Old 05-07-2009, 05:19 AM   #1
Vicks OP
I love sand !!!
Vicks's Avatar
Oddometer: 3,154
in"sight" to the 990 Fuel pump
i managed to open up the fuel pump on my '07 990S and give it a thorough look inside. It looked good except for some grains of dirt and a few metal looking filings, which were filtered by the dual filters (good - they are doing the job). Of course the pump O-rings were damaged (even before i opened removed the pump) must be a installation related damage ?
here are some pics.. i hope you guys will find them usefull.
the complete fue lpump assembly
the two O-rings
they are of different sizes. The larger Dia O-ring is thinner and the small dia O-ring is thicker by 0.5mm
measuring the larger dia O-ring (thickness 3.0mm)
the smaller dia O-ring is thicker (3.5mm)
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 05-07-2009, 05:27 AM   #2
Vicks OP
I love sand !!!
Vicks's Avatar
Oddometer: 3,154
the pressure regulator and upper (circular) filter assembly
assembly opened up
Old 05-07-2009, 05:33 AM   #3
Vicks OP
I love sand !!!
Vicks's Avatar
Oddometer: 3,154
the fuel pump itself
the pump's vanes can be seen here
pump Identification no. ?
The crescent shaped filter (this is the one which getrs blocked with dirt/grime from bad fuel)
The pump connection tabs
If you have forgotten to note down which wire goes where, don't sweat. The polarity is marked on the plastic. Red wire goes to "+" and the Black one to "-"
Vicks screwed with this post 05-07-2009 at 05:40 AM
Old 05-07-2009, 06:52 AM   #4
911racer
dare to explore
911racer's Avatar
Oddometer: 471
Question
Great pic's, thanks for posting. makes me wonder if it would be possible to retrofit some sorta automotive style fuel filter to replace the "sock" filter. I will be traveling around South America for about a year and I know other people have had problems with dirty filters and failing fuel pumps. I have yet to take my pump apart but it would be nice if I could fit a generic/common car or truck style filter in there that I could easily find replacements for in the middle of Argentina and doesn't cost $100+.
Is this possible?
You must become ignorant of all you've been tought
And be, instead, bewildered!
Run from what's comfortable and profitable.
Run, run, run!
If you drink those sweet liqueurs you'll spill
The springwater of your real life.
Forget safety
Live where you fear to live.
Be notorious
Destroy your reputation.
You have tried prudent planning for long enough.
From now on, live mad.
-J. Rumi, born 1207, a sifi mystic poet.
911racer is offline   Reply With Quote
Old 05-07-2009, 07:48 AM   #5
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,040
Is this possible?
I know the pumps are pricey, but if i were to ride my 990 to S.A. I would
carry a spare pump and a set of filters.
When I rode my 950 down a few years ago I carried a fuel pump and H2O
pump rebuild kit.
I picked up my SE to ride back to Bolivia this fall. It's far simpler to work
on than the 990 with no ABS or EFI. But then again I've ridden my 990
over 25,000 miles in rough conditions with no issues and will leave in a
few weeks for two months of two up riding through Alaska and Canada,
on the 990.
Thanks for the tear down pics Mr.Vicks.
It would be helpful if someone could find a place to buy just the fuel pump
part of KTM's fuel pump assembly. It would save $ and be more compact to carry.
Twist it, MAX
Da oggi la strada
é senza limiti
MAXVERT screwed with this post 05-07-2009 at 07:54 AM
MAXVERT is offline   Reply With Quote
Old 05-07-2009, 08:22 AM   #6
Scribe
£Bob£
Scribe's Avatar
Oddometer: 7,425
Don't have a 990, but those pricey o-rings look a lot like some that came with a set of o-rings I bought at Harbor Freight for about $10, IIRC. It was an entire range of metric sizes and thicknesses. Paying $60 for those things is robbery.
"Do or do not. There is no 'try.'"
— Yoda
Man Ball Rolls Through Coloutahrado 2014!
Scribe is offline   Reply With Quote
Old 05-07-2009, 10:56 AM   #7
aage
Oddometer: 76
Look what I found on Ebay
Not sure its the same pump BUT
I googled MK5 Fuel pump and this is what came up.
http://cgi.ebay.co.uk/WALBRO-255-FUE...23139004r13097
maby its the same ?? its listed for 80 pounds uk.
aage is offline   Reply With Quote
Old 05-07-2009, 11:09 AM   #8
aage
Oddometer: 76
This is a fuel pump seller
http://www.nolimitmotorsport.com/walbro/
I have no idea if any of these pumps works or not for our bikes. Hope there is someone here with enough knowlidge to find out.
Old 05-07-2009, 12:27 PM   #9
Vicks OP
I love sand !!!
Vicks's Avatar
Oddometer: 3,154
Is this possible?
After doing the pump, i understand (pls correct me if i'm wrong) that the each of the inlet and outlet for the pump has a filter. The pump Inlet has the crescent (sock) filter and the outlet has the round paper element filter.
Its usually the crescent/sock filter which gets clogged and once this happens, the fuel flow slows down, thereby giving the characteristics experienced by many. During this clogging, if you shutdown the bike and start it again, the clogged filter probably gets freed up a li'l bit and then you get another few miles of riding before it gets clogged due to the dirt. The fuel pump itself looks pretty sturdy in design to me and i feel that all the 990 fuel pump problems (or atleast the majority of them) are due to failing filters, and not the pump mechanism itself.
If we can find a filter which will fit inside the tank, similar in size (filtering area) to the existing sock filter, and if we can manage to connect it to the fuel pump nozzle (by means of an adapter/pipe/reducer/connector etc) then we have a solution.
I'm trying to come up with a drawing to explain this .. shall get back in a while.
Old 05-07-2009, 12:30 PM   #10
Venteuri
I don't give a shit
Venteuri's Avatar
Oddometer: 15,358
Excellent information Mr. Vicks.
Thanks for that and the time you took.
BMW R1200GSA 2014
Member #68,893
Above all stop pandering to posts from morons like Venteuri who can't even spell Venturi properly.
Venteuri is offline   Reply With Quote
Old 05-07-2009, 12:38 PM   #11
Vicks OP
I love sand !!!
Vicks's Avatar
Oddometer: 3,154
back home in Indiyeah, we have a saying that goes like "pour the water that you take from the pond, back into the pond"
i'm just doing that. i'm giving back to the pool from which i have learnt most of what i know today.
cheers guys
Old 05-07-2009, 12:51 PM   #12
Venteuri
I don't give a shit
Venteuri's Avatar
Oddometer: 15,358
maybe this helps.
BMW R1200GSA 2014
Member #68,893
Old 05-07-2009, 12:57 PM   #13
Vicks OP
I love sand !!!
Vicks's Avatar
Oddometer: 3,154
maybe this helps.
no it doesn't help
cos i ain't gonna spend 100s of dollars on that thing when i can think of a cheaper solution.
something like this. its still an idea, but let me see if i can make it materialise.
Old 05-07-2009, 01:59 PM   #14
Gimme 2
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,066
Fken A. i just go to the local bearing shop for those 1 dollar each and they are the ones that are viton, gets me all my steering head bearing with races complete, wheel bearings at a third or less of the oem, which is exactly where they get them from any way , the only time i had trouble was with a honda big end bearing, which is made special by a honda subsidiary i supose.
Gimme 2 is offline   Reply With Quote
Old 05-07-2009, 06:03 PM   #15
Autostream
Autostream's Avatar
Oddometer: 5,833
i managed to open up the fuel pump on my '07 990S and give it a thorough look inside. ....here are some pics.. i hope you guys will find them usefull....
Thanks for that, did you perchance take a shot of the pump assembly with filter sock attached?
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream is offline   Reply With Quote
Times are GMT -7.   It's 03:30 AM.
