention was on the wheel, not the steering head. I've got a thick skull.
HeatXfer is offline   Reply With Quote
Old 04-01-2013, 01:17 PM   #817
CosentinoEngineering
Oddometer: 183
Wadester has it right, its the bevel drive in the headstock that needs to be balanced. There are only dual driveshafts because you need opposing torques in the headstock.
In the headstock one end of the drive is anchored to the frame the other end is anchored to the triple champs. If it was only a single bevel drive then as soon as the front wheel drive system was loaded the steering would want to turn to the stop. This wouldn't be torque steer in the conventional sense as that is a small side effect where this is using all of the engine torque to turn the steering. Once the steering hit the lock then the front wheel would start to spin. Not a good design.
Christini's dual bevel drive and telescoping drive shafts allow the triple clamp assembly to 'float' on the opposing torques. By having a top and a bottom output bevel gear the system is torque neutral on the steering axis and then by having the bevel drive on the fork lowers be mirror images the reversing torques are resolved to be all in one direction. Christini recommend that a steering damper is not needed so I suspect the added torques in the steering system create a damping action of its own which in this case is a benefit.
Chris
moto2-usa.blogspot.com
Check out my products 10% off for ADV rider members
CosentinoEngineering is offline   Reply With Quote
Old 04-01-2013, 02:15 PM   #818
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 2,925
Torque
Torque can do some funny things.
Orangecicle is offline   Reply With Quote
Old 04-01-2013, 02:49 PM   #819
DRjoe
DRjoe's Avatar
Oddometer: 5,143
Ha
Old 04-01-2013, 03:26 PM   #820
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,486
Thanks Chris. I'm going to miss having you right next door. Being wrong from the other side of the country isn't nearly as much fun as being wrong right there where I get the eye roll and the sardonic, "Well think about it for a minute." You need your own emoticon.
As an aside I finally got the boxer to idle today - only took 10 years...
Gregor
Old 04-01-2013, 05:07 PM   #821
mookymoo
Mookish Mook
Oddometer: 4,396
I only hope the weather is still cold enough to test cold starting.
Do you have access to a big cool-room?
mookymoo is offline   Reply With Quote
Old 04-02-2013, 10:05 AM   #822
ramon
weezin' the juice!
ramon's Avatar
Oddometer: 1,128
Awesome project!!
"...if you don't like the price then move on because I don't give a shit...it's my bike and I will sell it for whatever I want." Craigslist SF posting
ramon is offline   Reply With Quote
Old 04-03-2013, 08:26 PM   #823
Oddometer: 183
Isn't that what facetime is for?
Chris
Old 04-19-2013, 09:30 AM   #824
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,486
Chris is waiting on some parts but I got out there this past weekend to pay a visit, see the progress and take some photos. I recently decided to step up my personal photography - Sony has finally introduced a point and shoot (the RX1) that is on par with my professional gear and so from this point forward you will see a marked improvement in photography for this thread: both in the quality of the equipment and my intent. I hope you enjoy watching.
So, let's take a look at the progress thus far.
This is the countershaft drive. Chris will have to custom make this part but the important part is the location of the second sprocket just inches away. Locating the second one here will allow a long second chain run to the 90 gearbox.
Here you can see the second chain run up to the head stock - this chain will run in an enclosed case and utilize a tensioning device similar to a cam chain. The bulk of Chris work is to perfectly place the gearbox square to the headstock. He will ream the headstock to accept the Christini bevel stem. The brilliance of this solution is that the frame only needs very small modifications and no external changes to the bodywork, tanks or running gear. It will require the modification or removal of the stock airbox but that is a small price to pay.
Here are two views of the location of the bevel gear box. Christini has been extremely helpful with us and has given us a lot of proprietary information to allow us to build the very best adaptation to the 950/990.
I liked seeing Chris' copious notes here scribbled on paper. There's a tremendous amount of math and measurements, both of distance and forces that Chris is making to adapt the parts to the 950/990.
I hope you enjoy the photos. I think there's nothing more beautiful than an elegant solution and Chris is well on his way to completing this in the most elegant way possible. Stay tuned.
Gregor
Old 04-19-2013, 03:33 PM   #825
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,456
Top notch all around!!!
The photos and play by play are additionally fantastic. This project quite simply amazes me! Great courage involved beyond the engineering sophistication. Elegant indeed and at the highest level. Hat's off to you all! I'm glued to this.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Times are GMT -7.   It's 12:38 PM.
