Old 05-23-2009, 02:14 PM   #16
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,353
Originally Posted by Remy
Has anyone tried a vacuum evacuator to remove the FD lube? I've used one to change the oil in a four stroke outboard motor and a lawn mower engine. It seems like it would work for the FD.
The gears are too close to the housing, it wont work.
Jim
Old 05-23-2009, 02:35 PM   #17
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 955
The new final drive service bulletin.......
Measure no. Subject
US 23342824-01 Increased wear in the rear-wheel drive
Status date (mm/dd/yy) Status PQM Problem reference
4/15/09 Accepted
Date created (mm/dd/yy) Created by Organization
4/15/09 Rainer Wanninger US, MOT
Release date (mm/dd/yy) Approved by Dealer release
Allow automatic release
Vehicles affected
E series Engine Body
K25 K25/02 K25/03 K25/11 K25/12
K25/HP K26 K26/02 K27 K28
K29 K29/HP K40 K40/11 K43
K43/11 K43/HV K44 K44/31
Production period (from/to) Feedback (all cases relating to
(mm/dd/yy) Comment on production period measure up to) (mm/dd/yy)
Complaint
The rear-wheel drive displays premature wear in the form of leaking shaft sealing rings or an increased bearing clearance.
Cause
1. Increased temperature and high pressure lead to premature wear on the shaft sealing rings.
2. Metallic abrasion, which is constantly increasing when the vehicle is in motion, significantly shortens the lifetime of
the bearings in the rear-wheel drive.
Measure
For point 1: The gear oil capacities have changed for initial filling and when changing the oil in the rear-wheel drive.
The new capacities:
For initial filling: 200 ml
For changing oil: 180 ml
(The new RSD 05/2009 contains this modification)
For point 2: Regular oil change in rear-wheel drive:
At 600 mi.
every 12,000 mi or every 2 years
(This service interval is all ready in place)
Fault
Fault location Nature of fault Condition
Drive, Drive train, Rear drive Noise While driving
Defect
Main group
33 rear axle
Subgroup
10 Rear wheel drive
Location
00 Rear wheel drive
Defect code Defect description
3310002100 Rear wheel drive Excessive
tooth backlash
Module Area Fault code
Powertrain
CIP / DIS
System State Version
___________________________
Tech. Office report
__________________________________________________ ______________________________
Report no. Subject Link Condition
23344826 Increased wear in the rear-Approved
wheel drive
Measure AG
Measure no. Subject
AG 23342824-01 Increased wear in the rear-wheel drive
2002-2009 BMW OF NORTH AMERICA, LLC. ALL RIGHTS RESERVED.
whisperquiet is offline   Reply With Quote
Old 05-28-2009, 08:50 AM   #18
Throttlerocker!
Giddy up go
Throttlerocker!'s Avatar
Oddometer: 132
Pressure build up=seal leaks?
I lowered my oil level after a short ride as per the update and had an air pressure build up that released when the drain plug was removed. I'm thinking the seals are more apt to leak from this pressure more so than the higher oil level. What do you think?
Throttlerocker! is offline   Reply With Quote
Old 05-28-2009, 11:47 AM   #19
Longer
Longer's Avatar
Oddometer: 168
I have a 2004 R1200GS, I see that the posts all refer to 2005 and newer. Can any clarify for me what I should be doing with the fluid level? I did mine last year and used JVB's video. So far it's been fine, no weeping or anything. I have 60,000km on my bike.
Any insight would be great.
Thanks!!!
Longer
Clap your hands whilst in the shower, this will spray water in all directions.
Longer is offline   Reply With Quote
Old 05-28-2009, 01:25 PM   #20
JimVonBaden
"Cool" Aid!
Oddometer: 53,353
Thanks!!!
Longer
You can safely leave the level as is, or open the 9:00 plug and drain it to level with the plug, your choice.
When I made the video 220ml was the standard, now BMW says 180ml.
Jim
Old 05-28-2009, 01:29 PM   #21
Longer
Longer's Avatar
Oddometer: 168
Jim
10-4. Thanks Jim! I'm due to change my fluid pretty soon anyway, I'll go with the 180 going forward I guess.
Regards,
Longer
Old 05-29-2009, 08:54 PM   #22
Motor-110
...respect my Authoritah!
Motor-110's Avatar
Oddometer: 597
You can safely leave the level as is, or open the 9:00 plug and drain it to level with the plug, your choice. ...now BMW says 180ml.
Jim
Jim
Are you saying if we (I) open the FD drain plug in it's current position (without dropping the FD) will be ~180ml left in the FD?
I will be adjusting mine this weekend in either event. Also, if that is the case, we could use the drain plug as the fill point and not have to deal with the tedious process of filling through the fill point behind the caliper.
Please advise....
Mike
"Fresh BMW's and whisky for all my men!"
M-110
Motor-110 is offline   Reply With Quote
Old 05-29-2009, 09:45 PM   #23
JimVonBaden
"Cool" Aid!
Oddometer: 53,353
Originally Posted by Motor-110
Jim
Please advise....
Mike
It is probably not to the ml, but I have added 180ml several times, in a variety of bikes, through the 9:00 drain plug.
Jim
Old 05-30-2009, 09:06 AM   #24
spikesgs
Bliksem
spikesgs's Avatar
Oddometer: 254
Jim
Please advise....
Mike
i opened my drain plug and drained until it stopped and exactly 40 ml came out and i filled with 220ml 500 miles ago = 180ml left in there....good to go
2012 BMW F800GS TRIPLE BLACK
spikesgs is offline   Reply With Quote
Old 05-30-2009, 09:41 AM   #25
Motor-110
Motor-110's Avatar
Oddometer: 597
Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh, roger .
On the "To-Do List" today
M-110
Old 05-30-2009, 11:07 AM   #26
Wallowa
Oddometer: 5,453
18% Reduction In FD Lube? Better?
Good grief BMW now dictates that we put 18% less lube in our FDs to prevent seal failures? Less lube will stop the loss of seals and resulting bearing wear caused from loss of lube? Do I have this correct? The problem as stated in BMW bulletin was: "1. Increased temperature and high pressure lead to premature wear on the shaft sealing rings." So were the higher pressures a resultant of too much lube and/or increased temperatures? If increased temperatures, what generated the unacceptably, seal destroying high temperatures? Does anyone have access to a BMW source who can explain this? I thought that lube fluid aided in cooling, so removing 40 ml seems like it would cause the FD to run hotter. I would love to see the test data for 220ml vs 180ml FD temperatures and internal pressure against the seal [no vents in my FD] at a constant ambient temp and load.
So I guess I need to drain 40 ml of FD lube from my '07 GSA...but first I would really like to understand the counter-intuitive logic of doing so. You know an analysis of the "mechanism of injury"..
Daneel O....you are on inside...comments? Thanks....
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline   Reply With Quote
Old 05-31-2009, 04:45 AM   #27
JStancampiano
PhotoJoe
JStancampiano's Avatar
Oddometer: 395
Should have read " Falure to design a proper venting system lead to higher pressures pushing oil past seals"
2007 R1200GS ADV, 1978 R100T, 2009 FJR
JStancampiano is offline   Reply With Quote
Old 05-31-2009, 06:14 AM   #28
malloy
Oddometer: 741
Question Compromise
Thinking about Wallowa's post, how about 200ml .
F650GS (Build Date 11/11)
malloy is offline   Reply With Quote
Old 05-31-2009, 08:24 AM   #29
Wallowa
Oddometer: 5,453
Good One!
Good one Malloy..
Or...."Don't worry about it anyway, the lube never needs to be changed in the new FDs"....well, maybe once at 600 miles...OK...perhaps at 24K...75W90?; no many dealers use 75W140....how much? Standby I will get back to you on that one...
"In Wallowas"
Old 05-31-2009, 08:37 AM   #30
spikesgs
Bliksem
spikesgs's Avatar
Oddometer: 254
nice discount from bmw on my next service as they are using less oil.....in your dreams mate
Times are GMT -7.   It's 02:43 AM.
