Old 05-15-2009, 08:19 AM   #1
mdfehrmann OP
mdfehrmann's Avatar
Oddometer: 338
TPS Sensor Questions
I searched for this and I'm sure the answer is here but I couldn't find it.
What does the TPS actually do? Does it make adjustments to the timing based on the throttle position?
I have a 06 950 if it makes a difference.
Thanks dudes!
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo-
2006 KTM 950 ADV S - 2004 Sherco 2.9
http://www.mdfeditions.com/
http://www.cjdesignsllc.com/
mdfehrmann is offline   Reply With Quote
Old 05-15-2009, 08:47 AM   #2
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,120
deleted post due to uncertainty's still wheter it is actually used beyond emission stuff.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD screwed with this post 03-15-2013 at 10:05 AM
StevenD is offline   Reply With Quote
Old 09-07-2010, 02:31 PM   #3
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,944
950 CARBS, Surging and TPS
FOR 950 CARBS - the Throttle Position Sensor, TPS, sets the ignition advance. The ignition set the advance based on Engine RPM and Throttle Position. This is called a 3D Map, 1. RPM, 2. TPS, 3. Ign Advance.
When you turn on the ignition, the small computer in the ignition looks for a 'referance voltage' to determine if the TPS is in range. The voltage should be 0.5-0.6 volts when the throttle is shut. You should always have the throttle shut when turning on the ignition.
This referance voltage is set at the factory at engine idle. BUT, if the idle is turned down during the break-in period, then the referance voltage may be wrong! You may need to reset the TPS after the engine loosens up and the idle position is different. I've seen several 2006 950 Adventures with a too low voltage of 0.38 v. These had a bad surge around 3000 rpm. Reseting the TPS usually fixed it without re-jetting.
If the ignition doesn't see this voltage during start up, it may not set the advance correctly and you'll get a surge between 2000-3800 rpm. This acts just like a lean carb condition. It can be masked by richening up the carb low speed mixture screws or low speed jets, but you'll get poor mileage and a weak low rpm throttle response. If the TPS is dirty or worn, you can get the same erattic behavior.
The workshop manuals show how to set this. I'd recomend to try a resultant voltage very close to, but below 0.6 v. Check it several times by turning off the ignition and make sure you still have the same voltage when you turn it back on. Make sure it tracks voltage smoothly as you open/close the throttle. Any jumps, dead spots or other flaky action means you need a new TPS.
I did a search for this subject and only found fuel injection subjects. If anyone knows of a thread, please add the link.
(Edited on 2-20-11) .... Check this voltage between the Yellow and Black wire. Some early manuals have it different (blue/yellow) which is wrong. Just push the probes in past the rubber seals to touch the connectors. It is most critical to get the closing voltage between 0.5 and 0.6 v.
"Son, you can't do both"
Zuber screwed with this post 02-21-2011 at 07:28 PM
Old 09-07-2010, 03:23 PM   #4
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Zuber,
Thanks for explaining the TPS in such great detail... I was wondering about this.
I found my this wire connection had slipped off the Carb (due to loosening copper connector) last week and wondered just how much it affected the bike without EFI.
Thanks again....
AdvGa is offline   Reply With Quote
Old 09-08-2010, 08:41 AM   #5
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,121
This is very timely post for me. I pulled mine off after ridding the bike of the emissions crap and doing a valve adjustment and replacing the carb vents, etc. , and it's smoother but feels slower. That may be an illusion...gonna have to put it back on and set it up properly and see the difference...now that I know how.
Great post...Thanks!
*edit* This really should be added to Wisdom section.
2005.5 KTM 950 Adventure
2005 Ducati ST3
Chuckracer is online now   Reply With Quote
Old 09-09-2010, 10:18 AM   #6
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,121
Follow up: Yeah, it's definitely slower...doggy. I guess it's not getting any ignition advance? If you give er a handful, it still goes though.
I just re-installed the wire and set it as per Zuber's excellent instructions, with help from the manual on CD. Easier than I thought it would be. One tip though: as the tanks are off the bike, when you turn the key on the pump starts and blows what gas is left in the lines straight up in the air. If you're standing on the left side of the bike like I was...well, it's laundry time anyhoo.
Stand on the right side of the bike when you do this!
Haven't had a chance to ride it yet as the weather sucks here today.
2005 Ducati ST3
Old 09-10-2010, 03:04 AM   #7
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,469
Zuber you're a gosh darned life saver :)
I've been chasing a surging problem on my 950 for months now, fiddled with the carbs endlessly, I even checked the TPS.
BUT ...
The repair manual says the TPS should give .5-.6 volts when closed and 3.6 when fully open. Mine seems to have a slightly wider range, so I had guessed that the open voltage was the important one, and set it so that the range was about 0.4 - 3.6. How wrong I was! So now I've adjusted it to give 0.6 closed and about 3.8 open. What an improvement. The surging was not terrible but it was enough to make it very annoying when riding at low speed round town for example.
So thanks for that info :)
Also, the repair manual says measure the voltage between the blue and yellow wires, however on my bike it's the blue and black wires that give this voltage. Mine's an early bike (2004) maybe they were wired differently.
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 09-11-2010, 04:37 AM   #8
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Nice find!
ktm950se
ktm950se is offline   Reply With Quote
Old 09-12-2010, 01:45 AM   #9
Zpider
Oddometer: 97
So the conclusion is that carb bikes DO need the TPS after all. Mine is broken, just sits there and give way false readings in voltage, but i cant really tell if the bike runs as it should, all i know is that it runs ok. I can however feel that its not that crisp in the range of 3000 - 4000 rpm. Maybe time to get a new TPS after all....
BMW R1200GS Adv 2008
http://www.weirdperformance.se
Zpider is offline   Reply With Quote
Old 09-12-2010, 09:43 PM   #10
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,121
I think so. I ran mine without one at all and it was kinda doggy at lower RPM's, but very smooth - NO throttle jerkiness what so ever. That tells me it was mis-adjusted before...well, I'm sure it was cause I was messing with the idle setting constantly.
Valve adjustment, carb sync, fuel screw adjustment and replacing the vent lines and it's never run better. The idle is consistant now. I put the TPS back on after seeing this post and set it up, and got the low RPM response back without the snatchiness.
2005 Ducati ST3
Old 09-23-2010, 01:53 AM   #11
men8ifr
Oddometer: 383
Please post on here if you notice any fuel economy differences when the TPS is back workign again, I'm interested in this.
men8ifr is offline   Reply With Quote
Old 12-04-2010, 06:27 PM   #12
tejaspuke
tejaspuke's Avatar
Oddometer: 25
BUT ...
Mine bike is an 06. The blue and yellow wire voltage was 4.3v closed and 1.3v fully open. I checked the blue and black and the voltage is .6v to 3.6v. Thanks for the tip!
tejaspuke is offline   Reply With Quote
Old 02-15-2011, 08:11 AM   #13
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
same on my 04 I thought the sensor was busted initialy but I guess not.
black and blue it is
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 02-16-2011, 06:17 AM   #14
Problem0
Problem0's Avatar
Oddometer: 17
Cry Caution
Just a word of caution - When you set the TPS up in a cold garage, make sure the carb heaters are disconnected, as they suck a bit of voltage and could leave you with a flat battery: or if you have no fuel in the carbs they could damage the seals leading to a fuel leak when reconnected and then catch fire when you try and balance the Carbs.
please don't ask me how I know.....
2005 KTM 950 Adventure
Sold ** 2003 KTM 640 Adventure
Problem0 screwed with this post 03-09-2011 at 03:02 AM Reason: grammer
Problem0 is offline   Reply With Quote
Old 02-16-2011, 08:06 PM   #15
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
*correction*
black and yellow WTF?
Times are GMT -7.   It's 06:27 PM.
