05-14-2009, 11:09 AM
#16 | |
Oddometer: 9,781
05-14-2009, 01:06 PM
#17 | ||
for a corrector life
Oddometer: 13,152
yeah, i gotta replace an o-ring that you don't have to worry about. decarbonizing the head/piston? if i go this route, what kinda cleaner is recommended. my bike only has 17K on it and the oil is damn clean after 500 miles and there no smoking or anything under hard acceleration. not sure it's a huge need at this point.
05-14-2009, 01:17 PM
#18 | |
Wacky Bongo Boy
1974 BMW R75/6, 1974 BMW R90/6, 1969 BMW R60/2 hack, 1929 Ford Model A, Metal casting, Part 2/Part 1 among others.. |
05-14-2009, 01:21 PM
#19 |
Horizontally Opposed
Oddometer: 5,294
Don't bother decarbonising
You'll just create a big mess of gooky shit that you can clean out again sometime not so soon....
Try runnin' it a tad leaner... it'll burn off! But not TOO lean...it'll burn up!
'65 R60/2 '68 R60US '74 MG Eldorado '95 R100M |
#20 | |
Wacky Bongo Boy
![]() While disassembling one of our new-to-us antique engines, we needed 4 hands to remove a valve spring keeper. I got it off while my brother compressed the spring. In the blink of an eye, the valve spring shot against my arm, the keeper bounced off, landed on my brothers shoulder, and the spring landed on another project. I've got a pic of the spring/keeeper grease print it left on my arm. I'll post it when I find it.
05-14-2009, 05:20 PM
#21 |
+/- V TDSPP
Oddometer: 19,946
So weird, I just developed this strange tic on the left side of my face
feelin kinda woozy. Is that nostalgia?
What to do... What to do... |
05-14-2009, 05:38 PM
#22 |
Oddometer: 7,760
Push it out next to the road and put a "for sale" sign on it.
05-14-2009, 06:29 PM
#23 |
Confirmed Curmudgeon
Oddometer: 3,904
Yes! Safety glasses are a plus. I had the early-style wire clip sproing me in the eye last Fall.
The early wire clips can be at PITA to wrestle in with the cylinder in the way, so I prefer to remove the cylinder on those. The later type circlips are easier to work with so on later bikes I pull the piston+cylinder.
'73 R60/5 Toaster |
05-14-2009, 07:12 PM
#24 | |
Beemerholics Anonymous
Oddometer: 7,361
It may be clean in there, or maybe not. Most likely not. Soaking in carb cleaner helps, but I'm not really sure the best way. I've mostly just scraped the stuff off - it's pretty brittle and pushing on it edgewise with a screwdriver will shear some off. Gotta be careful, though, to not scratch or scrape the aluminum. You want it all smooth so new build up won't have a rough spot to attach to.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
05-14-2009, 10:56 PM
#25 |
Adventman
Oddometer: 1,236
So here's the million dollar question: When you put in the new push rod seals, do you go dry, use gasket seal, or do you use oil or grease
I personally use a light coat of grease, and tap in the tubes lightly as they start to leak. I'm at over 40k miles on mine and will be changing them tomorrow.
"¿Qué sería de la vida si no tuviéramos el valor de intentar algo nuevo?" Van Gogh... "Your the only guy i've met driving a BMW who isn't an asshole." D. Irwin... |
05-15-2009, 12:03 AM
#26 |
Oddometer: 3,739
I've got access to a bead blaster at work. Takes all the hard work out of decarbonising. In the past I've always scrapped it out.
![]() ![]() Theres no substitute for clean parts. Makes working on the bike a pleasure instead of a chore.
05-15-2009, 12:17 AM
#27 |
Woolf Barnato
Oddometer: 29,150
Make it a challenge, only use hammers, chisels and punches. Any parts left over, you have to eat.
'Gonna get me a six pack...push people off the highway!' "they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood." "I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!" "Yeah, that guy sure is terrible at touching moms" |
05-15-2009, 06:30 AM
#28 | |
+/- V TDSPP
Oddometer: 19,946
05-15-2009, 06:38 AM
#29 |
Dare to be Stupid
Oddometer: 3,800
here's the ultimate solution to all oil leaks of any sort on your bike--paint the engine black so you don't see 'em
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind Proud SmugMug User Support ADV: Don't give those cheap bums your discount code |
05-15-2009, 07:41 AM
#30 |
AKA. Shineyboydudley
Oddometer: 336
I took my pistons out as I needed to clean everything up ( Got 80,000 miles on clock)
I used a bead blaster to clean the muck off and made my own push rod tubes out of stainless steel. I used grease round the tops of the tubes and tapped them in with a hammer. I think i used engine oil round the rubber seals and no leaks yet. ![]()
