Old 05-23-2009, 09:19 AM   #1
SR1 OP
Back in S. Korea
SR1's Avatar
Oddometer: 4,398
VERY hot weather coolant?
I'm buying an F650GS Dakar this week here in Kuwait. Today the max temp was something like 48* C. A scorcher.
While I don't expect to ride during the heat of the day, I certainly don't need anti-freeze here.
What would you guys recommend I use, as I should flush the coolant anyway (bike's been sitting a while)? I am thinking water. Can I use tap water (here it is pretty salty, might need distilled).
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 05-23-2009, 09:24 AM   #2
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,224
Straight water will have the best cooling properties but is bad for the cooling system. What is that stuff, water wetter or something? You add it to the water to be an anti-corrosion ingrediant as well as lubricating the water pump.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 05-23-2009, 10:09 AM   #3
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,198
I've had good luck desert racing in Southern California using Engine Ice
http://www.engineice.cc/
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 05-23-2009, 10:23 AM   #4
Jonex
zipper suited sun god
Jonex's Avatar
Oddometer: 1,357
Distilled water and Water Wetter.
The Water Wetter reduces the surface tension allowing better heat transfer.
Jonex is offline   Reply With Quote
Old 05-23-2009, 10:30 AM   #5
SR1 OP
Back in S. Korea
SR1's Avatar
Oddometer: 4,398
I'm not sure if Water Wetter is attainable here. Is running straight water long term really "bad" for anything?
Old 05-23-2009, 10:43 AM   #6
LuciferMutt
Oddometer: 11,224
Yes it will corrode the cooling system. Anti-freeze is also anti-corrosion.
Old 05-23-2009, 10:56 AM   #7
dump-a-thump
lapsed atheist
dump-a-thump's Avatar
Oddometer: 559
In Oz we ran straight water for a year or so, as long as its distilled it didn't make too much of an issue with corrosion. However, unless you are going to be crawling around in the sand at low speeds all the time, you really shouldn't be overtaxing the system on the 650, even in the low 40's, my fan is rarely on.
I'd make sure the rad is clean, inside and out, and go with a 20% coolant mix. It only lowers your heat capacity a tiny bit, plus gives you corrosion protection. If you find that's not enough, then wire the fan in to be live (100% run time) and/or drop a few degrees on the thermostat (or toss it).
dump-a-thump is offline   Reply With Quote
Old 05-23-2009, 01:02 PM   #8
Jamming
Desert RAT
Jamming's Avatar
Oddometer: 2,883
Here in Phoenix I'm running Engine Ice. Seems to work fine. The fan isn't cycling off and on as much.
2014 Victory Cross Country
2007 Triumph 1050 Tiger
WWW.Motorcyclistcafe.com
Jamming is offline   Reply With Quote
Old 05-23-2009, 03:11 PM   #9
rbrsddn
3banger
rbrsddn's Avatar
Oddometer: 2,625
Npg+
This waterless coolant will work www.evanscooling.com
rbrsddn is online now   Reply With Quote
Old 05-23-2009, 04:37 PM   #10
yosmitetom
Oddometer: 3,354
Propylene Glycol same as Engine Ice and any of the anti-freeze you see that is pet frindly. Most of the claims are greatly exagerated.
yosmitetom is offline   Reply With Quote
Old 05-23-2009, 07:14 PM   #11
lightfighter
where does this go?
Oddometer: 2,266
at the risk of opening a technical debate, water boils at 212, ethylene glycol and propylene glycol blends can have boiling points as high as 370.
so while water **may** conduct heat better(i really dont know, but i dont believe it does), it will evaporate off faster since it will be much closer to its boiling point in a water cooled engine
my ktm(525) on straight water went 500ml down on the same ride that my kids ktm(250) lost no prestone premix.(two hours in the desert at 85 degrees)
lightfighter is offline   Reply With Quote
Old 05-23-2009, 07:27 PM   #12
yosmitetom
Oddometer: 3,354
Water in a closed system doesn't evaporate. Water conducts heat much better than anti-freeze just doesn't lubricate very well or prevent corrosion.
Old 05-23-2009, 07:37 PM   #13
lightfighter
where does this go?
Oddometer: 2,266
does the f650 have a closed system? or a catch tank? the distinction is more than semantics. running straight water in a closed system that isnt that well closed can in fact force steam out of the system.
ive had jeeps do it, and ive seen honda mc's do it. my ktm has a catch tank, and it lost water untill i got to the store and picked up some coolant.
Old 05-23-2009, 07:39 PM   #14
yosmitetom
Oddometer: 3,354
If it has a pressure cap it is a closed system.
Old 05-23-2009, 09:39 PM   #15
roygrady
Oddometer: 8
Yeah its boiling off, so if you don't have the catch tank its gone, thats why coolant is better. It wouldn't be a closed system, there has to be an overflow pipe or it would be busting open pipes when overheated.
roygrady is offline   Reply With Quote
Times are GMT -7.   It's 08:07 PM.
