09-14-2011, 12:07 PM
#46 | |
Retro Rider
Oddometer: 534
WalMart or the like has the self stick velcro.
06 950 Adventure 96 Beta Techno 07 450 EXC 04 FZ1 |
09-14-2011, 12:32 PM
#47 | |
let's keep going...
Oddometer: 987
FWIW there have been a few posts over the years RE: people breaking the TT lockable & locked GPS holders off bikes, one in a National Park parking lot with lots of people around. Just saying don't trust it too long or far away from you, I guess. damn thieves anyway
Britt '06 KTM 950 Adv 'S' '03 KTM 250 EXC '88 KLR650 - +170K miles "looks like you've had a lot of fun on that bike..." |
11-09-2011, 05:41 AM
#48 |
Oddometer: 253
Thanks for the ideas! Here's how I did it.
Got a RAM ball that mounts with a M8 bolt, #RAM-B-367U. Wanted to use 3mm thick L-shaped aluminum, I knew I had some, but couldn't find it. Took a piece of 80mm x 40mm and cut it to L-shape. ![]() . Made a slight bend to match the lines of top console. . Test fitting, marking four holes and drilling. Used couple of bolts with three nuts as spacers between brackets to secure it in place. Drilled small guiding hole through plastic and aluminum bracket. Then 8mm hole to bracket and 11,5mm to plastic. Trimmed bracket to its final size, some filing and sanding to round corners. Put some self vulcanizing tape around the base of RAM ball to hide clear aluminum and give it a snug fit through plastic cover. Also found the piece of L-shaped aluminum I was looking for earlier.. ![]() . And there it is. ![]() ![]() ![]() I'll do the wiring later. GPS's battery is good enough for short trips. Edit: Got the wiring done. Just soldered the leads together with the heated grips plugins connected to ACC2. Enlarged the hole for RAM mount to get the power plugin through and put a rubber grommet to give it a snug fit.
Masa screwed with this post 01-28-2012 at 05:08 AM Reason: Wiring done |
11-10-2011, 01:10 PM
#49 |
Oddometer: 76
Now that's reinforcement -- I just used a piece of flatbar underneath.
11-10-2011, 02:47 PM
#50 |
Oddometer: 513
Yee gods, that is one meaty bracket!!! I used 2mm aluminium, and thought that was overkill!...
PS - great job, but your nylock nuts are not locked - too short bolts.
---------- Current Bike (number 66!!): 2008 KTM SE 950 R ------------ http://950SuperEnduro.com |
11-10-2011, 03:52 PM
#51 |
Confused Hack Nut
Oddometer: 2,518
Just buy a Yoke Mount - $10
Add some braces under the bracket and voila!
Ken => I'm a DAMN Rider (No rules, just ride!)
Happiness is a 3-wheel drift! Member of the Maryland OHV Alliance |
11-10-2011, 07:13 PM
#52 |
Oddometer: 296
i have the ball mount to the top of the dash, it came that way when i bought the bike.
11-10-2011, 08:29 PM
#53 |
Just Love Bikes
Oddometer: 741
KTM 990 Adventure Home made Garmin GPS Mount
AMA Earned Life Member • Iron Butt Association Member suttoncycleworks.com Honda XR650L XR600 NX650 Oil Cooler Kit • KTM 990 Adventure • Honda CRF450 Supermoto • H-D Sportster Streettracker • Honda XR650L |
11-10-2011, 09:31 PM
#54 |
Oddometer: 153
The Cheap Option
Here is my gps mount. Cost, $10 for the ram-mount cradle, piece of scrap aluminum and a couple bolts.
11-10-2011, 09:36 PM
#55 | |
Oddometer: 294
Yascher screwed with this post 11-10-2011 at 09:41 PM |
11-10-2011, 09:40 PM
#56 |
Oddometer: 153
And how it looks on the bike... like most of the other ones I suppose. I have to admit the whole thing adds up to just enough vibration that when on a dirt road I have to put my hand on it to steady it so I can see my tracks. Of coarse seeing the tracks isn't easy with this model gps anyway.
11-11-2011, 12:56 AM
#57 |
Oddometer: 253
I know. Already picked those and it would have been too long journey (about 8 meters) back to the nut box to pick regulars or longer bolts, so didn't bother.. Don't think it's going anywhere.
******* Wow! That's a beautiful mount you got there GSMark. Hope I had the patience - and skills.. |
11-11-2011, 08:20 PM
#58 | |
Just Love Bikes
Oddometer: 741
All that hard work and it doesn't work. All of these miles and I thought it was working just fine. I am so stupit... ![]() Thanks for telling me.
11-12-2011, 05:01 AM
#59 | |
Confused Hack Nut
Oddometer: 2,518
11-12-2011, 05:15 AM
#60 |
Just a fella.
Oddometer: 106
Touratech damped lockable mount!
A great bit of kit.
Ciao Marco Simoncelli #58. |
