Go Back   ADVrider > Riding > Regional forums > The Sandbox - AKA Flatistan
Old 12-27-2011, 02:52 PM   #1951
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,052
Originally Posted by motomike14 View Post
Technically not on craigslist (trying to avoid bonkers people), but looking to sell my 1976 Honda CB750K. I recently bought a bike to start doing some light sport touring with, so something has to give.
Technical stuff; motor is all original with 24,xxx miles. Runs perfect. Internals are stock, but has a max 4-into-1 header and muffle (not an open baffle; nice sound to it but not too loud). Also installed a Dynatek eletronic ignition, which makes starting a piece of cake. Just recently serviced the carbs (cleaned thoroughly), changed the oil and reoiled the pod filters.
Cosmetic; fiberglass tank and seat combo from Benjie's cafe racer. Cost over $800 new, without paint. Painted to resemble a Norton manx. Frame, swingarm, fork lowers have all been powder coated. Passenger peg lugs have been removed and welded over. Also has some neato LED lights to light the tag. Hideous light bar has been removed and replaced with a neutral light and oil pressure light built into the tachometer.
Other stuff; progressive road shocks and heavy duty front springs make it a handler. Bridgestone spitfire tires have less than 2,000 miles and show hardly any wear. Bronze swingarm bushings and all balls steering head bearings have been installed as well. Low center of gravity makes it a blast in the corners.
Nit picky stuff; the fiberglass tank looks cool, but has one minor issue. The painted I hired did not use the correct primer, so it has some bubbling and blistering. Sealed it with caswell over 2 years ago and inside had held together nicely until recently; one spot on the stem/center of the tank has separated slightly. I believe if you reseal it and apply some weight to the area, it would reseal without difficulty. I will do this for you if you choose to purchase it; just buy the caswell and give me 3 days with the tank.
Other bugger is the starter button. When I bought it, the button fell inside the handlebar control. I have meant to buy a new one, but kick starts easy. The starter does work; most guys hook up an external switch. But, a career and laziness on my part has prevented me from performing this operation the last 3 years.
Included is a box of spare parts including some original stuff like the tank, rear fender, turn signals and a host of other things. Also have a set of clubman bars for those so inclined to ruin their wrists.
Clean FL title in my name and all of the manuals. Asking $3,500. Not too interested in trades unless you have a Husky TE310 or TE450 that is not beat to death. Would also consider throwing in my XR600 in a trade if it's a newer model.
Ok, ok, we can add some more incentive to the deal.
Also have a 1971/72/73/75 Yamaha XS650. The downlow;
Mechanical: 1971 motor with 750 Shell Thuett Kit, megacycle cam, balanced crank, lapped valves w/heavier springs, barnett clutch with heavy duty springs, 34mm Mikuni carbs with K&N air filters/extended intakes, 2 into 1 kerker/mac exhaust (such a sweet, sweet sound), stock electrics and battery less than a year old
Cosmetic: 1972 frame, chrome "Superbike" bars, powder-coated frame (Cadillac brown; welds were shaved down, very nice job many years ago), 1975 tank with the older two screw type petcocks, Bonneville rear fender and fiberglass front fender, gold pin-striping (not the best job, but neat for its age), stock seat from a 72, front drum from a 71 (dual leading shoe), small rear brake light with tag mount on the side
Has been with the same owner (my dad) since 1993. I've kind of become its caretaker in recent years. Runs very well and is a hoot to ride in a straight line.
Known issues (being upfront):
1) Base gasket does have a leak in the lower left hand side. Tried to seal with Yamabond and some other stuff from the outside. Worked for a while, but recently has started to leak again. Really needs to be sealed from the inside, but I haven't sealed it for the last 4 years, so another go may help greatly.
2) Tires are dry rotted and I would replace if you plan on riding any considerable distances (I've been riding it to work every other week or just a quick 20 mile ride just to keep it going the last 2 years).
3) Steering head bearings are original, and hence, are on their last leg. Taking your hands off the bars any speed over 20mph and it wobbles a bit. Otherwise, it's good. Swingarm bushings are original and still tight as a drum.
4) I recently replaced all the seals in the petcock. Have been working well, but the right side will dribble while riding it now and then. The main seal needs to be repositioned I believe.
This is a great retro ride for bikeweek or something to ride on a Sunday morning during riding season. With the 750 kit, it makes a noise like no other XS650. Still has the stock springs/shocks and is very comfortable to ride. Not a sport bike by any means, but does not cramp your hands or anything.
Also have a quarter fairing in matching brown with a bubble screen. Screen has a crack in it after unloading out of a friends van many years ago. So, it's been shelved since.
Clean FL title (as a 72). I love this thing, but we my dad and I have a garage full of bikes, and the CB and XS keep getting shuffed aside for other projects/rides.
Open to reasonable offers on the XS. Would make a package deal with the CB if you are so inclined (would really like to see them both end up in good hands).
"Living just to keep going, goin' just to be sane." - The Black Keys
I prefer kick starters, air-cooling, and carburetors over anything.
motomike14 is offline   Reply With Quote
Old 12-27-2011, 05:12 PM   #1952
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 653
Originally Posted by fatalerror View Post
'84 IT 490 $1200
http://sarasota.craigslist.org/mcy/2732593494.html
I had one of these back in the day.... frikkin monster....
and a KX 500 for $1550!!
http://sarasota.craigslist.org/mcy/2759062877.html
^^^ got mine for 500$. guy is an asshole for asking 1200$ for an old dirt bike. though the best part is that mine was street legal
1994 Yamaha WR250-Z | 2005 Gas Gas FSE450 | 1998 Kawasaki KLX300 | 2004 Honda CRF450R (Motard)
"Great! What am I supposed to use now?! Harsh language?!?!?"
- Duke Nukem
Sub Zero is offline   Reply With Quote
Old 12-28-2011, 06:37 AM   #1953
fatalerror
skrik vir niks
fatalerror's Avatar
Location: South West Florida, USA [formerly, South Africa]
Oddometer: 827
I had one of those when I was 19... damn thing was scary...
fatalerror is offline   Reply With Quote
Old 12-28-2011, 08:48 AM   #1954
FloridaSteve
FloridaSteve's Avatar
Oddometer: 2,070
Wow! Street Legal. Listen I realize that people say this sort of thing all the time No Joke... I'm a certifiable 2 stroke lunatic. (See my blog below in my sig line). If you EVER want to sell this bike PLEASE PLEASE PLEASE let me know. That's a borderline dream bike for me.
FloridaSteve is offline   Reply With Quote
Old 12-28-2011, 11:23 AM   #1955
Chicken Helmet
I'm A Stumper™
Chicken Helmet's Avatar
Oddometer: 3,948
Originally Posted by Buzztail View Post
Now I'm no Machinist, but.....
I have a 440 that needs some more cubic inches. An 880 mountain motor must be easy to do for this guy...
Sean
1988 KLR 650 Parts For Sale PM for Details 2009 KLR 650 1994 DR 350
Originally Posted by RonSavage View Post
KLR's are chick magnets.
Chicken Helmet is offline   Reply With Quote
Old 12-28-2011, 02:48 PM   #1956
Buzztail
8 lug oil burner
Buzztail's Avatar
Oddometer: 9,347
I got a buddy with a bunch of 392 hemi stuff.... We should go that route
When there is no way out - Find a way further in.
690 DL650 DR350 MMS Edition Past bikes
Buzztail is offline   Reply With Quote
Old 12-28-2011, 04:45 PM   #1957
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 653
I sold it for 600$ in February this year
- Duke Nukem
Old 01-01-2012, 10:36 AM   #1958
MOTO DUDE
Rydin Dirty
MOTO DUDE's Avatar
Oddometer: 123
1988 Honda NX250 - $750
kinda' cool
http://gainesville.craigslist.org/mcy/2777473323.html
MOTO DUDE is offline   Reply With Quote
Old 01-02-2012, 04:12 AM   #1959
Retro
Just the Facts Ma'am
Retro's Avatar
Oddometer: 31,969
ADV Rider does not facilitate firearm sales
Hey guys, please remember that ADV Rider does not allow the sale posting of firearm or firearm items in the sale threads.
I'm just lookin' for clues at the scene of the crime.
Quis custodiet ipros custodes?
Retro screwed with this post 01-02-2012 at 12:41 PM
Retro is offline   Reply With Quote
Old 01-02-2012, 08:46 AM   #1960
FloridaSteve
Oddometer: 2,070
is right. I'd have given you a thousand... Oh well.. Any idea how it got slipped past he DMV for the tag?
Old 01-02-2012, 01:03 PM   #1961
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,423
Check
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 01-02-2012, 02:39 PM   #1962
Retro
Retro's Avatar
Oddometer: 31,969
Old 01-06-2012, 10:05 AM   #1963
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 653
I guess the lady behind the desk thought i was cute.
- Duke Nukem
Old 01-06-2012, 10:08 AM   #1964
Sub Zero
Ice Breather!
Sub Zero's Avatar
Oddometer: 653
If anybody has a supermoto they want to trade for an older street bike i would very much be interested
http://orlando.craigslist.org/mcy/2785224996.html
even older bigger bore dual sports with street tires I would be interested in (XR600R, KLR600, XT600, XL600R etc etc)
- Duke Nukem
Old 01-10-2012, 08:00 PM   #1965
ineptizoid
Ineptus Interruptus
ineptizoid's Avatar
Oddometer: 4,314
I always thought the VX800 was a great idea: a shafty V-twin UJM, Suzuki's answer to the CB750. But what do I know? They weren't exactly a sales success, and don't bring much in the used market. Worth every bit of $1400, though
http://pensacola.craigslist.org/mcy/2793803828.html
*FAIL*
Everything I really needed to know, I learned in Schneider School.
Official Organizer of the ADVrider Sandbox Hooligans Anti-FEE Movement
Quoth the Photojournalist: Am I gonna be the one that's gonna set them straight? Look at me--WRONG!
ineptizoid is offline   Reply With Quote
Times are GMT -7.   It's 03:12 AM.
