Old 11-07-2013, 08:41 PM   #1081
Lawsonuw
Oddometer: 7
Originally Posted by CosentinoEngineering View Post
Marty, care to share your thoughts a bit on underdrive ratios? Christini likes to stay around mid-60s and says if you go higher you get a hard feeling on the pull of the bike. (?) I'd think (with no testing to back it up) as close to 100% as possible without overdriving it would provide the most seamless transition from rear drive to 2wd.
On my bikes I've found matching rollout (gear ratio * circumference. ie. how far the bike travels per turn of the tranny output) front and rear is a good start. We've actually found driving the front wheel 5-10% faster is best on sand/mud, but it increases rolling resistance and has a funny steering feel on pavement. I'm running the front rollout 1-2% faster on the bikes now. The knobbies squirm enough that the steering feels normal, and the bikes are just magic when on the throttle!
Christini's advice on underdrive is a side effect of how they re-combine the two drive shafts to the front wheel. I'd at least try it 1:1 to see if the instant traction is worth fighting the slip-clutch all the time.
@Wadester: Not a problem. Both my bikes and the Christini have an overrunning clutch to let the front wheel spin faster when it needs to. Though it's only really needed when going slow or brake sliding. (or when the engine seizes...)
Marty
My AWD KTM
Lawsonuw is offline   Reply With Quote
Old 11-08-2013, 06:16 PM   #1082
Oddometer: 183
>>Just my $.02 - the problem comes with cornering, where the front wheel covers more distance than the rear.
With a dual track vehicle this is noticable but the nature of how a single track vehicle turns greatly reduces this effect.
I thought so. One more benefit of a FFE.
We have easy gearing for about 65, 72 and 82 that we can test.
Chris
moto2-usa.blogspot.com
Check out my products 10% off for ADV rider members
CosentinoEngineering is offline   Reply With Quote
Old 11-08-2013, 08:26 PM   #1083
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,472
Just ran into our mutual friend Dan from Revit tonight at Gino's place and he's offered some help for our test this weekend. This is going to be much more fun now but I'm not letting the cat out if the bag just yet. You'll see.
Yes, it looks like we'll take the bike over to Revit's sample sale tomorrow after noon sometime. We're going to use tomorrow to prep for Sunday.
Gregor
sakurama is offline   Reply With Quote
Old 11-10-2013, 08:51 PM   #1084
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,472
So today was my first ride on the bike. Chris rode it to the Revit sample sale yesterday but I didn't get the chance to ride it as Tommy and I decided that we wanted to make a fun video and we had a few ideas that we thought would put it over the top. When we mentioned it to our friend Dan at Revit he thought it sounded like fun and asked if we needed anything - we said heck yeah, how about a couple more GoPros? He said sure and so we spent the day learning the new cameras and packing all our gear.
Sunday came and we were at the shop early to go over the bike and then take it out for a test. We found a bearing had backed out of the jack shaft backside and that required some machining to fit a circlip. Chris hasn't finalized all the parts so this was the first shakedown issue.
Once Chris made a spacer and turned the groove for the circlip we put the bike back together.
The chain line is final but not yet enclosed. You can certainly hear it when rolling but it's not very loud. Since we had spent some daylight making fixes we decided to go across the street to the gravel road for a little spin with Gino as our reference as he had his 18/21 wheel set on with a set of TKC's and my bike had the smaller 17/19 with a pair of Avon Distanza's.
It was no contest. Even giving him a bit of a lead my bike, with pure street tires, consistently pulled him. The bike is just amazing and it's going to take a little while to recalibrate the way I ride because it behaves quite differently. If you're used to giving it a bit of gas to swing the rear around on gravel it just doesn't really do that anymore. There's none of that wild spinning as the bike fishtales around - it just goes, where it's pointed, very fast. You have to be careful where the front wheel is pointing when you hit the gas because it will go there immediately. Frighteningly fast in fact.
It is more than I expected and it's exactly what I was hoping for. This bike, more than any other off road bike, desperately needs traction and the whole package delivers it. With street tires on gravel the bike accelerates faster than knobbies could ever hope and gives an amazing sense of confidence up until you realize how fast you're going. I can't wait until I get it in dirt with the second set of wheels and fresh knobbies. It looks like that old two rears to one one front ratio is gone for good.
We shot video with six cameras , were almost arrested twice , and were kicked out of every place we went . It was fun and we got some amazing footage. It's going to take a few days to sort the 80 Gigs of video and turn it into something but hopefully it will be worth the wait...
Gregor
sakurama screwed with this post 11-11-2013 at 06:30 AM
Old 11-10-2013, 09:08 PM   #1085
Oddometer: 183
Yea, what he said.
I should have know that for Gregor shooting a little video entails a carful of equipment and 3 non-riding personnel!
It was a lot of fun and we rode it pretty hard and had no problems. The abuse got so bad at one point we had to chain it down. It was interesting to see Gregor look a little spooked after some of the higher speed runs. I'm banned from putting up any of my crappy footage yet but the HD and slo-mo stuff will be worth it.
Chris
Old 11-10-2013, 09:34 PM   #1086
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,286
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 11-11-2013, 08:27 AM   #1087
slidewayes
slidewayes
slidewayes's Avatar
Oddometer: 551
I can just imagine a Teraflex on both ends
slidewayes is offline   Reply With Quote
Old 11-11-2013, 08:38 AM   #1088
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,472
When I finally get it out to Portland I plan on putting a pair of paddles on it and taking it to the dunes where my nephew races quads. That should be silly fun.
The funny thing, which you'll see in the video, is that the front pulling is constantly straightening the bike out. It's a strange sensation of being pushed and pulled at the same time. Gino's bike, like all normal 990's, is just wildly spinning and fishtailing as no tire can manage the 990's power.
Gregor
Old 11-11-2013, 11:12 AM   #1089
Pyndon
Pyndon's Avatar
Oddometer: 2,536
So, this thread has gone on for so long and I've been pretty tied up with other stuff from time to time but I have to say, I'm always impressed with what's going on when I do catch up.
Nice work but I genuinely mean this, who's bike is it anyway? There is so many cool people involved, I've lost track.........OK, I could go look and I think I vaguely remember.....
PS. I have a spare KTM690RR in the shed, that would make a cool AWD project, let me know when you guys get bored
Lyndon Poskitt Racing
Currently racing my way around the world at: www.facebook.com/LyndonPoskittRacing
Blogging at: www.racestoplaces.com
My Dakar Rally Experience
and blog www.LyndonPoskittRacing.com
My KTM 950 Story
Pyndon is offline   Reply With Quote
Old 11-11-2013, 11:26 AM   #1090
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 769
Gregor
Dunes big fun.. A winter trip to Christmas Valley would be high fun factor as well.. Semi frozen dunes.. Maybe snow on them.. What could go wrong?
Dave
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is offline   Reply With Quote
Old 11-11-2013, 12:59 PM   #1091
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,203
And while you are working up Pyndons 690 AWD kit, I'll take a set too for my 690, might as well make at least 2 of everything.
cyborg is offline   Reply With Quote
Old 11-11-2013, 01:26 PM   #1092
pdxmotorhead
Oddometer: 769
The Christini package on a CR500 would not be boring..
How much gyro do you get if you crack the throttle in mid air?
Hmm.. Just a fascinating bit of engineering it is..
DAve
Old 11-11-2013, 01:43 PM   #1093
Oddometer: 183
I'll have to take a look at that bike and see how feasable it is. Nobody I know has one. Anyone have good pics of the chain side without bodywork?
Should work at least as well as rolling up the windows.
Isn't possession 9/10 of the law? ;)
Chris
Old 11-11-2013, 02:01 PM   #1094
DRjoe
DRjoe's Avatar
Oddometer: 5,115
Don't you even think about it
Old 11-11-2013, 02:22 PM   #1095
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,472
Not as much as I remembered from my 450 testing. I was just a bit disappointed as I was hoping it would be a magic wheelie machine but I'm still only average. Gino is really the one who needs to test it on one wheel as he can go through all the gears.
As far as the bike being resistent to turning or feeling stiff or tight it's not really there. You certainly notice the steering tighten when the front is spinning and honestly that's a blessing. It's a combination of gyroscopic forces along with the front pulling the bike straight. It's like the bike is always trying to stay in line or follow the front. While it's obviously a limited test the extra weight of the 990 actually seems to temper some of the more lively behavior I felt on the small Christini - such as the tendency for the front to skate or get crossed up and pull off course. Obviously I want more time on it as there's much to learn. Knobbies might reintroduce that.
I'm trying to convince Gino to take it down to the Pine Barrons next weekend and ride it in the PB300 to put it through it's paces. We'd need some better tires but already I know it would be worlds better than it used to be with the smaller wheel set. Right now the only downside seems to be the cost and I think it's worth it as this is a whole new motorcycle.
Gregor
Times are GMT -7.   It's 07:54 PM.
