Old 10-07-2013, 10:18 AM   #961
Slider_Over
Hooligan
Oddometer: 40
Amazed at watching the progress on this....love it! Excited about the "choke work" too. Can't wait to see an FCR with choke solution
I just got my full Akra exhaust installed with the header. I can't believe how much this wakes up the 950...just amazing!! It looks so good as well...and the sound...wow!! I can't wait to add some FCR's...and then I'm done...
Slider_Over is online now   Reply With Quote
Old 10-07-2013, 01:15 PM   #962
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
No such thing.
Flanny is offline   Reply With Quote
Old 10-07-2013, 01:25 PM   #963
CosentinoEngineering
Oddometer: 183
>>How repeatable is this? Not can you do it again but how much quicker/more economically can this be performed?
It will be a much faster turnaround for more but I would ideally do them in batches of a few at a time. As of now official turnaround and pricing are TBD.
>>If the key, I would have thought it would be safer to have the two sprockets fixed to each other?
Keyways are specifically designed for transmitting torque on shafts so why try to reinvent the wheel? A 7/8" long key has a pretty large shear area compared to a couple of screws or dowel pins.
Chris
moto2-usa.blogspot.com
Check out my products 10% off for ADV rider members
CosentinoEngineering is offline   Reply With Quote
Old 10-07-2013, 02:53 PM   #964
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,837
Originally Posted by sakurama View Post
Over my head in stress right now...
Alcohol helps. I prefer tequila and beer at times like this.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 10-08-2013, 06:43 PM   #965
Oddometer: 183
Well, its looking like the narrow 520 chain will be required! These are the 420V _rivet_ connecting links that finally arrived.
After a lot of phone calls and digging, according to DID they do have rivet links for the 420V chain but nobody has ever bought one so they are not stocked even though they are listed as 'in stock' by many online vendors! DID US need to call DID Japan and see what a minimum production run is. Since that is a sure sign of scarce availability it is best to switch to parts that are more universally stocked.
The 520VT chain seems to be carried by a lot of vendors and if we use it then a clip link can be used on the 420V short chain. It may seem like a tiny detail and it is but that 1.5mm means instead of a light grinding on the inside of the frame we would need to break through the wall thickness of the tube. That's not an option so we have an 11th hour change in parts. Its not the end of the world but just as I'm about to go and test it sucks. Now I need to get one of these chains in and on Gregor's bike for testing. Does anybody know if the rear sprockets/carriers for the KTM singles and twins are the same? I can machine the front sprocket to suit but the rear sprocket on Gregor's bike is hard as hell and chips every one of the inserts I try when cutting it on the lathe. If necessary I'll do it on the mill where the interrupted cuts from the sprocket teeth are nowhere near as much of an issue for the cutter as they are on the lathe, but would rather use an OEM part for for easy and cheap replacements.
Arrrrgh.
Chris
Old 10-08-2013, 07:15 PM   #966
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
The smaller KTM rear sprockets are similar in bolt pattern/count and the ID works too, however they use smaller diameter counter sunk bolts. Some people have switched to 520 on the 950/990s successfully by re-machining the bolt holes to accept larger bolts. Last time I asked, Sporting Wood had a 520 setup
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 10-08-2013, 08:33 PM   #967
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,486
That's a tool steel sprocket and it is hard. I wouldn't try machining it. Is there a way to use clips throughout? For ease of use on the trail I like using clips if possible although I know they're not as secure as a rivet. I think a chain tool for 420 might hard to come by and space is limited.
Gregor
sakurama is offline   Reply With Quote
Old 10-08-2013, 08:49 PM   #968
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
There is a cross over from the Aprilia that will work as well as the 520 CS sprocket from the RC8 will work as well, the shaft is the same.
Old 10-09-2013, 02:22 PM   #969
Oddometer: 183
Haven't you been keeping up? Needing to use the 420V clip master is pushing us to the 520VT2 rear chain. Anyway, the 420 chain is only 30 links long so keeping a spare onboard is easy.
There are 520 front sprockets available for the SuperDuke, SM, RC8 and the Aprilia Mille, is that what you are talking about?
Chris
Old 10-09-2013, 02:26 PM   #970
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
Yes, 520 for the CS for the aforementioned applications will fit with little/no mod, however the rears for the same will not fit. Will need to use a rear from a 530 application and machine the holes to accept larger dia bolts to fit the LC8 rear drive carrier.
http://www.drivesystemsusa.com/
specifically: http://www.drivesystemsusa.com/p/558...m-950rc-8.html
Old 10-09-2013, 03:02 PM   #971
DRjoe
DRjoe's Avatar
Oddometer: 5,143
Having to drill out rear sprockets isn't ideal.
I'd rather a hard to find rivet link for the front wheel drive chain rather than a custom rear sprocket.
But saying that you do what you've got to do.
Old 10-09-2013, 03:51 PM   #972
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,391
Why is that?
I have had good luck doing it on my XR600. Even easy to get a nice clean cut, since I discovered step drills.
Edit: Hey Chris, am I allowed to say "step drill" in this thread? or is that heresy?
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle screwed with this post 10-09-2013 at 03:57 PM
MortimerSickle is offline   Reply With Quote
Old 10-09-2013, 05:22 PM   #973
DRjoe
DRjoe's Avatar
Oddometer: 5,143
Because when the owner of the bike is in butfucknowhere and is sprocket goes to shit its sometimes hard enough to find a sprocket let alone have it drilled out to match bolts.
Not impossible but not ideal.
Chris I do have plenty of 520 ally hub rear sprockets to try that I can drill out so if we have to go down that path it won't be a huge issue.
I'll have to check but it might also be possible to swap sprocket hubs between the 520 and 525 two peice ktm sprockets.
Old 10-09-2013, 06:06 PM   #974
Oddometer: 183
If I heard back from DID I'd just buy a bunch of the rivet links and be done with it but nothing yet.
There are a few alloy rear sprockets for the 950 for a 520 chain size and drivesystems.com says AFAM are a couple of months away from production of a steel one. I prefer the steel rear for durability reasons, especially with the narrow 520 chain.
Since you did it supporting my approach I'll overlook it this time.....
Chris
Old 10-10-2013, 04:10 PM   #975
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,143
Talon 520 labeled for Honda Xr600, lc4, exc. Direct fit with the lc8. And so is every other Xr600 sprocket, they have the same patern and 10mm holes.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Times are GMT -7.   It's 01:00 PM.
