Old 01-10-2012, 03:00 PM   #151
Dustodust
Dustodust's Avatar
Oddometer: 1,075
guess I'll find out because I just ordered one 5,5 from universalparts over the phone , They answered right away $47 shipped , late in the day and said I just missed the truck but it will go out tomorrow
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Old 01-11-2012, 09:46 PM   #152
Blakduk
Just trying to get by.
Blakduk's Avatar
Oddometer: 1,274
Any ideas where I can get a plastic shroud for the RIGHT hand side to keep the heat from my 2nd fan off the tank?
edit: Sorry, previous page - I see you've modified a LHS shroud.
FE450.
XT660R
Blakduk screwed with this post 01-11-2012 at 09:56 PM
Blakduk is offline   Reply With Quote
Old 01-11-2012, 10:06 PM   #153
xcflyn
xcflyn's Avatar
Oddometer: 1,153
I believe it is mentioned here that people use the left side OEM part and do a little trim work. I read also that some dont do anything. I will tell you that you probably need to do something to get the heat away from the tanks. I am ordering heat reflective material and doing the insides of my tanks. My fuel boils like crazy if im doing a lot of technical slow riding, and its only been in the 70's and 80's. I just read a thread about someone having fuel delivery issues from fuel boil
xcflyn is offline   Reply With Quote
Old 01-13-2012, 06:52 PM   #154
Autostream
Autostream's Avatar
Oddometer: 5,833
Right shroud - post 135 shows my solution
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream is offline   Reply With Quote
Old 01-24-2012, 10:43 AM   #155
Dustodust
Dustodust's Avatar
Oddometer: 1,075
I got the 5.5 Spal from universalparts, I unscrewed the motor from the generic housing and pressed off the fan blade , I switched it over to my 950 fan shroud and pressed the new blade on , it pressed back on nice and snug , tested it on the bench and it runs smooth and balanced . Soldered on the KTM plug nice and clean, back in bussiness
it was a $40 replacement instead of the KTM part at $140
my fan had been failing intermittently and during an 800 mile trip to Death Valley I discovered it totally seized
04 KTM 950 S
Old 02-09-2012, 08:02 PM   #156
rinho
Rinho Féroce
rinho's Avatar
Location: back in France but Soul still in North America
Oddometer: 1,159
something similar happen to my wife's bike (4:pm, July 3rd !)
That' also why I want a 2nd fan
Sans un sou mais plus riche qu'avant
rinho is offline   Reply With Quote
Old 02-10-2012, 02:22 AM   #157
Blakduk
Blakduk's Avatar
Oddometer: 1,274
I'm going to muck around with some heat shielding first, taking the tank off to stick it on this weekend. I really think the people who sold me the proper '2nd fan kit' should have addressed this aspect. After all, I think I paid well over $100 for the fan and bracket......
FE450.
XT660R
Old 02-10-2012, 12:34 PM   #158
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
Understood. The addition of some form of a hard shield has been on the "to do" list. Applying a adhesive insulation to the tank is one way that works well.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 03-04-2012, 08:15 AM   #159
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 1,159
I've started my bracket
Just did a mistake and cut a part wich was supposed to stay to be the upper bracket ...
I'll do a 2nd bracket, attached to the fan screws in order to correct this.
I used 0.05 alu to do a first try (easier to bent) but I finally guess it's stiff enough, especially when the 2nd part will be done
Old 03-04-2012, 09:02 AM   #160
xcflyn
xcflyn's Avatar
Oddometer: 1,153
Very nice work. I wondered if it was the desire to fabricate your own or why you did not purchase one, I believe you can get just the bracket for $24.00 (dont quote me on the price), when I did mine I was going to buy a generic fan and go the same route as you but then found the complete fan/bracket combo and went that route. I certainly understand if you chose to make your own because clearly you have the skills to do it and it looks really solid. More wondered if you did something that you feel will help draw more air or re-direct the air flow ? After all the wheel has been reinvented many times over and it is still getting better.
Always hated that when people would ask :why reinvent the wheel ? , " because it aint perfect like you " .
Old 03-04-2012, 01:27 PM   #161
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 1,159
Well, yes, I like to do things myself (thanks for the compliment) and yes I feel concerned about how the air is drawn...
But if the bracket (wich was out of stock when I started) was available, alone, for 50$ or less, I would not have spent any time working on this one... for sure.
I have understood on thing... Whatever I do, there's one thing I'll never have enough, it's time!
Old 04-26-2012, 02:20 PM   #162
Faunus2011
Faunus2011's Avatar
Oddometer: 63
Just ordered my ADVmachines dual cooling fan... Have a 2500 mile trip planned next month, so its gonna get a trial by fire, especially being that all 2500 miles will be in the deep south!
Faunus2011 is offline   Reply With Quote
Old 04-26-2012, 03:00 PM   #163
Unkgd
Oddometer: 350
It will be great!
Put this fan on my 990ADV last year right before a 5 day trip into the Mojave Desert and it worked great. Sand, slow speed and 120 degreesF and no overheating problems!
Unkgd is offline   Reply With Quote
Old 07-12-2012, 12:57 AM   #164
crazybrit
crazybrit's Avatar
Oddometer: 8,554
fan connector question
Looking at the manual, ktm parts for the fan connector seem to be:
000700000BI SPARE CONNECTOR BI 2-PINS (fan)
000700000AU SPARE CONNECTOR AU 2-PINS (wiring harness)
Does anyone know the generic type (manufacturer/part#). Is it D2CP/D2CS from here? http://www.corsa-technic.com/categor...category_id=57
crazybrit is offline   Reply With Quote
Old 01-26-2015, 09:02 AM   #165
deeve
DumbA$$
deeve's Avatar
Oddometer: 1,354
Old post resurrection time...but did you find an answer to this question?
2010 KTM 990 Adventure-Nuclear Fusion Powered
deeve is online now   Reply With Quote
Times are GMT -7.   It's 10:02 PM.
